08-07-2016, 04:36 AM | #1 |
277
Rep 864
Break pad and rotor replacement
Hi guys
Fyi this is for 328i with standard calipers Im going to tackle a pad and rotor change next week. I found plenty of tutes but nothing specifically for a f30. Is there anything unique about f30 brakes Is there anything about the rear rotor and electronc handbrake i should be aware of when replacing rear rotor. Any diys specifically for the f30 or another model with the same set up i can refer to Thanks |
08-08-2016, 08:35 AM | #2 |
175
Rep 766
The BavAuto tutorials on youtube are fine.
The fronts are a cakewalk. As all the tutorials cover. I found I needed to use a breaker bar to break loose the caliper carrier bolts. Supposedly when you replace the rear rotors you need to adjust the parking brake - not a procedure I've attempted.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
08-25-2016, 09:03 AM | #6 |
277
Rep 864
08-25-2016, 11:42 AM | #7 | |
175
Rep 766
Finding track pads has been an even bigger ordeal. For street, Hawk has had some great pads - for 330mm you wanna be running the Hawk 5.0. Best pad out there for our setups.
08-25-2016, 09:20 PM | #8 | |
277
Rep 864
Thanks. Definitely will try non oem pads next time around. Would also love to try a light weight rotor if they exist |
08-25-2016, 10:04 PM | #9 |
175
Rep 766
The blanks do and are easy to get a hold of, but the majority of 328i's come with the base 312mm rotor and at least here in the states it seems like most M-Sports are ordered with the upgraded blue brakes with the 340mm calipers. Also I think the 330mm brake package was discarded and all m-sports come with the 340mm rotor/caliper starting in 2015 (I think at least).
