06-28-2016, 11:18 AM | #1 |
624
Rep 796
I thought I would start a thread for everyone to share specs or any thoughts regarding factory or track oriented alignment settings.
Edit : This first alignment was with lowering springs only and no camber plates. I had a bit too much toe in at the rear. When I installed coilovers/camber plates I settled on 1/16 total toe in the rear as recommended by HPAutosport. 0 toe with -2.8 degrees of camber front and -2.0 in the rear. Car felt great on the street and track. |
06-28-2016, 11:34 AM | #2 |
Dinosaur supervisor
3027
Rep 4,214
There is a thread already where I posted mine.
http://f87.bimmerpost.com/forums/sho...ight=alignment |
06-28-2016, 11:49 AM | #3 |
BimmerPost Supporting Vendor
3777
Rep 54,162
Drives: F80 M3
From what you posted the rear has way too much toe-in, am I reading that right?
06-28-2016, 03:27 PM | #5 | |
624
Rep 796
I was put off that the m4 spec called for almost 0 toe in the rear. I've never ran so close to 0 on a rwd car. So I went in to about 4mm, equal to other f80 track alignments I've seen. Although I'm not running much camber at all. What's your setup? I could be totally wrong but I didn't think it was overkill. It doesn't help reading a alignment in MM and trying to translate/convert over from Swedish haha. |
06-28-2016, 03:38 PM | #6 |
Dinosaur supervisor
3027
Rep 4,214
Most of the alignments should be easy to understand the names of.
The numbers are in the order Before // Accepted range // After adjustments. So Börvärden is what the allowed specs are for each item. |
06-28-2016, 03:41 PM | #7 | |
624
Rep 796
I've just heard of the f80 problems of squirm under braking with the almost 0 toe in they call for. I believe IND and others pushed it to around 4mm total to help the problem. |
06-28-2016, 04:17 PM | #10 |
813
Rep 526
We're currently setup with -2.5* camber up front with 0 toe and -2* camber in the rear with 1/16" total toe-in.
StealYourFace260.00 |
06-28-2016, 05:16 PM | #11 | |
3777
Rep 54,162
Drives: F80 M3
06-28-2016, 06:43 PM | #12 | |
624
Rep 796
07-04-2016, 09:21 AM | #14 |
4397
Rep 2,856
Drives: BMW M2 CSL Turbomeister
Guys, what is your preferred alignment setting for a stock car? Any thoughts on that?
I might have my tuner look at the set up since I have vibrations under heavy braking, and I do not think my brakes would be the main issue here with only 10K km driven. MR |
07-04-2016, 09:48 AM | #15 |
1418
Rep 2,559
Drives: Rapidly from A to B
Anyone, how much front camber can be dialed in without aftermarket camber plates?
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
07-04-2016, 12:50 PM | #17 | |
624
Rep 796
Camber for me as well as everyone is -1.5 up front unless you have plates. No pins to pull here. I set the rear at -2. |
07-06-2016, 05:52 AM | #18 | |
4397
Rep 2,856
MR |
07-07-2016, 04:55 PM | #19 | |
1236
Rep 1,963
Current
AW BMW M2 Past VO BMW 1M |
07-07-2016, 10:52 PM | #20 | ||
624
Rep 796
07-11-2017, 11:03 PM | #22 | |
624
Rep 796
The only other suspension mods are H&R sways and adjustable links. have a feeling I might be dialing back those camber figures but I have yet to see tires temps on track with the new setup. The car feels great though. 0 toe front And a little more than factory toe in rear |
