Methanol Nozzle
07-12-2016, 12:43 PM | #1 |
23
Rep 133
Methanol Nozzle
How much meth (50% + 50% water) can the the engine process without quenching/stuttering?
My newly installed system uses boost pressures from tapped charge pipe to activate progressive controller from Snow Performance. Currently pump starts at 22 psi of boost and Maxes out at 26 psi. Nozzle size is 225ml/min (#4). I think it can handle more volume than 225ml/min. Kit comes with 225 375 625 nozzles. What nozle/setting are you guys running?? |
07-12-2016, 01:33 PM | #2 |
55
Rep 218
I run dual nozzle 500cc X2. I just moved to all stainless steel lines so I will start running 70% meth then. This is with jerek 2.5 all deletes, egr race pipe, and helix intercooler.
07-12-2016, 02:14 PM | #3 |
102
Rep 320
Boost is just one of several variables that control water/meth flow rate vs. quenching. Your starting and max injection points are reasonable, and you should be able to inject quite a bit more solution without quenching. Simplistically, if your boost is around 22 psi and your rpm is up around 2500+, your engine should easily swallow about 630 ml/min. Mine does.
07-12-2016, 02:38 PM | #4 |
Warrant Officer
375
Rep 1,341
I run 1000cc at 62% meth, and I start spray at 20PSI and max out at 32PSI. The car hasn't quenched with this setup. I am also running BPC stage 3 so it's optimized for methanol.
I feel that you can kick it up a notch and go for 600-1000cc.
Deleted, ATM I/C and tuned by B.R.R.
07-12-2016, 05:11 PM | #6 |
22
Rep 109
Best nozzle size is a function of a number of variables including what your primary goal is for the meth injection. If cleaning is your goal then a smaller nozzle spraying earlier (lower boost) is better. But if max power is your goal then a larger nozzle spraying later is your ticket. Devil's Own website has a nozzle calculator using fuel type, engine displacement and max boost level; for a stock 335d it suggests 650ml/min is about right. If power is your primary goal (of course more power is always nice even if looking for cleaning primarily) then the largest of the nozzles you have is the right one. If cleaning, I would recommend the middle size nozzle and start it spraying earlier and also reach max a little earlier (perhaps as early as 20 PSI). I believe that some minor quenching is not detrimental to the engine so you may want to play around with the settings, get a solid feel for what quenching feels like, and then make your settings appropriately to eliminate the quenching.
07-12-2016, 06:28 PM | #7 |
23
Rep 133
Thanks for all replies. It seems i grossly undershot the nozzle flow rate as my primary goal is power. Glad to hear there's more performance left on the table as I will add a second nozzle rated for 625ml/min. Total will increase to 900 ml/min. This is with deletes & jr tune.
Interesting how the engine can eat approx 3x the meth compared to current setup... that small 1 gallon tank will be devoured in no time! If anyone's wondering, the Snow progressive controller is able to read and command meth injection up to 50 psi. |
07-15-2016, 12:25 AM | #8 | |
671
Rep 1,442
07-15-2016, 10:59 AM | #9 |
103
Rep 580
Another thing to consider is how the voltage ramps run on that controller. Not familiar with your controller, but looks like a 200+psi pump you've got there, so starting it earlier will increase your flow rate significantly through the upper end of the pressure range regardless of the nozzle(s).
07-15-2016, 11:24 AM | #10 |
41
Rep 241
I gotta ask the newbie question to you and others who want to chime in. Are you and others using 100% or 99.9% concentrated our methods from a race shop or are you guys using windshield washer fluid or heet products? Wanted to capture the Intel of what others are using and their specific success rates and dollars saved?
07-15-2016, 01:07 PM | #11 | |
Warrant Officer
375
Rep 1,341
I forgot how much it comes out to, but I want to say somewhere around $6 per gallon for my own mix, opposed to Snow's 50% which costs roughly $10-12 per.
07-15-2016, 01:59 PM | #12 | |
41
Rep 241
07-15-2016, 02:25 PM | #13 |
Warrant Officer
375
Rep 1,341
That's a good price, it's $50 per 5 gallons of methanol for me out here. I need to find a bulk supplier, lol.
07-15-2016, 02:49 PM | #14 | |
427
Rep 1,040
07-15-2016, 03:01 PM | #15 |
213
Rep 2,210
Yeah I just paid $15 for a 5 gal drum, $50 is crazy high. I got mine from a race shop that gets it in bulk, but if you can find an actual direct supplier you might get an even better deal.
07-15-2016, 03:07 PM | #16 |
95
Rep 308
Drives: 2011 335d M-Sport, Nav/Blinds
I believe the correct term for the thread title is "MethaNozzle"
07-15-2016, 03:25 PM | #17 |
41
Rep 241
cheers true that! 😎👏👏👏 I thought it was a pretty good deal. So I ordered the drum! A lot of fun to last me a little while lol 😂
07-16-2016, 01:10 AM | #18 | |
671
Rep 1,442
