05-28-2016, 03:19 PM | #1 |
23
Rep 130
Under bonnet trim and drainage
I did a quick search in the UK sub forum so apologies if this has been discussed before and would be grateful for a link to the thread.
Has anyone noticed there are 2-3 areas in the trim under the bonnet where water can collect and there aren’t any drainage holes? I’ve highlighted a yellow box around the area I’m talking about. Without water: I see the winderscreen wiper does have a drainage hole so any ideas if there is suppose to be a hole and what they are suppose to do? Last edited by Tux; 05-28-2016 at 03:41 PM.. |
05-28-2016, 03:34 PM | #2 |
6461
Rep 8,524
I can't see your pics. Can anyone else see them ?
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
05-28-2016, 03:39 PM | #3 |
209
Rep 542
Drives: F36 430d xDrive M Sport GC
Part of my drying process is to scoop water out of there and give it a wipe.
440i GC M Sport : Arrived 25th May 2018
Mineral Grey / Ivory White Dakota Leather / Reversing Camera / Folding/Auto Dipping Mirrors / Park Assist / Sun Protection Glass / Electric Glass Sunroof / Heated Steering Wheel / Icon Adaptive LED Headlights / 19" 704M Alloys / Digital Cockpit / Head-up Display / Wifi Hotspot / Driving Assistant / Speed Limit Display / Harmon Kardon Loudspeakers / High-Beam Assist / Enhanced Bluetooth - Wireless Charging / Online Entertainment / M Sport Brakes / Comfort Access / Extended Storage |
05-28-2016, 03:51 PM | #5 |
151
Rep 403
Yes water collects along there in my F36 as well. I usually scoop it out after a wash. I was considering creating a little drain hole myself. Not sure if that's a good idea as I don't know what's under that panel and I'm sure proper drain holes are not just a hope but have some kind of rubber piping directing excess water to road surface?
05-28-2016, 04:05 PM | #6 | |
23
Rep 130
I found it odd because there is a drainage channel below and infront of the highlighted area (left of the picture). You can see the small sediment 1 level below and for it to be so close I thought it could've been a fault. |
05-28-2016, 04:33 PM | #7 |
771
Rep 2,468
Drives: F21 M135i LCI
The same stupid design issue on my F21
Current: F21 M135i Mineral Grey and few options
Previous: F30 320i XDrive, E85 2.5i, E21 323i |
05-28-2016, 11:43 PM | #8 |
56
Rep 185
I had the same on my F36 - after some digging around it turns out that we do indeed have the actual drainage channels underneath but no holes for the water to reach them! I went through with a 6mm drill bit on a slow speed! Perfect!
On the cars you are referring too do you have a hole on the drivers side? Just not the middle and passenger side? The f36 had one hole so I added another 2 |
05-29-2016, 03:06 AM | #9 | |
23
Rep 130
Did you drill a hole straight down on both? |
05-29-2016, 03:58 AM | #10 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
There is a quality enhancement for removal of grommets. Have your cars had it done?
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
05-29-2016, 05:17 AM | #11 |
23
Rep 130
05-29-2016, 05:42 AM | #12 |
56
Rep 185
I just drilled straight through at the bottom of the dip! It is only about 3mm thick and you only need to go just through it! The drainage channels are there as it 'tested' it with a jug of water after I had done it!
05-29-2016, 10:38 AM | #13 | |
151
Rep 403
05-29-2016, 10:40 AM | #14 | |
151
Rep 403
05-29-2016, 03:21 PM | #16 |
777
Rep 1,645
Drives: 2020 Audi SQ7 & 2019 AM DB11
Location: The Democratic Peoples Republic Of South East England
There is also another water holding pool on top on my LED headlights. I'm always give the engine a little wipe over after a wash and just wicker these up.
05-29-2016, 03:51 PM | #17 |
23
Rep 130
05-29-2016, 04:00 PM | #18 |
777
Rep 1,645
05-29-2016, 04:26 PM | #19 |
Beemer Heaven
462
Rep 2,941
It depends on the age of your cars, our 2012 car had to have it done, the 2014 already had the enhancement at build.
Scott
05-29-2016, 05:41 PM | #20 |
105
Rep 251
You may have seen and checked this place, too - but just in case....
There is a deep well in hte engine bay, on the driver's side where the steering column (I think) and the wiring loom come through from the cabin. This really fills up with water to the extent that I syphoned about 3 litres of water out of it before taking it to the dealer. I think this is the "enhancement" where they remove a grommet at the bottom of the cavity which lets it drain normally. After that is done they're no problem at all. |
05-30-2016, 12:59 AM | #21 | |
151
Rep 403
05-30-2016, 02:30 AM | #22 | |
Beemer Heaven
462
Rep 2,941
Scott
