Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > ***Logic Motorsports HVI Intake System DIY Thread***
      03-14-2008, 06:09 PM   #1
Huy@Logic
Drives: J's Racing S2000
Talking ***Logic Motorsports HVI Intake System DIY Thread***
Here's a quick DIY guide for those that purchase our HVI intake system.
Tools required:
1. Rachet & 12" socket extension
2. 8mm socket
3. 10mm socket
4. T-15 torx driver
5. Flat head screw driver
Stock engine bay:
Step 1: Remove the plastic pieces (2) and center piece using 8mm the flat head screw driver.
Step 2: Remove the 3 wires from the stock air box and the air tube.
Step 3: Remove the front air snorkel with T-15 torx driver and air box clamps with flat head screw driver.
Step 4: Remove power steering reservoir bracket with 10mm socket and reinstall it using the relocation bracket.
Step 5: Install the intake and filter. Tighten down the clamps and reconnect the wires to the bracket. Reinstall the air snorkel, the 2 plastic pieces and center piece.
YOU'RE DONE!
      03-14-2008, 08:03 PM   #2
5soko
5soko's Avatar
332
Drives: M5
wow great write up. product looks well done.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      03-14-2008, 08:44 PM   #3
Max@Logic
Max@Logic's Avatar
Drives: E55 AMG
Hi George,
Remove the 3 wires and leave them there till you install the HVI and clamp everything down... Remove the ps bracket and reinstall with the relocation bracket and the provided black oxide bolts and lock nuts.
Let me know if you have any other questions. It is very simple once you do it yourself. Have a great weekend guys!! BTW All tracking numbers for yesterdays shipment have been sent!!
Best Regards,
Max-
Stock Mercedes Benz E55 AMG. 11.96@118.3mph
      03-14-2008, 09:15 PM   #4
cn555ic
cn555ic's Avatar
441
Drives: 335i
The wires are connected to the OEM airbox with rubber grommets...take those off the OEM box....Once you install the intake there are three prongs there for you to connect those rubber grommets back onto the intake to make it look neat...Look at you Logic intake, you will see off to the side a bracket with three tooth like notches, thats where the wires go...just insert the rubber pieces onto it!!The wires are hooked up on the back of the OEM airbox on the right side which is the driver side!
      03-14-2008, 09:19 PM   #5
cn555ic
cn555ic's Avatar
441
Drives: 335i
When you de-tach the air-tube just leave it detached...the Logic intake is going underneath that airtube...Reason to take it out is so the intake can go underneath it...Once everything is installed, then simply plug the tube back into its original position....
      03-14-2008, 09:28 PM   #6
Max@Logic
Max@Logic's Avatar
Drives: E55 AMG
+1
      03-14-2008, 09:32 PM   #7
cn555ic
cn555ic's Avatar
441
Drives: 335i
No the airtube is the little plastic hose that u disconnected from the front of the airbox....its not the pipes that u loosen up the clamps on...two totally different things....Just look at the pictures posted above and print it out onto paper and bring it with u into the garage!!! Its really simple...Just print the pics!!!
      03-14-2008, 09:36 PM   #8
cn555ic
cn555ic's Avatar
441
Drives: 335i
Originally Posted by Railgunner View Post
<insert lightbulb here> OK... I think I got it... When he said grommets I was thinking hole grommets so I'm thinking the wires are actually going "inside" the air cleaner box (thru round grommets). Sounds like the grommets are really some kind of wire loom type things that just hold the wires.
Yes you got it...Its those wires outside that is connected to the original airbox...the rubber grommets( fasteners) are grey...
      03-14-2008, 09:43 PM   #9
cn555ic
cn555ic's Avatar
441
Drives: 335i
OK... I had just deleted the post you answered because I thought I was wrong, but I guess I was right. I see the air tube you were talking about now.
To take off that tube, just press the two side together that have ridges on them and pull straight up, but dont' pull it too hard just enough force to disconnect it..
      03-14-2008, 09:59 PM   #10
Max@Logic
Max@Logic's Avatar
Drives: E55 AMG
Glad you figured it out George!! It is very self explanatory once you are installing the intake. The tube that leads from the brake booster plugs right back on. See the last image.
Best Regards,
Max-
      03-15-2008, 08:33 PM   #11
eurotekm3
eurotekm3's Avatar
Drives: e36 M3, Audi B5 S4 Stg.2+
So simple a caveman can do it...
Originally Posted by morerevsm3 View Post
"speed is a question of money...how fast can you afford to go?"
      03-16-2008, 02:29 AM   #12
Max@Logic
Max@Logic's Avatar
Drives: E55 AMG
Yes Indeed!!
      03-16-2008, 03:11 PM   #13
cn555ic
cn555ic's Avatar
441
Drives: 335i
You have to be the first person that I know that has fitement problems!
      03-16-2008, 04:32 PM   #14
L8Apex
L8Apex's Avatar
24
Drives: 997 turbo
Fit my e90 just fine! Thanks Max! I can definitely feel the car pull a tad harder up top. Finally, I can hear the little snails working. Happy!!
      03-16-2008, 04:51 PM   #15
Park2670
Park2670's Avatar
355
Drives: Tesla Model 3
You guys realize that the DIY pictures are from a sedan. There must be something wrong with your installation.
      03-16-2008, 05:04 PM   #16
Park2670
Park2670's Avatar
355
I dont have an intake, so I cant totally help you. But it looks like you didnt move your PS reservoir like in the DIY
      03-16-2008, 05:05 PM   #17
johnnymu
Warranty Killer
johnnymu's Avatar
Taiwan
126
Drives: Nike shoe
Do they provide you with the relocation bracket? that looks like the problem, you need to relocate to make more room.
EUROPROJEKTZ Midwest Member
08 335i Jet Black | too much to name....
      03-16-2008, 05:13 PM   #18
L8Apex
L8Apex's Avatar
24
Drives: 997 turbo
Look at the power steering bracket, it's different on my car. If their pics are from a sedan, then something has changed with the '08's and they had an '07. It could be that their's some variation in the angle of the fitting where the air tube connects that is blocking my filter. If it angles up more then you'll have more room to slide the filter onto the pipe. If the fitting angles out more, then you won't.
You need to relocate the power steering reservoir by removing the stock bracket and using the bracket supplied in the kit. BTW, my 07 has the same bracket.
Push the blow off pipe toward the motor to get more room for the filter. I had to do the same thing. It's a tight fit but works fine.
      03-16-2008, 05:14 PM   #19
johnnymu
Warranty Killer
johnnymu's Avatar
Taiwan
126
Drives: Nike shoe
Yes, I had not moved it yet when I took the 1st pic. But it was moved in the 2nd and 3rd pic else it would be where the filter is.
Can you take another picture with a zoom out view of the relocation?
      03-16-2008, 05:19 PM   #20
L8Apex
L8Apex's Avatar
24
Drives: 997 turbo
Did you do this?
      03-16-2008, 05:37 PM   #21
Park2670
Park2670's Avatar
355
The picture you just posted does NOT have the PS fluid reservoir moved. There are no air hoses in the way
      03-16-2008, 05:38 PM   #22
Park2670
Park2670's Avatar
355
It needs to look like this to get the filter to fit
