Car went into 1st gear but didn't move?
03-13-2008, 05:32 PM | #1 |
27
Rep 184
On my way home from work, I approached a 90 degree turn and tried to put the car in 1st gear at around 20ish mph. The clutch was floored, but the car refused to go into 1st. I tried 1st gear couple of times while the clutch was still depressed, released the clutch and depressed it again, tried second gear once, but it did not go into either one of those gears. Finally, I made the turn while in neutral, and the car is now probably going 10mph or less. I pressed the clutch again, and if I remember correctly, it went into first gear without any problems, but it was like being in neutral. I assumed I was in first and pressed the gas, but the engine reved to 4500rpm and the car didn't go anywhere. I put it in neutral and back into first, and same results. Now I'm panicing because the guy behind me is honking at me because I'm completely stopped. I put the car in reverse, then back to 1st, and this time it worked like nothing ever happened. So, WTF happened when the car was actually in 1st, but did not move?
I have experienced problems going into 1st gear ONLY when I'm driving more aggressively, and I know the CDV mod may fix that issue, but this was a first for me.
2007 335i Coupe
Black Sapphire Metallic | Coral Red | Gray Poplar Wood Trim | Sports Package | Premium Package Last edited by BeAmW335i; 03-13-2008 at 06:31 PM.. |
03-13-2008, 05:37 PM | #2 | |
218
Rep 4,726
03-13-2008, 05:42 PM | #3 |
RJE 335xi E90 Monaco Blue/Lemon, MB C350 White/Blk
12
Rep 149
+1, I'd never go back to 1st gear unless I'm almost 0 speed or full stop. 2nd gear can handle that low speed. It's either a safety feature that's why it didn't go 1st gear or it did not engage the gear properly. Sometimes pumping the clutch helps.
My steptronic auto starts actually at 2nd gear from a full stop most of the time. Only when I engage 1st from full stop that it goes to 1st, at least from what I observed so far. Go get it check though, making sure you didn't break anything. |
03-13-2008, 05:42 PM | #4 | |
Modder Raider
753
Rep 8,633
Drives: M3
Yah man, you should never put the car in first when going that fast.
I actually never ever put the car in first if the car is even rolling a bit. Why are you trying to put it in first anyway at 20-25 mph?? Quote:
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
03-13-2008, 06:00 PM | #5 |
27
Rep 184
Actually, it's my second manual car, but I did not know that you are not supposed to put car in 1st, if the car is actually moving. Mr. 5, I probably was not going 25mph, but it was probably around ~15. It was just an estimate...the whole thing happened and lasted few seconds. I don't think that anything is broke, but I will go for a drive tonight and make sure everything is good. Thanks for the replies.
03-13-2008, 06:03 PM | #6 |
247
Rep 1,435
Yeah man that is a good way to do some serious damage to your car. You will likely rev to almost 6k at 20-25. I know people who use it to slow their car down at a red light and it always turns my stomach hearing it. Especially coming around a slow turn at 20-25 you are at 1500-2500 rpms in 2nd.. this car has the low end torque to accelerate after the turn.
03-13-2008, 06:11 PM | #7 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
You live, you learn. Just drop it into 2nd gear next time.
I once drove in an EVO IX with a kid who had no idea how to properly drive his car, and he had a bad habit of trying to revmatch 1st gear downshifts when he was doing ~15mph... I just looked at the kid like he was retarded while I was suffering from whiplash and listening to his drivetrain crying.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
03-13-2008, 06:32 PM | #8 |
Modder Raider
753
Rep 8,633
Drives: M3
Every once and a while when I'm feeling balsy, I'll rev match and double clutch into first gear while at a fast roll. This is usually done when I'm making a U turn and traffic is coming.
This usually means that I should have just waited for the traffic to go by.
03-13-2008, 06:48 PM | #10 |
27
Rep 184
No, believe me I wouldn't do that. Whatever speed I was truely at, if 1st gear would have engaged, it would have been somewhere around 3500 rpm. I was planning on going into first gear at say 20mph (don't quote me on that), shift into 1st and hold the clutch until I get to the turn, using the breaks to slow down, so right after the turn I could be in first gear. I know it's probably not the right way to do it. I was not looking at the speedo, and was just estimating the 20-25mph speed earlier. Live and learn...I guess. I'm going to go for a drive and report back. Talk about a crappy feeling!
2007 335i Coupe
Black Sapphire Metallic | Coral Red | Gray Poplar Wood Trim | Sports Package | Premium Package |
03-13-2008, 07:12 PM | #11 |
27
Rep 184
Ok, back from the drive. Everything seems to be fine. No noise, problems, or issues with up or down-shifting. Hopefully no damage was done, at least it doesn't seem like it. Just for the record, at 20mph, 1st gear RPM's are at 3100. NO, I did not downshift to 1st at 20mph to check the RPM's!! It was from a rolling start, okay.
Again, thanks for the replies. Time to go learn about synchros.
2007 335i Coupe
03-14-2008, 09:32 AM | #13 |
2753
Rep 4,445
funny!
03-14-2008, 01:22 PM | #14 |
218
Rep 4,726
HA putting it in first is not the ballsy thing, doing a U turn in first is! I slide around when I'm in second.
03-14-2008, 02:42 PM | #15 | |
Modder Raider
753
Rep 8,633
Drives: M3
Ya know... -You need to flip a Btch up ahead -It's clear to do so, but you see traffic apporaching quickly -You are currently driving at aprox 40 mph. -Pull into the left hand turn lane -BRAKES -Traffic is getting closer -Push in the clutch -Start making the turn -Let out the clutch -rev match to first gear -push in the clutch -Throw in first -accelerate and get far in front fo the traffic. Again, it's safer to just wait for the traffic to clear, but it's fun to do every once and a while.
03-14-2008, 02:44 PM | #16 | |
218
Rep 4,726
Right I know how to double cutch, I'm talking about you taking it in first. Whenever I make a U turn I shift ASAP into second for it, otherwise you're going for a ride.
03-14-2008, 05:42 PM | #17 | |
Modder Raider
753
Rep 8,633
Drives: M3
I was just letting others try to visualize what I was talking about. Double clutching is the only way I would ever go into first.
03-14-2008, 05:56 PM | #18 | |
13
Rep 610
My friend, it's not that you really shouldn't, but why would you? There is no need to put you car in first gear unless stopped or rolling to a stop. Since there is no reason and doing so, is a big no-no, BMW made safeguards to prevent it. Half the time I don't even use first gear and just start from a stop in second gear. Chances are, if your car is moving 2mph-25mph, 2 gear is perfect to downshift into. |
03-14-2008, 06:57 PM | #19 |
27
Rep 184
Like others have mentioned, I was just trying to have some fun by kicking the tail out a bit during the turn, but things didn't turn out right. Maybe first gear never engaged at all, that's why it felt like I was in neutral. I've been driving around all day and no problems at all. Good learning experience and learned something new!
2007 335i Coupe
