06-22-2016, 12:51 AM | #1 |
13
Rep 83
Hifi, harman?
Hi all
The harman on the F22 is not logic7, and there's no equalizer but the same treble and bass settings as the hifi. My questions are: 1) do the hifi and harman use the same harness? 2) if yes, are they interchangeable and require no coding? I searched everywhere and could only find pics of harman amp plugs and harness (upgrading to bimmertech). Not even one single post of hifi upgrading to harman and pics of the hifi amp plugs and harness (i understand one might as well upgrade to better choices, but i just want to know) thanks |
06-22-2016, 12:22 PM | #2 | |
1753
Rep 2,942
The reason why no one's upgraded the Hi-Fi amp to an HK one is that there's no compelling reason to. Both are underpowered, and both have built-in DSP that limits bass and treble and bumps mids ... ... and according to RealOEM and a part-number search, the latest version of the HK amp runs nearly $1,100 ($1,217 list). Another consideration: both systems feed the dual underseat subs differently. Hi-Fi uses a single mono channel; HK uses two summed channels. It theoretically could work with OEM wiring, I believe. But unless you score a unit from a salvaged car for a song, I wouldn't bother.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
06-22-2016, 09:43 PM | #3 | |
13
Rep 83
the reason that i want to change the stock amp to hk is because all other speakers (except the 2 subs) on my car are already upgraded to hk. so i want to 'see' the whole picture of what a full hk system is capable/incapable of you are right about the crazy markup of the non-L7 hk amp. so i am looking at a new amp and 2 used subs at a discount |
06-23-2016, 08:14 AM | #4 |
64
Rep 155
I pulled the stock HK subs from my 2016 m235i and they are 2 ohms. I have the Bimmertech amp installed now so I have not checked to see if they are running off the same channel in the HK amp or not but they are not connected together in the actual wiring from the amp to the speakers.
06-23-2016, 10:18 AM | #5 | |
1753
Rep 2,942
I believe the HK still sums the left and right channels at the amp, but if the HK subs are now 2 ohms each, that means they have to be receiving a mono signal to work in series at 4 ohms, which is what the remainder of the HK drivers are. Bottom line for the thread: The above means the likelihood of a Hi-Fi-to-HK amp swap working is greater.
06-24-2016, 04:05 AM | #6 | |
13
Rep 83
When RealOEM returns "Exchangeable retrospectively" for a product ID, I will understand it as backward compatibility. For example, if I have a 2015 Oct car, I cannot use an amp produced before that date. But what the hell is "Bilaterally exchangeable" ????? I guess safer to: (1) if possible, buy an amp with the latest production date (2) for older production dates, search by VIN first (3) make sure to buy only those newer than my car's manufacturing date (VIN search doesn't return "exchangeable retrospectively" or "bilaterally exchangeable") |
06-24-2016, 09:10 AM | #7 | |
1753
Rep 2,942
Those tags also partially relate to core exchanging; in other words, turning in the 'core' of a product so that it can be remanufactured and re-sold. (Think alternators back in the day).
