07-14-2016, 04:45 PM | #1 |
Rep 14
update Nbt Evo retrofit
Hello I have Nbt Evo retrofit
Installed in f22 Version 001.044.003 Is there a way to update to the latest versions? I realized that if i update the device it is will lock? |
07-15-2016, 09:31 AM | #3 |
Rep 14
I want to update to all 001.047.003
Because I have a problem with music playback Every time I Clicks a next song it is paused, And i try in other friends of this version it also works have continuous music playing an instrument |
07-15-2016, 03:28 PM | #4 |
2373
Rep 8,364
You are referring to bmw.com/update, which is different from ecu (flash) programming.
07-17-2016, 03:12 PM | #6 |
2373
Rep 8,364
I do not know how your retrofit was done, but nothing done via center console USB should lock the NBT.
Do you have 001.047.003? If using emulators with donor VIN and FSC, Rheingold can lock NBT if FSC status is checked. If you try to update via ISTA-P, it may cause issue. |
