Hard Brake Pedal?
03-18-2008, 10:53 AM | #1 |
Rep 227
Hard Brake Pedal?
Hi all
When I return to my car after it been parked up I put my foot on the brake pedal before I start the car (as you need to in the auto) and sometimes the pedal is rock hard? As if someone has been pumping the pedal without the engine running. When the engine starts the pedal sinks (as it should) returning to the normal position. This happens randomly and I can see no pattern or reason for it. Anyone else had this? Or knowguess why this is happening? |
03-18-2008, 11:11 AM | #2 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
Yeh i think i have mate, not really thought bout it tho! or even take much notice!
997.2 GT3
03-18-2008, 02:18 PM | #3 |
97
Rep 1,134
Drives: BMW G20 330e M Sport MY20
Maybe the brake servo's may be applying some pressure on the fluid keeping the pedal rock hard. When you start the engine the servo's will be running keeping the pedal soft.
I've rolled in traffic (with engine off) and nearly panicked when the car nearly failed to stop So never try rolling down a hill with engine off
20 BMW G20 330e M Sport Portimão Blue/Cognac, Driver Pro, Tech,M+ lumbar, storage packs
Long gone -15 Peugeot 308 2.0HDi GT AUTO Magnetic Blue, 10 BMW F10 520D SE Xirallic Imperial blue/Cinnamon Brown, 06 E90 320si - Le Mans Blue - Totally standard specification (Scrapped RIP 12/08/2010), 00 Peugeot 306 2.0 SE Cabriolet, 94 Rover 214 SEi, 91 Fiat Uno 60S Mk2 |
03-18-2008, 02:34 PM | #4 | |
THE Viv
185
Rep 4,743
Drives: 330i SE
Have a look here. Viv |
03-18-2008, 02:44 PM | #5 |
172
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
I remember that thread Viv, but the guy never came back with the answer.
I've taken mine to the dealers for exactly the same thing and they couldn't find anything wrong with it but it still does it occasionally, although the brakes operate as they should whilst in use etc. I've noticed though that if you pull up somewhere and happen to press the brake pedal more than a couple of times whilst parking for instance (even gently) then switch off the engine, when you return to the car and foot on brake pedal to start again, the pedal is 'hard'. Buggered if I know. |
03-18-2008, 03:09 PM | #6 |
23
Rep 635
Diesels don't build up vacuum in the same way as a petrol. They have a vacuum resevoir instead. Its a black canister like thing left hand side under the engine cover. Over a period of time, when the engine is switched off, the resevoir bleeds to atmosphere, leaving no residual vacuum in the servo as you'd have with a petrol. Its designed to do this and perfectly normal.
On the other thread it seems as though the issue is with the tolerances of the starter inhibit switch, rather than the braking system. |
03-18-2008, 03:54 PM | #7 |
172
Rep 7,953
Drives: Merc diesel
Thanks for the info.
I've looked at that thread again and that guy had trouble starting his car - hence your ref. to the starter inhibit switch. Mine's fine in this department. |
03-18-2008, 04:12 PM | #8 |
42
Rep 379
I've noticed this occasionally too... not sure of the reason though.
I've also noticed the brake pedal is a lot more sensitive when cruise control is on ... nearly stood car on it's nose a couple of times.
2018 G30 520d M Sport with M Sport Plus - Mediterranean Blue
Previously: 2015 F32 430d M Sport, 2012 F10 520d M Sport, 2009 E92 320d M Sport, 2006 E92 335d, 2004 E60 530d, 2000 E39 525d, 1997 E39 523i |
03-18-2008, 05:18 PM | #9 |
23
Rep 635
This one is a side effect of the "Brake Standby" feature of the latest Bosch ABS. The dynamic cruise control uses this feature to move the pads closer to the brake disc so that less pressure is required when braking is activated by the cruise control brake function.
