2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing Alignment specs
      06-15-2016, 06:26 PM   #1
zipphreak
No_Country
452
Drives: m235xi
Alignment specs
Just curious what other F22's on the track with camber plates are running ?
I've seen a couple people with 2.5 front/ 1.5 rear ? 1/16 toe in front, 1/8 toe in rear ?
What's a good starting point, keep in mind i have the M235xi AWD . I tend to see alot of different recommendations for FWD vs RWD vs AWD for toe settings. Some lean towards absolute 0 in the front, others try to balance out the factory understeer with camber/toe..
-Paul
      06-15-2016, 07:01 PM   #2
Liquidpaper
Liquidpaper's Avatar
450
Drives: '15 M235i
2015 BMW M235i  [0.00]
-Paul
I am a relatively novice driver, so my alignment spec leans toward slight understeer (RWD):
Front:
Camber: -2.3 (maxed out on GC plates -- will probably increase to 2.5 with Vorshlag).
Toe: 1/16 in
Rear:
Camber: -2.25
Toe: 3/32 in
I think a lot of people run around -2.2 in the rear, and its the front you usually work with to induce/restrict understeer/oversteer.
Just a word of caution, before I got my LSD, my alignment was 2.25 front and 1.7 rear. The car was impossible to control on fast (80 mph +) corners, as the back always gave away before the front did. Once I got my LSD, this was not so bad, but I also increased rear camber to at least -2. If you ask Pparana or rwalker, they run much higher front camber, but similar rear camber to me (they are far more experienced drivers).
I do not know how this changes with having an xdrive car, but I would imagine the xdrive would make you push more, so maybe you would want to loosen the back up a bit (less camber), or tighten the front (more camber) to induce some oversteer.
      06-15-2016, 07:06 PM   #3
zipphreak
No_Country
452
Drives: m235xi
Thanks for the comments. I was hoping Pparana and Rwalker would chime in too. I follow them on here .
      06-15-2016, 07:57 PM   #4
Pparana
463
Drives: 2015 m235i
what size tires and what suspension are you running? sway bars upgraded?
      06-15-2016, 08:06 PM   #5
zipphreak
No_Country
452
Drives: m235xi
235/40/18 front, 265/35/18 rear.. stock sways.. GC camber plates. xDrive.
      06-15-2016, 11:08 PM   #6
Pparana
463
Drives: 2015 m235i
AWD:
I Would prob. run zero toe front, w 2 to 2.2 degrees camber, rear 1.5 to 1.8 w 1/16-1/8 to start. Adjust to suit driving style.
RWD:
LP setup is pretty close to what I would run on street tires stock ride height, maybe less rear toe.
I run 3.1 front w zero toe, 2.1 rear w 1/16 toe. But that is on coilovers w sways and semi slicks. Car is pretty loose, but that's my preference.
      06-15-2016, 11:38 PM   #7
Liquidpaper
450
Drives: '15 M235i
Originally Posted by Pparana
AWD:
RWD:
Note that I have the H&R bars, but on stock springs. Car is a little tight, but I tend to like it that way.
      06-17-2016, 06:48 PM   #8
zipphreak
No_Country
452
Drives: m235xi
Bump for others running M235i on the track.. Got a custom alignment, camber plates? Post here and let me know what your running. Going on the rack tomorrow just looking for opinions/options.
      06-19-2016, 04:36 AM   #9
zipphreak
No_Country
452
Drives: m235xi
lol a difficult one. how would i know that unless you just told me. you had to make that post you couldn't have just put your numbers or a link?
http://www.2addicts.com/forums/showthread.php?t=1213402
      09-10-2016, 01:11 AM   #10
casper83
casper83's Avatar
119
Drives: M235i XDrive
I went with the -2.5 in the front and -1.75 in the rear, 1/16 front toe & 1/8 rear toe. 245 square & awd. It was fairly balanced. I may try -2 in the rear next time just to see how it reacts.
      09-10-2016, 11:24 AM   #11
zipphreak
No_Country
452
Drives: m235xi
What shocks/springs are you running in the front ? OEM? Lowering Springs/coilovers ? I couldn't push more than -2 with my xdrive and oem shocks/springs.
      09-11-2016, 01:09 AM   #12
casper83
casper83's Avatar
119
Dinan springs
      02-15-2018, 08:06 AM   #13
teinesina
Drives: M240xi
I'm picking up my m240xi tomorrow
One of the first things I want to do is add camber plates and get a more aggressive alignment, so the all the specs above are superrrr helpful. I plan on autocross and light track duty.
One question i had was how much you can loosen the car up and reduce understeer with just the addition of toe out in the rear (looks like most of you are running that anyway). I'm thinking I might try it a bit without the camber plates and see how it feels.
I'm coming from a MINI that I had to run -2.6 camber in the front and 0.1 toe rear to neutralize the understeer (barely)
      02-15-2018, 09:11 AM   #14
bubbajan21
Drives: BMW
Couldn't this have easily been resolved track-side by dialing back the front camber to reduce overall grip and bring front/rear grip more into balance?
      02-16-2018, 01:32 PM   #15
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
RWD
Front:
-3 camber
0 toe
Rear:
-2.5 camber
1/16 toe in
255 square RE71. KW Clubsport coilovers. Custom front spring rate (for square setup).
EDIT: Just saw you're AWD. When I had my Evo I did:
0 toe rear
Slight toe out in the front.
This was to get the AWD feel more RWD bias.
      02-26-2018, 08:14 AM   #16
capt_and
250
Drives: 2017 m240i
I am at -2.7 on the front and have really even temperature distribution between the inside and outside of the tires.
At -2.2 on the rears, I am experiencing a 6*F different between the inside and outside of the tire (inside hotter). I'll need to dial it back to -2 or -1.8.
Something to keep in mind for some folks that may be browsing for information, these alignments are for the track. Doing these alignments for a car that is for the street is expensive and less safe. With a lot of camber, you have less of a tire contact patch with the ground when driving normally. Less contact with the ground = less traction. With a lot of camber, you'll also wear out the inside of your tire a lot more quickly than if you kept stock alignment (because you changed the contact patch from an even distribution across the tire to just the inside).
The reason for this alignment is for the track or autocross where you are pulling a lot of lateral Gs and the lean of the car requires camber to get the max contact patch on turns for extra traction. It also saves money on tires since the contact patch is spread equally on the hard turns instead of the outside edge.
"Spirited" driving on public roads do not need all the extra camber. You don't need more camber to get rid of the understeer if you don't track/autocross. If anybody every runs into an understeer/oversteer issue on dry public roads, that's more of a public safety issue.
M240i Racing Build
Instagram: @Capt_and
Search this Thread:
Advanced Search
2addicts
