M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Recommended tire pressure for track use
      06-01-2016, 12:45 PM   #1
thunderBMW
19
Drives: 2016 M2
Anyone know what the best hot tire pressures are for track use? (Maybe from the BMW driving experience ?).
Thanks
      06-01-2016, 12:54 PM   #2
Hossel19
62
Drives: M2
Typically you want to be around 38-40 hot (start around 30-32 cold)depending on the tires. Some require more heat others less, this information is usually available from the tire manufacturer.
      06-01-2016, 12:59 PM   #3
oj34
29
Drives: E82 135i
Here are some pretty good values from the german Sportauto test (translated by me, so pls. be patient):
"Instead of the recommended warm tire pressure of 2,2 bar for all wheels for Hockenheim the recommended tire pressure for the Nordschleife is 2,5 bar warm for front tires and 2,0 bar warm for rear tires"
For the non Europeans :
- Hockenheim : GP track with perfect surface
- Nordschleife : well, you should now that
- 2,0 bar ~ 29 psi
- 2,2 bar ~ 32 psi
- 2,5 bar ~ 36 psi
(german original) "Statt des für Hockenheim empfohlenen Warmluftdrucks von 2,2 bar rundum wird für die Nordschleife ein Luftdruck von 2,5 bar warm an der Vorderachse und 2,0 bar warm an der Hinterachse empfohlen."
This information is from BMW test drivers for the factory installed Michelin Pilot Super Sport, I think you want get any better source of information.
Appreciate 2
baggus0.00
      06-02-2016, 07:35 AM   #4
MilehighM3
MilehighM3's Avatar
915
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
I seemed to settle on 32-33 front and 35-36 rear when hot.
      06-02-2016, 10:40 AM   #5
thunderBMW
19
Drives: 2016 M2
- 2,0 bar ~ 29 psi
- 2,2 bar ~ 32 psi
- 2,5 bar ~ 36 psi
Thank you.
So just to be clear, I should set the front to 36 psi and rear to 29 warm - correct?
      06-02-2016, 12:50 PM   #6
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
- 2,0 bar ~ 29 psi
- 2,2 bar ~ 32 psi
- 2,5 bar ~ 36 psi
Thank you.
If you are running the Nordschleife
Otherwise it recommends 32 all around for other tracks
      06-02-2016, 01:31 PM   #7
oj34
29
Drives: E82 135i
Exactly. Not sure if you have something similar to the Nordschleife in canada?
      06-02-2016, 01:47 PM   #8
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
Hahahaha I wish!
Also curious where the OP will track, not many good options in the great white north.
      06-02-2016, 03:55 PM   #9
M3 Adjuster
Albania
7906
Hahahaha I wish!
Calabogie, Mosport, and Trois Rivere are all on my list of tracks I would like to drive in Canada
      06-02-2016, 04:27 PM   #10
Hossel19
62
Drives: M2
You should also add LCMT (Mont tremblant) 1.25 hours north of Montreal, one of the nicest tracks on the east coast. They ran few F1 races there in the early 70's I believe.
      06-04-2016, 04:20 AM   #11
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
I find it strange that the pressure on the Nurburgring is a lot lower at the rear then at the front. With my Z4M with 19" csl wheels and same supersport tyres I drive with 2.25bar front an 2.35bar rear on the ring... When tyres are hot!
      06-04-2016, 04:41 AM   #12
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
God how I hate imperial(vs metric)....
Cheers
Robin
      06-04-2016, 04:43 AM   #13
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Lower tyrepressure means more grip/traction...
So more stable rear end at Ring...
Cheers
Robin
      06-04-2016, 06:47 AM   #14
M3 Adjuster
Albania
7906
I do as well actually , I've always used a slightly lower pressure up front than on the rear on every BMW I have ever driven.
Apparently they must anticipate a ton of heat being generated at the rear tires on the Nurbugring and agree with Robin_NL it would provide more grip at the rear. Everything BMW does with this car is respectful of the rear end in an effort to keep it planted, unlike the 1M and M4. Of course they still don't trust journalists or non racers to drive a manual M2 with DCT off on the track....
      06-04-2016, 06:52 AM   #15
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
In the case of the Nordschleife they didn't want the rear end to slide like on Hockenheim Short where that setup proved to be Nr1 in laptimes (1:12.2)
So how can you make the rear end a bit more neutral in that case(NS): less pressure in the rear tyres(= more traction/grip) and more in the fronts(a tad more understeer so to speak) to get a faster laptime. And they're talking about one fast lap(or 2) on the NS. It's not like being on a trackday the whole day...
Cheers
Robin
Appreciate 2
      06-04-2016, 06:54 AM   #16
M3 Adjuster
Albania
7906
Cheers
Robin
Agree totally. We were typing at the same time!
However, a .5 bar/7 psi delta from front to rear is such a MASSIVE difference front to rear ... That's an absolutely *radical* change from even pressures all around...
And yes, I would bet those are both settings for one optimal lap in either situation , whether at hockenheim or Nordschleife. Of course to be honest , with the Michelin pilot super sports on a warm day.. That's about all one can achieve ... One hot lap.. Before they just about melt on you ... .
Looking forward to a little more time in an M2 and my 1M. On track at COTA in a few weeks ...
      06-04-2016, 07:17 AM   #17
Pyrat 2
Pyrat 2's Avatar
1418
Drives: Rapidly from A to B
I ran about 35 to 36 hot a couple weeks back and it seemed to work fine. A lower pressure might have been better but there was no greasiness at all at the pressures I ran. Warning though. After cool down I dropped to below 30. For my next session I went out and the tpms sensor turned on the stability and traction control. Also pulled back the throttle significantly. I had to attempt to heat up the tires under these conditions. I then pitted reset the tpms and turned off and restarted the car to get everything cleared. Not very much fun. They need to either disable this nonsense or disable the TPMS whenever you disable DSC and DTC. Of course this is probably against the law for them to do this - disable TPMS. So they should just not have it intervene and simply warn you that your tire pressures are low.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
Appreciate 2
      06-10-2016, 06:24 PM   #18
F87LUV
F87LUV's Avatar
3689
Drives: '16 M2, '23 GT4
2023 Porsche GT4  [5.00]
2016 BMW M2  [8.66]
Cheers
Robin
So what happens if I don't drop the pressure for a track day?
IG: Trackinheels
      06-10-2016, 07:22 PM   #19
gthal
gthal's Avatar
1903
Drives: 2018 340i xDrive
You need to chalk your tire's sidewall and adjust higher/lower to manage the contact patch if you want a good hot pressure IMO. Every car/tire combination is different. I'd use some of the recommendations here to start and go from there.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      07-21-2016, 12:55 PM   #20
IS+1
240
Drives: 2017 M2 (AW 6MT)
In my experience, dropping the pressures for track use is the single most important thing you can do to your car, to ensure safety and car control on the track. Running cold stock pressures will lead to excessively high pressures once hot (I've seen over 50 psi), which will lead to no front end grip (understeer), no rear end grip, overall twitchiness and a very unstable rear end especially under heavy braking/trailbraking. I drop my pressures to about 30 psi cold, which equates to about 38-39 psi hot. In order to get equal hot pressures front and back (if that is your goal), drop the front pressures a bit more because they will heat up more than the rears. Once you set your pressures initially and go out for a lapping session, re-check your pressures immediately afterwards, because 9/10 times they will need re-adjustment.
For reference, I track my car at Calabogie.
Appreciate 2
gthal1903.00
m2
