06-02-2016, 06:09 AM | #1 |
370
Rep 354
Track setup queries
Thinking about to go with the following setup for a track only.
10jx18 front/rear with 260 or 265 wide slicks. Can someone tell me would there be a problem to 260or265 at the front? Also, as these will be on completely new set of wheels, would it be possible to install new TP sensors on them or they can run without them? |
06-02-2016, 03:34 PM | #2 |
BimmerPost Supporting Vendor
9587
Rep 10,878
The tire width is possible, but a 10" wide wheel is highly unlikely without custom front fenders. Our M2 has a 9.5" wide wheel, and even that fitment was relatively aggressive.
06-03-2016, 04:19 AM | #4 | |
370
Rep 354
So, my initial plan is to get a set of wheels and tires which will be mild setup, and would be compatible when I go with M performance suspension upgrade. I got some nice wheels and tires, so I would like to hear what from anyone experience which setup would be fine. 18x9.5j ET40 or ET35 Tires are Advan 250/660 slicks. If slicks wouldn't be available, I'm thinking about 255/35 all around. Any suggestion is welcome! |
06-07-2016, 08:57 PM | #8 |
41
Rep 76
David -
What offset are you planning on running up front? Stock suspension or coilover? are you thinking you'll need to roll the front inner fenders to get 10/275's to clear or will the camber give you enough space to clear the fender? |
06-08-2016, 08:36 AM | #9 | |
813
Rep 526
I plan on flattening the lip on the inside of the front fenders, but do not want to roll or pull them so that it's noticeable from the outside of the fender. We haven't decided on a final offset but it will have to be in the low-mid 20s to clear everything. The deciding factor now will be if we plan on making the wheel fit with tires that have large lip protectors (Michelin PSS, etc) or if want to just make them fit with the style of tire we plan to run (aggressive street or even R-comps) that usually don't have any sort of lip protector built in to the tire. |
06-09-2016, 08:52 AM | #10 |
813
Rep 526
Our wheels have been ordered with BC and should be here in ~3-4 weeks. We ordered a true square setup, 18x10 with the same offset all around. We will run a spacer up front to clear the caliper/coilover, this way the wheels can be rotated front to rear without any issues. We also have our Nitto NT05 275/35/18 tires sitting here waiting for their forged counterparts!
06-09-2016, 10:47 AM | #11 | |
74
Rep 174
Good luck!
2017 F87 M2 M-DCT ALPINWEISS / Oct 2016 / BMW WELT European 'Re-Delivery'
2016 F87 M2 M-DCT ALPINWEISS May 2016 / BMW WELT European Delivery (Gone) 2009 997.2 C4S PDK PCCB (DD) 1991 E30 318is Diamondschwarz/Blk (Garage Queen) |
06-09-2016, 09:25 PM | #12 | |
892
Rep 9,032
Then you should look into wheels and max performance tires, but NOT SLICKS. Slicks typically break away suddenly and if you're skills aren't ready for it, you'll crash. Max performance tires will break away more progressively. As for the coils, stick with the stock suspension for a while from skill perspective. It'll take a lot of time before you're better than the stock suspension. But if you want to drop it a little, then look for something with a linear spring rate. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-10-2016, 12:15 AM | #13 |
WTF does Stage 1 mean?
273
Rep 311
Get some 18" apex wheels and RE-71r's tires. Leave everything stock other than SS brake lines and pads until you are able to put down consistent times at the limits of the tire throughout a lapping session. Avoid slicks like the plague, that will be like being taught by nun with a baseball bat.
06-10-2016, 10:20 AM | #14 |
63
Rep 128
To Yellowflash21,
I agree with Redux reply with two small changes: - You don't need to change your brake lines on an M2. - When you go on track you should always make sure your break oil is no older than 6 months. Have fun |
07-11-2016, 03:24 PM | #15 |
813
Rep 526
We have successfully fit 18x10 275/35/18 square on our M2 with BC Coilovers and camber plates. -2.5* camber up front and -1.7* rear. Photos coming soon!
07-11-2016, 03:46 PM | #17 | |
74
Rep 174
What wheels / offsets my man?
07-15-2016, 04:14 PM | #18 | |
7906
Rep 11,785
This is what I run on my 1M. 18x 10 square. It's an excellent setup, it's terrific to be able to rotate and I can also run Bridgestone 285/30/18 as well which are far wider tread. I'll be very disappointed with the M2 if this setup doesn't work for you. |
07-20-2016, 12:56 AM | #19 |
915
Rep 3,456
Drives: Harrop E90 M3
I'm interested in the wheel offset as well since I pulled the trigger on a set of clubsports this week. Wondering if I need to run my existing Volks with 9.5 up front from my E90 to clear the spring perches, or order a set of 18x10 and square it up. Also, how's the handling with equal contact patches on all corners compared to stock?
07-20-2016, 05:30 PM | #20 |
376
Rep 668
track setup
This is my track setup
Not all 18,s fit unfortunately. Even with the correct offset. Barrel size is also critical. 18 x10 - et 35 18 x 9 - et 20 Springs are H & R sport springs Square may have been better, but i had a number of track tyres that suit these sizes better |
10-01-2016, 09:55 AM | #21 |
325
Rep 240
Greetings to the best board ever.
Newbie with Nov delivery date. As per 1st post, are TP sensors required on track setup? I have an Apex square setup that I want to have ready when she arrives. Suggestions on where to get another set of sensors? Thanks in advance |
10-01-2016, 04:03 PM | #22 | |
2274
Rep 2,523
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
M3 Adjuster7905.50 |