So when you hit the brakes and cruise is on, the biting point is different to you have normally without cruise.. Does take a bit of getting used to. |
03-18-2008, 05:44 PM | #10 | |
275
Rep 9,218
My mate drove my car recently and accidently hammered on the brakes because of this. |
03-19-2008, 03:49 AM | #11 | |
Rep 227
You say this is with diesels, do you mean all diesels or just BMW's? I ask this as I've never had this with other diesels I've driven. Also, do you why the diesel would run a different brake servo system to the petrol? Thanks all for your responses. |
03-19-2008, 04:15 AM | #12 |
22
Rep 301
I've had this a couple of times - seems especially when I rush into the car, shove the key in, put my foot on the brake the starter won't operate. Normally I take my foot off, put it back on the pedal and then it starts just fine.
2012 F10 535d M Sport, Titanium Silver, Black Dakota Leather, Piano Black Trim, 19" 351M, Sport Automatic Transmission, Reversing Assist Camera, Powered Boot Lid, Soft Close Doors, Folding/dimming mirrors, Elec. fr seats, Surround View, Heads-up display, BMW Business Speakers, M rear spoiler, Sun protection glass, Visibility pack, Media Package Pro
03-19-2008, 05:47 AM | #13 | |
23
Rep 635
The method of creating vacuum is typical of all Diesels. A pump is used, rather than being obtained from the manifold. The method in which the vacuum resevoir is bled may well differ between manufacturers. I know from experience that BMW and VAG work in the same way. It really depends on how long the vacuum resevoir is kept primed. As soon as it is vented to atmosphere, you'll have the hard pedal feel you describe.
Try the same on a petrol car by depressing the brake several times with the engine off. The same will happen. I don't believe the brake servo is any different between the 335D and 335i, its just the way of providing vacuum to the servo which differs. The 335i is a bit of a special case here, in that it does have a vacuum pump but is only used as part of the turbo control mechanism. Quote:
03-19-2008, 07:02 AM | #14 | |
Rep 227
Thanks quattro, I understood whats happening (use the pedal pumping exercise to test the servo when purchasing 2nd hand cars ) just didn't understand why it would differ on the diesel. One more question for you (oh knowledgeable one!) why can't it keep it primed until you next start the car? Also why does the timespan differ? I can return after 4 hours or 20 hours and sometimes its hard sometimes its not! ok thats two questions!! |
03-19-2008, 04:41 PM | #15 | |
23
Rep 635
You're welcome...
The timing is something that I can't answer.. I would imagine a sensor somewhere for something tells the resevoir to vent. Its not considered good practice to keep something under pressure or vacuum unless its really necessary. Since the resevoir is primed as soon as the engine starts, I guess its considered acceptable as you won't be needing brakes before then ;-) Same happens with the fuel lines except they are primed as you open the drivers door. On the diesel, there is no reason that the vacuum couldnt be replenished at the same time since its an electric pump. Something which isnt possible with the petrol, and I suspect the root of the reason why its not done in advance - keeps control systems common between variants. Quote:
03-20-2008, 03:18 AM | #16 | |
Rep 227
03-20-2008, 03:59 AM | #17 | |
45
Rep 408
You are right that diesels need an alternate way of generating a vacuum and stroring it, but this is done mechanicaly not electricaly. If you open the bonnet on a 330d for example, look between the radiator cowling and the engine cover, on the front of the engine just infront of where the exhaust cam shaft would be and you will see the goldish coloured circular mechanical vacuum pump that opperates the vacuum system. ant. |
03-20-2008, 04:58 AM | #18 |
Rep 227
[QUOTE=and then still have the brake pressed when the engine is switched off and the brake pedal is used to push yourself out of the car once you have opened the door,
ant.[/QUOTE] See your point but not sure if I use the brake pedal to push myself out of the car!! |
03-20-2008, 05:12 AM | #19 | |
23
Rep 635
Here is the pump referred : http://www.realoem.com/bmw/showparts...72&hg=11&fg=45 |
03-20-2008, 05:33 AM | #20 | |
45
Rep 408
