TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Question on side markers tapping into + DRL side to be on "all the time"
      06-26-2016, 05:44 PM   #1
kisarci
64
Drives: 2007 335i
Hey guys, so I've been thinking about buying this item
http://www.ebay.com/itm/FITS-BMW-E90...5Xbac1&vxp=mtr
I searched all over google and cannot find a direct installation DIY guide to tap the red wire to a constant power source so the side markers run as DRL. It says to tap into the positive side of a DRL source. Any idea what the best way to run the wires are and what to exactly tap into?
07 335i e92
      06-26-2016, 10:48 PM   #2
luv135i
luv135i's Avatar
60
Drives: White
If you get carly , i believe coding drl as sidemarkers is an option.
      06-27-2016, 12:34 PM   #3
kisarci
64
Drives: 2007 335i
Thanks for the response! But i don't want to lose the function of having the turn signals. I want to have the white LED "on all the time" as DRL, and switch to the amber blinkers when using the turn signal. Correct me if i'm wrong, but i believe coding it through the carly app will just have them "on all the time" instead of switching back and forth from the white to amber when using the turn signal.
07 335i e92
      06-27-2016, 01:25 PM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Are your AE's working as drl?
If so, tap into positive feed for them
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      06-27-2016, 02:16 PM   #5
kisarci
64
Drives: 2007 335i
Yes my AE's are working as DRL. Where do i exactly tap into the positive side?? Sorry, i'm not very good with electrician work but can do it if i have a walk through.
07 335i e92
