2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum 2 Series Active Tourer Discussions Anyone did DIY oil change?
      05-21-2016, 09:43 PM   #1
fionbank
Drives: 218i
Some people said the first oil change in 5000 miles or 10000 miles , now i am in 8000 miles
and planning to have oil change. Any DIY to change?
I dont want to back to the dealer to do it. Too far, too expensive and waste time.
Hope some one could share the experiences.
      05-21-2016, 10:01 PM   #2
overcoil
3074
Drives: M235i 6spd
Some very good threads for the 2-series M235 oil change posted with pictures, use the SEARCH function.
Do you own ramps ?
      05-23-2016, 04:29 AM   #3
Kiwi
New Zealand
145
Drives: 2015 BMW M Sports Convertible
BMW states 30,000ks for first oil change. I wouldn't believe others about changing oil early. Why would BMW try and kill their own engines by not changing oil earlier because BMW knows their engines.
      05-23-2016, 04:33 PM   #4
koston
koston's Avatar
Australia
37
Drives: M235i
Google 'Mike Miller's Old School Maintenance Schedule' it provides a detailed of guide of what/when to service prior to the newer servicing schedules that BMW implemented.
FWIW I plan to change the oil at 1,200 as it is not that expensive and fairly easy to do yourself.
      05-24-2016, 04:17 PM   #5
stealthwang
14
Drives: M235i Estoril Blue
I recently did this and it was very easy with decent tools. 17mm socket, 86mm 16 flute oil filter wrench, good oil & filter. After you've done it once its a 20 minute job no problem.
      06-10-2016, 10:59 AM   #6
fionbank
Drives: 218i
Wow....sound great! Proud of u! You have menu on hand? My menu took off by the dealer so i havent got any car info on hand. I am still google the oil filter place and the oil export hole under the car!
What oil u used? When is the next oil change time? Thank!
      06-10-2016, 11:03 AM   #7
fionbank
Drives: 218i
I tried to found out the 218i oil change video on youtube but seems no match! Pity....
      06-10-2016, 11:11 AM   #8
fionbank
Drives: 218i
Yes, i noted 30000km to change oil also, i noted it on net and i cant believe it!
      06-10-2016, 11:15 AM   #9
fionbank
Drives: 218i
Do you own ramps ?
M235 is same changing method with 218i?
I havent got the ramps, i have a jack , i need to find out the jack point in front under the car!
      06-10-2016, 11:17 AM   #10
fionbank
Drives: 218i
Did u done?
      06-15-2016, 08:46 PM   #11
koston
koston's Avatar
Australia
37
Drives: M235i
I am still waiting for delivery of the car but here are some good posts on oil changes for a M235i. It should be similar for the 218i.
http://www.2addicts.com/forums/showp...2&postcount=13
http://www.2addicts.com/forums/showp...5&postcount=48
      06-16-2016, 11:32 AM   #12
zipphreak
No_Country
454
Drives: m235xi
Oil changes are very simple, one nut and crush washer on the oil pan to drain.. Up top you have the special oil filter wrench you need to twist off the oil filter cap.
https://www.ecstuning.com/News/BMW_N..._Removal_Tool/
Pop out the old one, put in the new oil filter, change the o-ring and gasket, tighten back up.
Important step: clean up the oily mess up top and underneath.
Fill up with 7 quarts of oil! Do note the oil filler can hold the bottle upright, but be careful of foil in the bottle (remove it completely), and make sure the plastic twist seal from the bottle doesn't come off.
But your wasting your money if your changing under the 12,000 mile interval unless your rag-dolling the car on the track.
      06-21-2016, 06:50 AM   #13
fionbank
Drives: 218i
Thanks bros, i have done the oil change and air filter changed by my old father today.
Quite hard and felt tricky, my old father sighed!
I just left the last step , reset the service indicator and change the air -con filter,
Any advice? Thanks!
      03-11-2017, 04:55 PM   #14
crabu2
142
Drives: Truck and ...
Took me forever to find a post with the oil filter cap tool size... 86mm..
I've got a 230ix on order, can someone tell me where the oil filter canister/housing is located on this? My sales guy has no idea, even though he drives one because he just relies on the BMW maintenance program.
BTW, anyone know if I can use a Fumoto valve?
'20 240ix convertible
      03-13-2017, 09:36 AM   #15
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
to change the filter, the filter is on the side of the engine near the back.
The drain plug is under the car, and typically has a little door cut out of the belly pan for you to locate and drain without having to remove the belly pan.
You can order oil and filter kits on sites like https://www.ecstuning.com/ for much cheaper than BMW will charge you.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
crabu2141.50
      03-16-2017, 08:40 AM   #16
crabu2
142
Oh snap! Look how low that thing is.. No wonder I didn't see it. I wonder how hard it's going to be to get at without oil dripping everywhere.
      03-16-2017, 06:08 PM   #17
bryan_G01
bryan_G01's Avatar
1165
id say take it straight up, have a rag ready to put underneath.
www.nybmwcca.org
Current Cars:
crabu2141.50
      05-20-2017, 04:06 PM   #18
caraway81
Drives: M235i
Great to know that! It's quite an achievement on my part too when I did my oil change last year. I used the Everglide as my oil additive as I was advised to use a Moly-Graphene based oil treatment for better protection and higher mpg.
      06-06-2017, 03:03 PM   #19
Colin from Oz
Belgium
Drives: Active Tourer 218i Luxury Auto
Hello,
I was interested to read the different opinions on the oil change and comments on servicing.
It made me think about my car's service intervals. I was of the opinion (and even think at some point was told this by BMW) that the first service was at 30,000kms.
However, today, I received an automatic email reminder from the garage suggesting a minor service was now due (according to the teleservice system information they received).
My car, 218i, has now done 22,000 kms and the message on the dashboard says service due in 9000km or June 2017. So, I haven't reached the kms yet, but it seems I have met the time.
Does it really need a minor service (no oil change has been done yet)?
Any thoughts on this?
Many thanks.
      06-06-2017, 03:41 PM   #20
overcoil
3074
Drives: M235i 6spd
Originally Posted by Colin from Oz View Post
Hello,
Many thanks.
Don't question the need to take it in due to mileage. You've hit the elapsed time so take it in. By the way how much is a quart or liter of motor oil in Benelux ?
      06-07-2017, 01:13 PM   #21
crabu2
142
FYI.. I did the 1st oil chance on on a B46 230i, you just need a 27mm socket and swivel to remove the filter cap. It's a a royal PITA because there's not much room to get it out.
2addicts
