Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Dyno Results
      05-11-2016, 12:45 AM   #1
Coupes33
374
Drives: 2006 335i, 2017 Audi S3
Dyno Results
I put my car on the Mainline dyno at RealDyno Performance today to measure the power and torque output. Results were 383.5KW (514HP) and 1007.7Nm. Considering I do not have PI or 100% E85, I am very pleased with the results. It appears the old RB Turbos can still produce an acceptable amount of power and torque. Now it is time to produce some decent times at the drags.
      05-11-2016, 01:09 AM   #2
tawfeeqh
Australia
162
Drives: 2007 BMW e90 335i
Hey mate
Good results especially for a mainline dyno. Power delivery looks nice and smooth with great torque numbers. AFRs look tidy.
What PSI is it peaking at? Are you running JB4 with a backend flash?
Time to hit the drag strip again
      05-11-2016, 02:22 AM   #3
Brule
Australia
827
Drives: 2007 335i e92 6spd man
Thats higher torque then vtt gcs turbos at 30+psi.
What size is mainline roller 273 or 219?
I would take 24.6% off torque no.s, it looks like torque no.s of a 273 roller.
At 23 ish psi you are making very good power and torque.
Should be quick at the1/4
      05-11-2016, 02:41 AM   #4
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Nice results Coops .... who did your tuning??
      05-11-2016, 03:00 AM   #5
bradsm87
Australia
596
Drives: F25 LCI xDrive30d
My local mainline does the same thing. Weird. Both my last 2L turbo engines making 300kw - 800nm. My brother's 300kw 4L N/A V8 - 700nm. My 335i with 250kw - 1000nm. All unrealistically high torque.
      05-11-2016, 03:16 AM   #6
Brule
Australia
827
Really keen to see your 1/4 times.
Did it hit 27psi near 5k rpm?
No reason you wont be low low 11s or better like delatima
      05-11-2016, 03:26 AM   #7
vtl
vtl's Avatar
Australia
1495
Drives: 2008 BMW 135i MT
Haha 1007Nm at the wheels? Wildly optimistic
      05-11-2016, 03:46 AM   #8
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
Nice results
By memory you're running a cobb flash custom map by PTF also? Are you E50/E60?
      05-11-2016, 04:04 AM   #9
CashedUpBogan
281
Drives: State Transit Bus
I had to check my screen when I saw 1000Nm... then looked at dynos.. then saw comments lol
      05-11-2016, 04:09 AM   #10
titium
327
Drives: 2009 BMW 135i
that's what gearing does for you I bet I can make my stock car put down 1000Nm + (I might not have the same speed range on the x axis though)
probably a third gear pull or fourth gear isn't quite 1:1. 383kw at 6k rpm is around 600nm.
Edit: Looks like you're putting around 650Nm of torque based on power graphs - Solid result
      05-11-2016, 04:17 AM   #11
Coupes33
374
Originally Posted by tawfeeqh View Post
Hey mate
Yes, the PTF tune appears to be working quite well looking at the power curve. The AFR is a little on the lean side but not too bad. Boost pressure is reaching 26psi. I am just running Cobb with an E60 custom tune from PTF. Nothing fancy. Hopefully, I may be at the drag strip next Wednesday night, if conditions suit.
      05-11-2016, 04:27 AM   #12
Coupes33
374
Hi Brule. Not sure what size roller the dyno has but I will find out tomorrow. I agree with your assessment that the torque is too high. I was getting around 800NM of torque using the E30 Cobb Generic tune on a Dyno Dynamics dyno. This fits in the range if you reduce the 1007 by 24.6%. As I am getting 125mph at the strip, I believe the power is correct.
      05-11-2016, 04:28 AM   #13
Coupes33
374
Thanks Socks. Tune was done by PTF.
      05-11-2016, 04:35 AM   #14
tawfeeqh
Australia
162
Hey mate
I would say your AFR is tidy. If I read your chart right its staying between 12-12.5 throughout the run which is pretty good. I know some guys are running 11s but I think that's on the rich side and I don't think you going over 13 so its safe and not lean.
Okay so its flash only tune. Looking good
      05-11-2016, 04:40 AM   #15
Coupes33
374
I believe maybe 11.3s is achievable if I can get my 60' times down into the 1.6s as I did a 11.6s with a 1.9s 60'. I will also try a 2nd gear launch as I am loosing 0.14s on the 1st to 2nd gear change. It is interesting when I compare my previous G6E turbo power/weight ratio with my Beemer. The G6ET put out 430rwkw and weighed 1,900kg (P/W = 0.23) while the Beemer puts out 383.5rwkw and weighs 1,600kg (P/W = 0.24). The G6ET did a 11.08s @ 126mph. Yes the graph of the Manifold Pressure shows 26-27psi at around 5,000rpm.
      05-11-2016, 04:41 AM   #16
_ink
Jedi samurai ninja turtle
_ink's Avatar
Australia
619
Drives: X3 M40i 2018
2018 X3 M40i  [0.00]
awesome number coupes!!
      05-11-2016, 04:42 AM   #17
Coupes33
374
I agree the torque number is not correct maybe due to the roller diameter as Brule has pointed out.
      05-11-2016, 04:46 AM   #18
Coupes33
374
Originally Posted by DR-JEKL View Post
Nice results
Yes Shane you are correct with the tune and I am running E60 with TBI.
      05-11-2016, 05:04 AM   #19
Coupes33
374
I have datalogs taken while doing runs at the drags which show peaks of 830Nm of torque through the gears. That is obviously at the engine not the wheels. I have a Dyno Dynamic dyno result showing 700Nm at the wheels. So your 650Nm is in the range. That is around where it should be.
      05-11-2016, 05:27 AM   #20
bmwheath
11 second stock turbo club. 11.6@120mph
bmwheath's Avatar
115
Drives: 2007 335i
Great numbers mate, car seems to be dialed in pretty well on the dyno. Just need to get it down the track quicker now! Nothing wrong with old style Rb's, as long as they dont smoke then happy days.
When i finally get around to soughting my car car out we should go for a run at willowbank, the weather is cooling right down at night now!! : )
JB4 ISO - 3" Catless Downpipes - RB Inlets to be fitted - BMS DCI - VRSF 7" intercooler - Charge pipe & Raceport BOV - BMW PE exhaust - Stage 2 fuel pump - BMS E85 Flash/ E50 mix, running map7 - NGK Plugs - BMS Catchcan - RB pcv valve - Quaife LSD - 19'' Beyern wheels - Msport suspension - M3 rep sideskirts - Aero front lip - Lux V5's - Mid kick rear spoiler - Dark tint - Msport steering wheel with M3 paddles & trim
      05-11-2016, 05:37 AM   #21
CashedUpBogan
281
Way to go shattering the poor guys idea of habing a 1000Nm car!! Do younthink I'm pushing 2000Nm yet, Joseph?
      05-11-2016, 05:39 AM   #22
titium
327
most definitely in first gear
