ticking noise from my engine bay
03-18-2008, 09:48 AM | #1 |
22
Rep 365
Hello all, I just picked up my 335 coupe 2 weeks ago and started her this morning and left her there for about 2 min to warm up and when I came back out I heard a ticking noise coming from my engine bay at idle.. I drove to work and parked it and it was gone..i only have like 700 miles on it. Is this normal? I've been hearing a lot about wastegate problems but I've read that you hear it when you decelerate in rpms so I doubt its the wastegate
Thanks |
03-18-2008, 09:55 AM | #3 |
247
Rep 1,435
Ahh so thats what they did with my old wastegate... They gave it to you!
Nah engine uses Direct Injection.. you will hear a ticking every once and a while especially on cold starts, if you still hear it when you get where you are going and you hear it during acceleration, then you have a problem. |
03-18-2008, 09:59 AM | #4 | |
22
Rep 365
03-18-2008, 10:48 AM | #6 |
17
Rep 729
Also, it could be the transmission. I have a slight chatter at idle with my manual. When I depress the clutch, the chatter sound goes away. Took it to the dealer, they said it was coming from the tranny and it was normal since our transmissions were so "BEEFY" Lame excuse, but whatever.
I've had this sound from day 1.
RIP 2007 335i Sedan
03-18-2008, 11:34 AM | #7 |
333
Rep 4,632
yes ticking is normal and the louder ticking is also normal during cold starts, it goes away once it is warmed up. also when cold it also comes and goes.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
03-18-2008, 11:47 AM | #8 | |
55
Rep 1,690
03-19-2008, 08:12 AM | #10 | |
Rep 115
He told me to replicate the sound...I told him to come to my house about 7:30 am, otherwise the noise will be gone by the time I get to the dealership. I do hear it faintly even after it's warm. But, until I feel power loss, i'm not going to worry too much. |
03-19-2008, 09:11 AM | #11 |
Rep 80
Direct Injection System creates a ticking due to the pressures involved and the fact the injectors are, for the most part, in direct contact with the cylinder head.
The somewhat louder ticking noises on cold start are possibly more related to the valve actuators - I had this issue on my E90 330i. Once the engine warms up it "should" go away, but you will always hear the Direct Injection tick. |
03-19-2008, 10:02 AM | #12 |
23
Rep 617
does it sound like this?
http://s269.photobucket.com/albums/j...rent=00020.flv http://s269.photobucket.com/albums/j...ent=inside.flv http://s269.photobucket.com/albums/j...rent=00023.flv http://s269.photobucket.com/albums/j...rent=00022.flv http://s269.photobucket.com/albums/j...rent=00021.flv http://s269.photobucket.com/albums/j...rent=00019.flv
root@bash-it# shift -g 6 -c 335i | grep "155 MPH"
03-19-2008, 10:32 AM | #13 | |
21
Rep 455
I would go to another dealer and have them swap out your gearbox and clutch before your warenty is up. that noise your hearing is your flywheel and you could need a new throw out bearing. This noise should not be there unless you have a light weight flywheel. |
