06-02-2016, 08:38 AM | #1 |
16
Rep 46
Where to buy internals?
Does anyone know where to buy forged or some form of aftermarket internals for the N20? I've searched everywhere and swear I can't find anything.
06-02-2016, 03:41 PM | #2 |
472
Rep 577
I investigated this. I wanted a drop in set. So no additional machining. Though you would probably need to have the cylinders lightly honed to properly prep for the new rings.
I only know of ABR Houston who could do the job. Apparently the N20 is very tricky to take apart and rebuilt. VAC gave me the following numbers. PM me if you want the contact. - The Pistons and connecting rods are special order so they will take 4-6 weeks to be made. - The piston set will come with rings pins and locks besides the pistons (CP Forged Piston Set, N20, 84mm bore, 10 to 1 CR, 89.6mm stroke) it will cost $750 for the set. - The Connecting rods (144.35mm Rod) are $1120 for the set with WMC upgrade rod bolts, (they are comparable tensile strength to ARP). I later asked for a price for Pauter Rods. Pauter N20 connecting rods $980, but I'm not sure if that included the upgraded rod Bolts. High Performance Rod Bearing Set, N20 - $350 |
06-03-2016, 07:21 AM | #5 | |||
1616
Rep 3,958
It seems like a 335i/340i would be a better bet when you consider cost. |
06-03-2016, 09:45 AM | #6 |
472
Rep 577
I would expect the labor cost to be pretty high. The point of a drop in set, is that you don't have to pull the whole engine/tranny out.
That's a big time saver. Still I would expect it would be quite a big job... Draining fluids, Removing head cover, intake and exhaust manifolds, Pulling the head, dropping the oil pan, removing old pistons/rods, Lightly honing cylinders, installing new pistons/rods/big end bearings and replacing everything, plus new gaskets and fluids. I would say prob a day to get it stripped, day for the change out and a day to put everything back at the very best. I would prob estimate 30 hours to be safe. So another big number. In all with parts I bet it's a $5k ticket. Unless of course you are a BMW tech and can do it yourself. The hard part is finding someone who can do it. ABR Houston rebuilt some hydrolocked engines for insurance claims and apparently they were very tricky with many special tools needed. Anyway, with 350hp supposedly on the table without forged internals, I guess this would only be necessary if you want to get to 400. At that point I think some other questions need to be asked. Probably Hardened head bolts & Over the top fueling for starters. Also this block is open decked. So def no 2jz. |
06-05-2016, 04:06 AM | #7 |
2JZ-GTE
3072
Rep 4,022
I'm hoping 4 320 rwhp stock or bust
06-05-2016, 08:18 AM | #8 |
Rep 13
I don't see why the n20 engine can't handle 350+ hp with stock internals. it has arc wire technology for the cylinder walls and it has an offset crank. shouldn't that mean less stress on the internals??
if I were to take a stab in the dark id say the problem is in running hot(for efficiency), oiling, and tuning. possible solutions are running on the rich side with added injectors spraying e85, and accusump for the oiling. can someone help me understand this? |
06-05-2016, 09:11 AM | #9 | |
472
Rep 577
Given the Pistons and rods are supposed to be the same design as N55, I would think that the engine could get close to 100hp per cylinder. But the tune (as you correctly have identified) is critical. Running rich and with correct timing. I also probably only attempt this if you have th hot temp pack which has additional radiators for cooling in hot climates. Baffles in the sump would prob be a good idea. As would arp Rod bolts & upgraded big end bearings. My guess is 350 is easily done without the mods, but 400 would be risky for sure. |
06-05-2016, 11:25 AM | #11 | |
472
Rep 577
06-05-2016, 11:59 AM | #12 |
16
Rep 46
06-05-2016, 01:40 PM | #13 | |
472
Rep 577
If you buy aftermarket charge pipes (I got black anodized ER hot and cold side) then it's more difficult. I had to make a minor adjustment to my FMIC for a perfect fit. |
06-05-2016, 03:47 PM | #15 | |
472
Rep 577
06-05-2016, 03:51 PM | #16 |
Rep 4
I think you guys are correct in your estimates of the N20's weak points and power threshold. The N55 DME is on the verge of being OBD flash-tunable without initially being bench flashed or removed and modified. When these cars can be accurately remapped in real time using the highly capable OEM DME, we will have a much clearer idea of the N20's stock hardware limitations. With the offset crank, DI and VANOS, an internally stock N20 *should* be capable of a reliable ~350 whp on pump gas and mid 12-second e.t.'s.
06-06-2016, 08:54 AM | #17 | ||
85
Rep 253
I even bought a subbie IC spray button to put where the rear fogs would go. I will do some proper logging to see if it's worth it cause it goes through water kinda quick. you can Try it by relocating the windscreen washer nozzle, pretty easy and cheap mod |
06-06-2016, 09:10 AM | #18 | |||
472
Rep 577
It works incredibly well down here in TX. |
06-10-2016, 12:35 PM | #19 |
16
Rep 46
A little off subject but WTH it's my post. I saw on ECS tuning you can get a N20 block and pistons for a little over $2k. Makes my wonder why BMW shows like $16k for all the guys/girls that have blown theirs. I only bring it up bc the people that have blown the N20 is my sole reason for looking into getting new internals.
06-11-2016, 12:15 PM | #20 | |
1614
Rep 2,421
Drives: E30 M3 Cecotto, F85, G05, G07,
06-11-2016, 01:24 PM | #21 |
Rep 4
