07-18-2016, 03:30 PM | #1 |
BimmerPost Supporting Vendor
813
Rep 526
Active Autowerke | M2 Sebring Track Report Take 2
Featured on BIMMERPOST.com See our first track day writeup at: http://f87.bimmerpost.com/forums/sho....php?t=1261307 The car setup was as follows: Nitto NT05 275/35/18 BC Forged RZ38 18x10 square BC Racing BR Type coilovers with camber plates Motorsport Hardware 14x1.25 -> 14x1.5 conversion stud kit (highly recommended if you use an impact to remove and install wheels like I do) Motorsport Hardware 12mm Traklite front spacers Active Autowerke FMIC Active Autowerke true 3.5" Downpipe Active Autowerke complete 3.5" Exhaust system Active Autowerke flash tune (15psi) IND cosmetics AWRON Vent Gauge BMW Performance Rear Spoiler The car was corner balanced and aligned by Apex Alignment two days before the event. The Drive: With the new suspension, alignment and wheel/tire setup I knew the car would be different, but I was honestly a bit skeptical because in stock form the car was so good! On the 2.5 hour drive up to the track I noticed that the steering sensitivity had increased quite a bit. The car reacted so quickly to steering input as if it was toe'd out (we set it at 0 toe). While this was a large improvement over stock I was now almost worried that the car was going to be too loose. On track I quickly forgot my worries and after a few warm up laps I began to get comfortable. The turn-in was so amazingly sharp but not uncontrollable at all. I had read reviews about the M2 including one from Bill Auberlen and I remember him saying that instead of understeering, the car would just hold it's line and accelerate through the turn when you applied mid-corner throttle. I never experienced that with the stock M2 (probably because I tend to overdrive cars) but after a few laps with this new setup I realized that this was exactly what Bill was talking about. At the point where the throttle would usually just initiate a slide with the stock car, I found that now it would just make me go faster. When I did manage to get the back end out, it was always more of a throttle steer than a drift and the car would continue to accelerate through the slide instead of just roasting the tires without gaining speed. The car was fast. During the morning sessions when temps were coolest we managed to trap 136.7mph on the back straight compared to the 129mph that the stock car did. Back in May going through Bishop's Bend wide open from Tower Turn was a little hairy, but doable. With the extra grip and power we were still able to hold it wide open out of Tower and around Bishop's and with the increased exit speed out of Tower we were now exiting Bishop's at 116mph compared to 111mph in the stock car. Unfortunately as the day went on the track got so hot that our speeds ended up being slower than the stock car at multiple points on the track, but the morning session was proof that the car really had improved. Overall the car was better in every way. An already amazing car was now even easier to drive and even more importantly even more fun to drive. I do believe that a slightly stiffer spring rate all around would help take advantage of the NT05 tires that we were running, although it would be at the price of some street comfort. We do plan on running a set of the new BC DR dampers with stiffer swift springs the next time around. Results: The track was extremely hot. Track temps were 110*+ it was taking it's toll on the car. Fluid temps rose and the with the new sticky tires the brakes were working much harder to slow the car down. Unfortunately the day didn't get any cooler and the best time we could put down was a 2:30.3. We dropped 1.9 seconds from our baseline back in early May when track temps were about 20 degrees cooler. At Sebring 1.9 seconds is about 375 feet (about 25 car lengths) going down the front straight which is a significant improvement, although I'm positive that with better conditions the car is capable of a mid 20 lap time. Looking back I should've suckered it up and pushed for a solid hot lap during the morning session yesterday while temps were somewhat normal. I will say that I'm disappointed in the car's temperatures after only a few hot laps. I saw maximum temperatures of: Oil: 259* Water: 229* EGT: 1762* For the next track day we plan on changing oil to a thicker Mobil 1 Racing oil (we are currently running OEM BMW 5w-30). We will also be adding our methanol injection system as well as potentially a larger oil cooler. Keep in mind that the conditions yesterday were extreme, and I admittedly was not being easy on the car at all. However, with 93 octane fuel and only 15psi we were seeing temps that I didn't feel comfortable running with. Thankfully the AWRON vent gauge we installed provided all of this numerical data because with the OEM cluster as my only source of information I probably would have kept driving **We have a video of the track day in the works which will be posted once it's been edited. |
07-18-2016, 10:47 PM | #2 |
Resident Engineer
135
Rep 748
So hot it melted your license plate holder.
