Radio head unit replacement
05-13-2016, 06:26 PM | #1 |
Rep 39
I just remove the old head unit from my e90. On the back of it there was only One pink connector. On my new radio there are two pink connectors. Also behind my radio, was a second pin connector wrapped in Velcro. Does this second connector go in this new pigtail hole?
05-13-2016, 06:27 PM | #2 |
Rep 39
They are of both the same size and shape. I assume it goes on that connector but I wanted to make sure. Also my e90 is non-nav. I picked up a new head unit to be able to receive satellite radio.
05-13-2016, 06:51 PM | #3 |
144
Rep 439
Drives: 07 E92 335 / 17 F16 X6 35i
Do you have a pic? I just got one that had two Fakra connectors. One for the antenna and one for Sirius.
@mikecentola
07 335i SG / CR - LOTS OF MODS - BUILD THREAD 17 X6 SG / LCSW - ZMM/ZCW/ZDA/ZDB/ZLP/ZPP/MPPK - H&R VTR / Vossen 22x10.5/22x12 18 Ford Raptor |
05-13-2016, 06:59 PM | #4 |
Rep 39
Ah! It is Sirius you're correct. That makes sense seeing as it was covered up too. Do you know if I have to play around with the MOST bus now? My e90 has SA693 and my BimmerTech coding kit to activate it comes tomorrow.
Also thanks for the reply, I appreciate it. |
05-13-2016, 07:01 PM | #5 |
144
Rep 439
The antenna one should be blue.
@mikecentola
05-13-2016, 07:18 PM | #7 |
Rep 39
FM and AM worked flawlessly. So I'll assume I picked the right pigtails. I matched the Adam one to the same connector on my new radio. I'm fairly confident I did it right. I hope!
