M2 Technical Topics > Suspension | Brakes | Chassis > Suspension noises?
      08-04-2016, 04:31 PM   #1
MTHRAR
438
Drives: LBB M2
Suspension noises?
My car is making a clicking/creaking noise in the (front?) suspension/wheels. Sounds like creaking plastic when I go around corners or when I'm going about 30 mph and jerk the wheel left or right to test to see if I hear that sound. It's a bit hard to explain. At first I thought it might be because of the stiff spring rates, but unsure. The car is usually fully warmed up. It's a predominant sound of clicking or creaking. I will probably getting it looked at soon, but not sure if this is something that is normal or not or if anyone else has experienced...
      08-04-2016, 06:36 PM   #2
gthal
gthal's Avatar
1903
Drives: 2018 340i xDrive
Haven't experienced this myself. Maybe something is loose and needs tightening?
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      08-04-2016, 07:36 PM   #3
MTHRAR
438
Drives: LBB M2
Yeah, this is a head scratcher for me. I may have the tech ride along with me as the sound can really only be experienced when I'm driving...
      08-09-2016, 11:03 AM   #4
MTHRAR
438
Drives: LBB M2
Ok, I found out what this was. I had an appointment at my dealer today and they informed me of a service bulletin on a part in between the Hub and Rotor. I'm not sure what exactly it is, but I'm thinking it's some sort of spacer? They are ordering the parts today for both right and left fronts to eliminate the crazy grinding/creaking noise I was hearing. It's not safety related, so I was able to take my car with me...Just an FYI for anyone else hearing funny noises like I have described.
Appreciate 3
reppucci339.50
gthal1903.00
      08-10-2016, 02:22 AM   #5
Yellowflash21
Slovenia
370
Drives: M2
Rofl, had similar issue a month ago, and it was just few small rocks that got stuck between hub and rotor.
They just cleaned it, and the sound was gone.
      08-10-2016, 10:05 AM   #6
MTHRAR
438
Drives: LBB M2
This isn't rocks even though 1 pebble did fall out when the tech had it on the lift, lol. I wish it was as that was the first thing that I thought of when I heard it because it does sound like that, however it creaks when going around turns pretty bad.
Don't mind that it's in portrait as I did not take the video (I'm driving). It only occurs on sharper turns.
Video:
      08-10-2016, 10:44 AM   #7
Yellowflash21
Slovenia
370
Drives: M2
yeah same noise bro, but it wasn't that loud.
Also, I could replicate it to service in the same mater like you did.
They just need to remove wheels, and do the proper cleanup. I'm positive it's just that as I had same noise as you.
MTHRAR437.50
      08-10-2016, 12:46 PM   #8
MTHRAR
438
Drives: LBB M2
Hmm, I thought the pebble/rock issue was more of a loud unbearable metal on metal screeching noise (Which I have heard on my previous cars - E46M3s). At any rate, they are going to be pulling the wheels when it goes in again, so hopefully the issue gets resolved. All in all, it seems relatively minor. Thanks for your input man!
EDIT: I'm not sure what is on the service bulletin though. I'll ask when I go back in for these (new?) parts they are referring to. Seems like this has been documented before.
      08-10-2016, 01:53 PM   #9
gthal
gthal's Avatar
1903
I've heard the rock/pebble noise and it sounds NOTHING like what you posted above. I've not heard that on my car. Let us know how it turns out... and thanks for posting the video
      08-11-2016, 01:45 AM   #10
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
I agree, i've had the stones clanging noise on a few occasions and it sounds completely different.
      08-11-2016, 12:55 PM   #11
MTHRAR
438
Drives: LBB M2
Ok, my car is fixed. Apparently there are shims that were contacting the brake heat shield, which was causing that awful noise. They replaced the shims and everything is good to go now. I'm not sure what caused the contact and I'm not sure if they bent the heat shield at all. I'll pull the part numbers if needed by someone.
      09-18-2016, 07:03 PM   #12
MTHRAR
438
Drives: LBB M2
Well...The noise is back. It's not as pronounced as it was before, but I think the brake heat shield is the cause again (or the shim). It's not a pebble, as I had that already and this sounds like something totally different. My CA actually recorded another video to show the SA. He said they may have an engineer look at it. I don't think there is any harm to the car, just a very annoying clicking sound.
For the noise - Reference post #6 in this thread.
