Grinding noise from MT
02-11-2006, 01:18 PM | #1 |
40
Rep 219
I´ve been getting a sort of metal against metal noise from my manual tranny since I bought the car. The sound can be heard in 2nd gear in speeds around 10 - 20 km/h.
I was thinking that it´s a break in issue but I´ve now got 5000km on the odo and the noise is still there. Anybody else hear this noise? |
02-11-2006, 01:28 PM | #2 |
hotsand5
49
Rep 806
does the sound happen when you are shifting, ie. from 2nd to 3rd? If it is, then your syncro's might be shot. That's a trans rehaul if it is.
-2006 BMW 330i-Sapphire Black- Tera Leather-Aluminum trim- 6spd manual- Sport- Premium- Cold- Navigation- Euro. delivery
-2005 Yamaha Warrior 1700 102cu" |
02-11-2006, 01:37 PM | #4 | |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
02-11-2006, 03:11 PM | #6 |
40
Rep 219
I was kind of hoping that several people have this issue and that it´s been reported to BMW, my guess is that my dealer is going to be a pain in the ass about this and try to convince me that everything is fine...
02-11-2006, 04:55 PM | #7 |
14
Rep 940
I have found that dealers are good about fixing problems if approached properly. I suggest you tell the service writer about the symptoms but not offer a diagnosis. They sometimes grouse about the rate paid by the manufacturer/importer for warranty work but it isn't that bad. If you develop a good relationship (give and take) with the service writer/manager, they will likely help you to say the right words to find relief. It has worked for me for a lot of years!
02-11-2006, 05:34 PM | #8 | |
40
Rep 219
02-12-2006, 12:40 AM | #9 |
1431
Rep 16,628
i think i am have the same problem as you. is the noise coming from the rear?? like the diferential? i have an appointment with them feb 16. i will let you know what they find. my problem have a metal clinky noise when traveling about 5 miles. even in reverse.
02-12-2006, 02:24 AM | #10 | |
40
Rep 219
02-12-2006, 07:30 AM | #11 |
93
Rep 2,168
I have a problem with 1-2 shift quality, baulks sometimes, other times very notchy and coarse... was hoping this was the problem you were having... not to jinx you, but to see if it was just me or not. hmmmm... anyone else have this?
'05 E90 325i | '06 E90 325i | '08 E90 325i LCI | '13 F30 328i M-Sport | '14 F10 535d M-Sport
Current: '19 G01 X3 M40i |
02-13-2006, 03:33 AM | #13 |
Rep 256
When I picked up my car from Munich my tranny started acting up on the drive back. It was "shifting" but not all the way does that make sense? I could shift between gears but the throw was not completeing. I turned off the car and turned it back on and it went away. Any ideas what would have caused this?
02-13-2006, 07:35 AM | #14 | |
550
Rep 6,563
02-13-2006, 07:45 AM | #15 | |
Rep 297
02-13-2006, 10:05 AM | #16 |
19
Rep 199
2nd gear is very moody you have have to shift just right or it will not be smooth at all.
'13 E92 M3 ZCP DCT
Prev:'06 E90 330i ZSP, '12 Mustang 5.0, '15 VW GTI |
02-15-2006, 05:31 AM | #17 | ||
93
Rep 2,168
I talked to the mechanics about it today while having my active cruise control realigned. They said they would look at it, and must have adjusted something - including my clutch and it is shifting far better now...
02-15-2006, 05:41 AM | #18 |
101
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
this thread reminds me of a similar issue i had back in 92 with my new e36. notchy & sometimes harsh gear changes in the mt.
service manager immediately pointed to re filling the tranny with a heavier duty oil. job done and problem solved. never had the problem again. my e46 never had this problem.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
02-15-2006, 05:48 AM | #19 | |
Rep 230
Any chance your improvement from the cruise adjust was just wishful thinking? CM
Compos Mentis
----------------- 2006 330xi Arctic, black leather, aluminum. 18000 miles... |
02-15-2006, 06:03 AM | #20 | |
93
Rep 2,168
Apart from the cruise, they also did look specifically at the shift quality of the transmission. They said that they did adjust some things, and the shift action is vastly improved. The clutch friction point is also changed - I like my friction point down low, I was much higher before. I find this makes it easier to time changes...
02-15-2006, 06:31 AM | #21 |
Rep 297
Hi jamie
Definitely agree with your comments about the 'bite-point' being low down. I remember test driving an E46 coupe a few years ago which had a manual transmission - hopped in, and went for a drive, I was even surprised myself at how smooth I was able to move off when the bite point was low down A few weeks later, having settled for the saloon, the bite point was closer the top of the clutch travel, and I stalled twice while trying to move off from the dealer car park, and found myself revving unecessarily in some hasty situations. On the whole, you get used to it. Having it high up means you can be a bit lazy when dropping the clutch for a shift, but definitely cannot be done with a low friction point |
02-15-2006, 06:55 AM | #22 |
28
Rep 1,832
Drives: bmw e90 320d
you should have taken it to the dealer immediately but well take it now
e90 320d,arktis,lumber support, hifi speaker, alarm, dakota beige, 162 18", xenon with washer spray,window chrome trimmings, professional radio, 6 cd changer wood trimmings
6 speed manual. |
