05-26-2016, 09:04 PM | #1 |
1718
Rep 5,110
M2 DCT vs E90 M3 DCT - GTBoard race
Seems quite evenly matched until the end where the higher power of the E90 starts to pull a lead as the aero drag takes over from weight disadvantage for the E90
05-26-2016, 11:48 PM | #2 | |
426
Rep 346
Also I'm dying for someone with a jb4 N55 to show me a top end like this, because I keep hearing the N55B30T0 in the M2 is 'just a boosted up N55" |
05-27-2016, 07:49 AM | #4 |
426
Rep 346
It would seem the race ends when the driver runs out of testicular fortitude. From previous videos, I think there's usually a cone marking the end, but I've seen GTBoard races that are closer to games of chicken with the end of the runway.
Also it appears the E90 M3 has an engine tune and exhaust, while the M2 is stock. Even more impressive result. Last edited by ilovewagons; 05-27-2016 at 07:57 AM.. |
05-27-2016, 10:34 AM | #5 | |
657
Rep 1,749
05-27-2016, 06:35 PM | #6 |
426
Rep 346
Am I? I think that in a race that ended in what, 6th for the M3 that revs to 8.6k (typical with a stage 1 tune) the M2 that revs to 7k is going to be using the upper end of its RPM range. I don't know if you've seen many GTBoard races, but a 50 roll is pretty much a top end vs top end race. Also, I've driven an M2 at a track, it has a great top end.
05-27-2016, 08:48 PM | #7 | |
840
Rep 2,402
Umm, from the most respected tuners in the country, it is, at least from a power perspective. Same turbo, same dyno numbers maxed out on a tune. It's the same engine, get over it.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
05-27-2016, 11:21 PM | #8 |
5254
Rep 5,874
At least give the M2 credit for its beefed up internals and better cooling/exhaust. Geez.
Regarding the video, that's about the result I expected from a roll. Both very fast cars. From a dig I wouldn't be surprised to see the M2 with a slight advantage due to less weight and more torque. |
05-28-2016, 01:19 AM | #9 |
426
Rep 346
Are there N55s neck and neck with tuned S65s with stock turbo, stock internals, no meth and an ECU tune? Maybe you might be right about potential power outputs, but it's pretty early days yet. Which engine would you rather max out, the one with built internals, upgraded intake, exhaust, cooling and oil system, or the regular one?