      09-19-2016, 11:24 AM   #13
jinsii
France
13
Drives: M4
i have the same problem on my m2
in my m135I similar and the solution is :
my search :
SI B34 08 14 Ticking Noise from Front Axle When Cornering
SITUATION
The customer may complain of a ticking noise from the front axle when cornering, maneuvering, parking or
pulling away from a parking space. The noise can be heard as a light metallic ticking from the front outer
cornering wheel.
CAUSE
Movement between the brake disc and wheel bearing hub.
CORRECTION
Remove and clean the front axle brake discs.
Sand the hub surface on the brake disc
to the wheel bearing hub using 80-grit
sandpaper.
Sand the surface in a radial motion
(inside to outside around the surface.
Clean the wheel bearing hub surface.
Important!!
Do not sand the hub surface.
Do not apply any type of lubricant to
the components surface (wheel bearing
or brake disc).
Reinstall the front axle brake discs.
      09-19-2016, 11:02 PM   #14
MTHRAR
438
Drives: LBB M2
my search :
SITUATION
cornering wheel.
CAUSE
CORRECTION
sandpaper.
Important!!
or brake disc).
Hmm interesting. I'll inquire as I have an appointment at my dealer on Wednesday. Thank you for the information.
      09-20-2016, 12:51 AM   #15
jinsii
France
13
Drives: M4
KEEP ME INFORMED
      09-21-2016, 12:15 PM   #16
MTHRAR
438
Drives: LBB M2
KEEP ME INFORMED
So, I just got back from my appointment and they are now adding a friction plate to the right front. They only did the left front the last time, however they did follow the service bulletin the last time (that I believe you posted). I'll let you know once they install the part. They only just ordered it today, but the funny thing is, I have not heard the noise since Saturday.
      09-26-2016, 07:28 AM   #17
jinsii
France
13
Drives: M4
Hello, you're problem is ok ?
      09-26-2016, 09:18 AM   #18
MR.
MR.'s Avatar
No_Country
4398
Drives: BMW M2 CSL Turbomeister
This is common on performance cars. I have seen it and heard soooo many times on so many different cars. Nothing to be worried about, only means you have driven your car decently.
MR
      10-07-2016, 01:49 PM   #19
MTHRAR
438
Drives: LBB M2
Sorry, I did not get an alert like I usually do for a quote on the forum. Yes, they replaced the friction plate on the passenger side front. I haven't heard the noise since they replaced it. Hopefully that solves the problem for good, but if this crops up again, I'll post back in this thread.
      06-30-2017, 07:33 AM   #20
M2GB
71
Drives: 911 and M2
Hello
I have a creaking sound (not ticking) coming from my front left suspension. It happens at low speeds/breaking or when turning the wheel at standstill. Any idea? anyone with same problems?
I have eibach pros but was happening before anyway....
Top mounts?
the Fix above?
      08-25-2017, 10:31 PM   #21
srswans
35
Drives: 2022 G80 Manual BG
Repack Front Wheel Bearings
I had the steering click/clunk issue. It showed up the after a weekend at the track with new camber plates (which probably just hastened onset). My mechanic found a TSB for the X5 describing the same symptoms. He repacked both front wheel bearings per the TSB instructions to fix the issue.
I could easily demonstrate the issue by driving slowly (parking lot speed) and turning the wheel lock to lock. Alternatively, I could simply reverse direction and the front end would click/clunk. Never heard the click/clunk when driving at normal speed.
I have around 9000 miles on it when the symptoms first appeared.
      09-20-2019, 11:37 AM   #22
biomechaniod
Drives: E46 M3
I want to add my recent experience in case it's helpful to anyone...
I took delivery of a 2020 M2 Comp in August. Right away I noticed a significant metallic ping, creak, or tick sound coming from the front suspension. It would happen when entering my driveway or articulating the front suspension but also when turning the steering wheel while maneuvering into a parking spot. It was not a repeating rotational noise associated with the front wheels turning or related to applying the brakes. It sounded like something was loose or shifting whenever a load was applied.
They checked out the calipers and tried the shim fix between the hub and disc. The dealer eventually diagnosed it as a problem on the upper front strut. They ordered new guide supports and washers (basically the upper mounting of the strut where it bolts to the frame) and replaced both driver and passenger side parts.
It appears to have fixed the problem so far...
m2
