2008 335i 80k MILES
06-01-2016, 10:51 AM | #1 |
Rep 19
2008 335i 80k MILES
Hi guys,
1st of all i would to announce that i have horrible experience with car repairing skills etc. this is my 1st BMW and it has been a crazy ride I have bought this car with 56k miles $23,000 so far this is what i have repaired (not myself spent lots $) SPARKPLUGS Clutch + Flywheels Crankshaft HPFP INJECTORS new turbo New tires Brakes and rotors Okay so here is the reason i have created this post my car just hit 80k miles it has been running fine but im super scared of new issues can you guys Please help me out with obvious repairs i should be looking into getting for a better run with this 335i i was thinking - Power steering Fluid Flush - Coolant Fluid Flush - Transmission Fluid Flush - AC recharge Please Help guys also all this repair are very expensive if there is anything i can do on my own ( no garage or tools) please share Thanks Last edited by Silosvick; 06-01-2016 at 11:02 AM.. |
06-01-2016, 10:55 AM | #2 |
247
Rep 416
06-01-2016, 11:04 AM | #3 |
Rep 19
Thanks Abren
any idea on cost for the below, at a German auto shop - Power steering Fluid Flush - Coolant Fluid Flush - Transmission Fluid Flush - AC recharge |
06-01-2016, 12:01 PM | #4 |
122
Rep 397
Lack of mechanical abilities, cheap and BMW are like oil/water as they don't mix well together.
Looks like most of the expensive stuff has been taken care of already. You can add water pump, t-stat and coils to the list of things that are going to break soon enough. |
06-01-2016, 12:30 PM | #6 |
232
Rep 723
Water pump loves to go out on these cars. When you replace that you must do water pump and t-stat (thermostat) together. Coils (ignition coils) and plugs (spark plugs) are regular maintenance like oil change (at 7K to keep the car happy). Not too expensive. General consensus is coils @ every 50K and plugs @ 25K, if tuned. Otherwise do them once in two years. Since almost all big ticket items are taken care of, you should be fine for a long long time.
2007 335i E92 MT | MFactory LSD | Diff Brace | MHD/Wedge Tuned| BL Coils | Stg2 lpfp BoostConcepts | VRSF DPs | VRSF 7" HD FMIC | DCI | VRSF CP | BMW SSK | Billstein PSS Coilovers | M3 Control Arms | Whiteline Rear SF Inserts | SS brake lines | Z4 35is Rotors | Hawk 5.0 pads | M219s + PSS | PE Mod -SOLD
2016 M4 F82 MT |
06-01-2016, 02:19 PM | #9 |
48
Rep 134
OP, visit your local harbor freight and pick up some basic tools (1/4 and 3/8 socket sets [in metric], open wrenches, screwdrivers, jack-stands, etc). You'll be amazed at how much you can do with $100 of tools, some good internet sleuthing skills, and few hours of patience. There are step by step DIY tutorials for most of this stuff. You can do it, but not without some tools.
The only expensive thing you'll need to do what you listed above (plus things like water pump/T-stat replacement) is a low profile floor jack ($140), which will be annoying to store without a garage.
2008 335xi 6MT Coupe - Monaco Blue on Saddle Brown | fully optioned
06-01-2016, 02:43 PM | #10 | |
Maximus Decimus Meridius
1130
Rep 4,584
F30 335i Melbourne Red Metallic M-Sport Package |
06-01-2016, 07:27 PM | #11 | |
122
Rep 397
Case in point, and true story, BTW-- Daughter- I got a flat tire the other week, what should I do? Dad- Buy a replacement tire and take it to a tire shop to have it mounted on the wheel. Daughter- Wheel? Dad- The metal thing the tire was attached to. Daughter- Oh, I threw that away with the tire. True story. Love her to death, but a mechanic she's not. |
06-01-2016, 08:06 PM | #12 | |
48
Rep 134
However, I think that most people could do the simple jobs if they were willing to learn. The Daughter in your story would have known better had she googled it first. OP, if you are, mechanically speaking, an idiot, then you probably shouldn't start pulling components out of your (extremely) complex german machine. However, if you are a smart enough fellow that is willing to spend a few hours learning what you're doing and another few hours implementing it then I certainly think it's worth an effort. All of us wrenchers, DIYers and BMW enthusiasts got started somehow. None of this is to say that Muncie21 is wrong about anything he said, but if you feel up for it then try it. If you don't like it, then sell your BMW Just be willing to put in the extra time because you're a beginner. Good luck, OP
06-08-2016, 06:58 PM | #13 |
224
Rep 699
If you're not mechanically inclined, do not buy a used bmw. I've owned 4 335i's for ~50-70k miles and heres a list of what i've replaced with all the work done by me.
-Valve Cover w/ Gasket and Bolts 85k -PCV Check Valve 65k -Alternator 98k -Waterpump & Thermostat 100k -High Pressure Fuel Pump 100k -Low Pressure Fuel Pump 100k -02 Sensors 100k -Low & High Pressure Fuel Sensors 100k -Crank seal w/ pulley bolts 95k -Belt, tensioners, and pulleys 95k -Coolant reservoir, overflow line, and radiator feed and return lines 90k -Carbon Valve Blasting 100k -Both turbochargers replaced ~80k -Front upper and lower control arms replaced with M3 arms 90k -Both Vanos Solenoids 80k -Both oil cooler housing gaskets 90k -Throttle body to manifold gasket 100k -NGK 5992 Spark Plugs changed every 10k -Coil Packs changed at 85k -Front upper and lower control arms 95k -Rear main seal 100k -Clutch, flywheel, pilot bearing 100k -And a few random coolant lines I'm probably forgetting a few things, insanely enough i've never had any injectors fail (Knock on wood) and 3 out of the 4 cars had full bolt ons throughout the entire ownership. One had vargas stage 1s with meth.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
