M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Active Autowerke | M2 N55 Intercooler
      07-18-2016, 12:24 PM   #1
David@ActiveAutowerke
BimmerPost Supporting Vendor
813
Drives: M2
Our AA Intercooler for your M2 is now available!
After a couple months of testing they're finally ready for release. Our stepped core intercooler is available in raw aluminum or black and can be installed at home in less than 30 minutes.
We tested it on the dyno back to back to log intake temps and the results are below. The baseline intake temp was 89 degrees and by redline the temp had climbed to 144 degrees fahrenheit. We immediately installed our intercooler and with a baseline intake temp of 96 degrees the temperature only rose to 118 degrees at redline. The stock car saw a gain of 55 degrees over the rev range compared to 22 degrees with our intercooler installed. Ambient air temps were 84 degrees and humidity was 67% here in sunny Miami.
We test fit and inspect all units after production before shipping. Before each unit is boxed we attach our signature plaque of authenticity with a stamped unique serial number. We guarantee 100% fit and finish with these intercoolers and they're designed to install quickly and easily.
Here's a photo of a raw aluminum intercooler installed on an F32 435i
Appreciate 3
      07-18-2016, 03:35 PM   #2
confusion
confusion's Avatar
601
Drives: 2016 M2
Nice! Thanks for posting the temp comparison.
2016 Long Beach Blue F87 M2 | DCT | Executive Package
XPEL Stealth Wrap | Tint 35%
HRE R101 in Brushed Dark Clear | 19x9.5 265/35/19 | 19x11 295/30/19
M Performance Steering Wheel | CF Rear Spoiler | Gloss Black Grilles & Side Gills
Build Thread
      07-18-2016, 03:50 PM   #3
BruceM
985
Drives: '17 6MT MG M2,930,Jag XKR 5.0
Exellent. Any thoughts as to whether the black finish would materially detract from temp drop over an extended track session?
      07-18-2016, 04:01 PM   #4
shemeld_135
shemeld_135's Avatar
652
Drives: 2020 SO - M2C
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
How much cutting out is involved to fit this? Hope none...?!
      07-18-2016, 04:06 PM   #5
813
Drives: M2
We always try to provide as much information as possible, and we test everything we sell
In my head it makes sense that the raw aluminum would be a better choice for dedicated track cars over the black option. That said, we do have a black one installed on our M2 and it's seen two track days now with no issues. I personally wanted to track the black one because if the black one can perform the raw one will have no issues.
None at all! It's a direct install with no permanent modifications necessary.
      07-18-2016, 04:12 PM   #6
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
Awesome work. I might have to get this when my M2 comes in!
How much does it run? You say it's 30 minutes to install. My guess is that you just remove the plastic panel under the car and the intercooler is visible from there?
      07-18-2016, 04:35 PM   #7
813
Drives: M2
That's correct, once the plastic panel is removed you have access to the intercooler. The intercooler is held in place by two torx screws. You need to disconnect the charge pipes that are connected by a single spring clip and then remove the two torx screws and then the stock intercooler will slide right out. Installation is the opposite of the removal. Quick and easy. I can't post pricing in this section of the forum but it's on our website and available from any AA dealer.
      07-18-2016, 08:33 PM   #8
TTFS
TTFS's Avatar
130
Drives: M2, F10 M5, E46 M3, E90 M3
Great work as always Active Team
      07-19-2016, 08:00 AM   #9
813
Drives: M2
Thanks guys!
      07-19-2016, 05:16 PM   #10
Jevi Javi
Dominican Republic
80
Drives: e46 M3 + G05 X5
what is the weight difference stock vs. active?
now all we need is an oil cooler...
      07-19-2016, 07:07 PM   #11
813
Drives: M2
Our M2 intercooler is ~19lbs. I haven't put the stock one on the scale, but it is definitely lighter than our all aluminum one. The plastic end tanks on the stock cooler make it pretty light. I'll weigh it tomorrow and let you know.
      07-25-2016, 11:06 PM   #12
srleadjb
srleadjb's Avatar
184
Drives: 2016 M2 LBB DCT
2016 M2  [0.00]
What was the outcome?
      07-26-2016, 01:39 AM   #13
Nine Lives
Nine Lives's Avatar
602
Drives: Austin Maxi
Nice looking product.
How is the throttle response compared to stock ?
      07-26-2016, 10:32 AM   #14
813
Drives: M2
On the same scale our stock intercooler weighs in at 8.2lbs.
We haven't noticed any increased lag or delay in spool time with the intercooler installed
      07-29-2016, 02:35 PM   #15
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
DKM3Power get your new IC
DrKevM5
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
DrKevM52273.50
      07-31-2016, 08:45 PM   #16
HP Autosport
3842
Drives: F80 M3
Looks good!
      09-01-2017, 05:38 PM   #17
Motivate
42
Drives: Shopping for a new one
Interested and was looking at the info specs. It says " Our stepped intercooler helps to maintain power over extended periods of time and will also yield a gain of 15-20whp on stock cars, with modified vehicles seeing 25+whp gains."
Is the 15-20whp typical or you mean only when compared to a stock intercooler set up running over extended periods of time?
m2
