05-27-2016, 08:13 AM | #1 |
Rep 28
Drives: 428iX M- SPORT
Incorrect E SYS PIN SoftToken
Please help!
When I click edit FDL it ask for PIN which im entering the same one i used when first starting the launcher but it says its incorrect |
09-07-2016, 06:39 PM | #4 |
2374
Rep 8,364
10-08-2018, 03:05 PM | #9 |
238
Rep 878
Hasnt esys timed out? Had this same problem and I had to use the date change mod that’s posted in another thread in order to get it working.
10-08-2018, 03:26 PM | #10 |
124
Rep 274
He's talking about my script in this thread:
https://f30.bimmerpost.com/forums/sh....php?t=1457494 You could try first to delete the folder "%UserProfile%\Esys" if it exists. This contains some E-sys settings that might interfere. Also, try to run E-sys without the Launcher and go to Options -> Settings and on the EST tab, clear the Soft Token EST path if anything is filled in there. Then retry running it with the Launcher. If that doesn't work and you're using the latest Launcher 2.8.2, you could try to run my script (as admin) without changing the date. This will reset the Launcher's settings as if it was installed from scratch. Cheers, ----------- Tony Twoclicks |
10-09-2018, 02:37 AM | #11 | |
588
Rep 2,302
Tokenmaster‘s Launcher Premium has timed out at 31.12.2017. But then Launcher Premium 2.8.2 was released and it worked again. |
10-09-2018, 04:16 PM | #12 |
238
Rep 878
Didn't even know about Launcher 2.8.2, just downloaded it and can confirm it works as stated above.
11-19-2018, 03:41 PM | #13 |
Rep 4
Maybe somebody can help me?
I have similar issue, plus i have E-sys launcher error "connection to E-sys Launcher failed. Restart launcher and try again" on the splash screen, after this E-sys starts and everything work fine, except FDL coding, where i receive "incorrect PIN" error. E-sys 3.27.1+launcher 2.8.0+Tonys "launcher rearm" |
11-19-2018, 11:23 PM | #14 | |
2374
Rep 8,364
11-20-2018, 01:20 AM | #15 |
Rep 4
Thanks for answering! Funny thing, that i have “secured by launcher” sign at the top of esys. I’ve tried every “solution”i found, nothing works. i guess it’s time to donate and wait
11-20-2018, 01:45 AM | #16 |
2374
Rep 8,364
Maybe error is related to rearm solution; I am not sure. Only time I get asked for PIN is when using without Launcher.
02-22-2019, 05:01 PM | #17 |
Save the manuals!
6019
Rep 6,750
Had anyone successfully gotten past the damn Soft Token error when attempting to.open FDL editor?
Mine says Secured by Token Master at the top... |
02-23-2019, 11:27 AM | #18 | |
27
Rep 67
https://f30.bimmerpost.com/forums/sh....php?t=1457494 |
02-23-2019, 11:36 AM | #19 | |
Save the manuals!
6019
Rep 6,750
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
02-10-2023, 07:35 AM | #20 |
Rep 4
02-10-2023, 07:32 PM | #21 |
2374
Rep 8,364
