05-24-2016, 05:41 AM | #1 |
151
Rep 403
Pigeon Post Mortem
Lower centre m-sport grill now replaced. Part cost £36 fitting was another £100 as it was a bumper off job, bloody birds!!!!!!
put car in reverse on leaving dealer and dashboard lit up with parking sensor system "inactive" warnings. dealer was closing so I agreed to take car home. upon reaching home and manually activating system via the button near shifter it all works fine. engage reverse all fine. today used car few times, all fine error has gone away. popped car back to dealer today and they removed bumper FOC to check connections and also then dumped errors codes from car. the following codes had been logged at some point (see attached). Technician said there was no visible damage to sensor or wiring and its possible the codes were generated at point of impact as that momentarily may have "shook" sensor enough to create these. Does that sound plausible???? Now the fix is to check wiring and replace sensor but as the error has disappeared and not recurred I'm tempted to just see how it goes. seems to be working perfectly. Cost to replace sensor and wiring is £285 which i'm fine with but I don't like throwing away money needlessly especially if this is just a temporary set of codes generated at the moment some object hit the car. dealer seems to think that is right thing to do and to be fair to them they didn't try and persuade me to get it replaced just for the sake of it. thoughts? would you do same? Part of me thinks sod it just get it swapped..but then part of me thinks...stop being OCD its a sensor....see how it goes don't waste nearly £300 for nothing. |
05-24-2016, 05:46 AM | #2 |
151
Rep 403
05-24-2016, 05:52 AM | #3 |
2826
Rep 4,939
Drives: 340i MPPSK
Find it hard to believe that a pigeon going through your grille would (even momentarily) shake loose the wiring connectors to the sensors, which then magically re-seat themselves. Think the tech just didn't want to say "No idea".
Life is a state of mind |
05-24-2016, 06:02 AM | #4 | |
151
Rep 403
service advisor did say "technician has removed bumper and reconnected everything and we've had the senior technician check his work...." hmmmmmm |
05-24-2016, 06:37 AM | #6 |
653
Rep 928
If it's just a front parking sensor I would leave it and see how it goes. Have the car running and manually switch on the parking system and get someone to walk across the line of all 4 sensors just to check if they are all working correctly. I wouldn't spend £300 unless the error came back, it could easily just have been a loose connector with them removing and refitting the bumper.
05-24-2016, 07:37 AM | #7 |
2649
Rep 3,665
I wouldn't worry about it. The car does all sorts of weird stuff when wiring is disconnected and then t sort of resets itself afterwards.
This is most likely being caused because the bumper was removed and wiring disconnected/reconnected. I remember some years ago having a car remapped and after it had been on the rolling road (rear wheels only) it threw a steering error as soon as you ran it. If you took it down the road, the fault cleared within a couple of minutes. The guy who ran the rolling road knew all about it and said nothing to worry about - and he was right. Hope that helps. Rukka
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