I imagine you've pushed the M3/4 under comparable conditions, how were the temps holding up on the older siblings? Be a neat comparison with M3/4 'track' oriented cooling systems.
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
07-19-2016, 10:22 AM | #4 |
1557
Rep 2,504
Larger oil cooler would be nice to develop and produce to the M2 community. Have people upgraded their engine oil coolers on M235i vehicles?
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
07-19-2016, 03:44 PM | #5 | |
813
Rep 526
Yeah it was brutal. We've managed to melt one other plate frame that was on our One Lap of America E46 M3 years ago. I'm not sure about upgraded coolers on the M235i but we're going to look in to it for the M2 for sure. |
07-19-2016, 04:03 PM | #6 |
Rep 31
awesome development and documenting on this car. love the new wheels, i was looking at HRE, forgeline, BBS, but now i really like the bc forged rz38. if you don't mind me asking, how much are those wheels?
i can't wait to get my M2! going to do alpine white and 6speed as well. |
07-19-2016, 04:17 PM | #7 |
2049
Rep 3,714
259 isn't terrible if you're pushing higher than stock boost and it's hotter than hades outside. How long were the sessions and how long before oil temp hit 259?
M3 Adjuster7904.50 |
07-19-2016, 07:09 PM | #8 | |
813
Rep 526
The oil temp would reach 250 after about 3 hot laps. I kept pushing to see if it would plateau but sure enough it kept climbing so I shut it down. I could turn the pace down and run the whole session for sure, but where's the fun in that? |
amw896582.50 |
07-19-2016, 10:04 PM | #9 |
652
Rep 1,922
Drives: 2011 e91
David, did you check the stock water temp gauge just for shits and giggles? I'm wondering if it actually works or if it just goes from cold to warm and stays there like my Landy.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
07-20-2016, 05:04 AM | #10 | |
1736
Rep 4,495
What would be 18" F&R width/ET to get similar concavity to fit M235i ? Looking fwd to the video to hear M2 with AA 3.5" CBE.
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT Last edited by Bee Pee; 07-20-2016 at 08:43 AM.. |
07-20-2016, 07:52 AM | #11 | ||
813
Rep 526
AtlantaDude128.00 |
07-29-2016, 02:33 PM | #12 | |
552
Rep 2,633
bradleyland1503.50 |
07-29-2016, 02:44 PM | #13 |
salivator
38
Rep 539
phoenixbmwlife1911.50 bradleyland1503.50 |
07-29-2016, 06:11 PM | #15 |
144
Rep 952
Were you at the last NASA event at Sebring too? There was a white m2 booking it around the track. Looked and sounded great.
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10 |
07-29-2016, 07:53 PM | #17 | |
7905
Rep 11,785
07-29-2016, 09:43 PM | #18 |
Just enjoying my time
128
Rep 855
I'm not going to lie, those wheels look perfect on this car. Fracking gorgeous. Awesome setup dude. Looking forward to the video.
Current - 2022 Rivian R1T, 2021 Ducati Streetfighter V4S, 1969 Chevy C10
Sold - 2018 Tesla Model 3 Performance Sold - 2007 E92 335i If speed is death, then buy a Honda and live forever |
07-30-2016, 12:02 AM | #19 |
826
Rep 1,674
Makes me wonder how it would feel with a real suspension.
07-30-2016, 05:47 AM | #21 | |
7905
Rep 11,785
This time around the car had been modified with an aftermarket coilover system, a tune, wider wheels on all four corners and stickier tires. Since the car only gained about 2 seconds over its previous track day, one can understand that the OP was hoping for a lot more. I'll have to agree with okusa regarding the suspension. I haven't personally heard of BC racing at all, (which means nothing, of course), but it's not a well known setup, which i believe was the point being made. Apparently the OE M3/m4 setup wasn't "real enough " for the OP, seeing as he has already placed aftermarket equipment on the car. It also sounds like the OP plans to chance from BC BR to BC DR dampers, (not sure what those changes might entail... I'll have to research this product a little. ) |
okusa825.50 |
07-30-2016, 05:47 AM | #22 |
168
Rep 405
Any changes to pads or brake fluid?
