06-28-2016, 11:56 AM | #1 |
BimmerPost Supporting Vendor
3815
Rep 54,312
Drives: F80 M3
Vorshlag's F87 M2 camber plate
A little sneak preview for you guys on the new Vorshlag Camber Plates for your F2x F3x and F8x, including the M2.
The tricky part was keeping the stack-up height of the camber plate + perch + radial bearing at the stock height, so the car isn't raised or lowered. Vorhlag never made a camber plate + perch this short, but the new BMW top mounts are all going to this super short stack. The new assembly uses a unique radial bearing and assembly procedure that lowers the stack up height of our assembly by nearly 40%. Very exciting - nobody else is doing this design as short or with a proper steel, sealed radial bearing for the spring perch. Other designs we've seen use a plastic radial bearing which has a very short lifespan. The spherical is in the upper bearing holder and allows the shaft to pivot relative to the plate. The spring pivots against the perch, just like the OEM top mount design BMW uses now. The large diameter billet upper spring perch fits the stock spring and also allows for re-using the factory rubber isolator above the spring. Design has been finalized and in production. Luckily there's no laser cut or other outside pieces they need, so they can machine this 100% in-house - no delays. We are looking at about 4 weeks before these plates are ready to ship. Last edited by HP Autosport; 06-29-2016 at 06:12 PM.. |
07-19-2016, 05:39 PM | #2 |
3815
Rep 54,312
Drives: F80 M3
No solid fitment has been confirmed. However, other brands of F2x and F3x plates have been used on M2 a number of times already.
Here is MCS with TCKR F2x/F3x plates for F87 M2. |
08-04-2016, 01:28 AM | #3 |
103
Rep 85
are the vorshlag's available for purchase yet?
2016 F87 M2 (current)
2019 Gt2 RS(current pipedream) 2016 Cayman Gt4(sold) 2010 E93 M3 (sold) 2012 Wrx Sti (sold) |
08-04-2016, 12:21 PM | #4 |
3815
Rep 54,312
Drives: F80 M3
08-13-2016, 08:20 PM | #7 |
3815
Rep 54,312
Drives: F80 M3
08-18-2016, 10:41 AM | #9 |
3815
Rep 54,312
Drives: F80 M3
08-28-2016, 02:18 PM | #11 |
3815
Rep 54,312
Drives: F80 M3
09-15-2016, 04:41 AM | #12 | |
7905
Rep 11,785
Tell Terry @ Vorshlag if they need a donor car then I am sure we can locate one. @paradoxical3 - I've run multiple sets of GC PLATES on E30 and switched to Vorshlag on that E30 and My 1M prototypes ( which also are for E9x) are excellent. Highly recommended. |
09-15-2016, 06:16 PM | #13 |
3815
Rep 54,312
Drives: F80 M3
Call Terry.
11-22-2016, 07:11 PM | #15 |
3815
Rep 54,312
Drives: F80 M3
Nothing yet.
We have sold M235i or none M plates for M2 applications using coilovers already so we know the similarities. However, Vorshlag still needs to confirm fitment using stock profile struts and springs. Anyone close by should contact Vorshlag. |
11-22-2016, 11:33 PM | #17 |
3815
Rep 54,312
Drives: F80 M3
12-08-2016, 08:35 AM | #18 | |
7905
Rep 11,785
It's a better product, plus maybe you can get a little love for being a beta tester. It worked for me and that's how they made plates for the 1M and E90.. E9x guys just don't show enough appreciation .. |
12-08-2016, 12:57 PM | #19 | |
3815
Rep 54,312
Drives: F80 M3
02-14-2017, 11:45 AM | #21 | |
3815
Rep 54,312
Drives: F80 M3
Give Jon or Jason at Vorshlag a call. Your interest will hurry them along to get the plates on the market. |
02-14-2017, 01:56 PM | #22 |
300
Rep 379
Sorry, meant to say for the M Performance Coil-overs. Will do! Thanks
BMW CCA and PCA HPDE Instructor
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
