TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Caliper adapter fabricator in Sydney
      05-07-2016, 08:40 AM   #1
WatashiEd
WatashiEd's Avatar
Australia
29
Drives: 2015 F82 M4 DCT
Hi guys, got a set of Brembo BM5 6-piston front 4-piston rear caliper with 380mm front rotors and 350mm rear rotors off a cayenne S that I am planning on fitting to my the e90 but will need some holes on the rotors to be re-drilled to the correct PCD and mod on the caliper adapter to make it fit, tried to search around the forum but couldn't find anything.
Does anyone know where would be a good place to visit in Sydney for this job for good quality that wouldn't cost an arm and leg?
Sapphire Black M4 | iPE - Valvetronic exhaust | VRSF 3″ catless dp | Bootmod 3 Stage 2 | OEM LED alcantara steering wheel | OEM M4 GTS CF hood | Vorsteiner GT wing | M Performance CF splitter | Vorsteiner CF front lip | M Performance CF side skirt extension | 3D CF diffuser | OEM CF mirror cap | H&R lower spring | Rays Engineering TE37 Ultra Bronze 20x10F 20x11R
      05-07-2016, 11:41 AM   #2
EB89
EB89's Avatar
Australia
541
Drives: 2011 335i e92 DCT
Nice looking brakes, good luck with fitting them
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP /
      05-07-2016, 04:59 PM   #3
WatashiEd
WatashiEd's Avatar
Australia
29
Thanks Elliott!!
Gonna rebuild the seals, clean the pistons and repaint them before going in, any suggestion on what color to paint?? My car is red btw
      05-07-2016, 08:04 PM   #4
EB89
EB89's Avatar
Australia
541
Originally Posted by EdDie_TurboN52 View Post
Thanks Elliott!!
Gonna build the seals, clean the pistons and repaint them before going in, any suggestion on what color to paint?? My car is red btw
If I owned them I would make them orange but that's my fav colour haha, on a red car.... Depends on your wheel colour I think.
Gloss black, bright blue, I'm not too sure, what were you thinking?
      05-07-2016, 09:09 PM   #5
NeT335
NeT335's Avatar
Albania
157
Drives: e92 335i M-Sport
Either red or yellow on your car. Or gold
      05-07-2016, 09:14 PM   #6
vtl
vtl's Avatar
Australia
1495
Drives: 2008 BMW 135i MT
Stock rear handbrake won't fit the new discs either
      05-07-2016, 10:00 PM   #7
CashedUpBogan
281
Drives: State Transit Bus
kind of overkill for your N52 lol
I can sell you my 335i brakes for 500 bucks if the job ends up being too hard (expensive)
      05-07-2016, 10:15 PM   #8
Trev88
Australia
182
Drives: 320d e90 LCI
Go with m sport blue! Haha looks awesome! How much did that cost you?
      05-08-2016, 01:38 AM   #9
EB89
EB89's Avatar
Australia
541
Get some vinyls stickers for them "BMW" and clear coat over the top.https://www.ebay.com.au/ulk/itm/262048818646
      05-08-2016, 05:25 AM   #10
dane083
19
Drives: 2011 135i
These guys made my adapters when i had porsche brakes on my E46
http://www.rallyroad.net
      05-08-2016, 06:12 AM   #11
WatashiEd
WatashiEd's Avatar
Australia
29
I thought about Red and Orange too, but a bit too close colour to the body. Blue is sooooo cool but doesn't seem to match Red body, think I might go with Gold!!
      05-08-2016, 06:13 AM   #12
WatashiEd
WatashiEd's Avatar
Australia
29
Why's that Vince??
      05-08-2016, 06:17 AM   #13
vtl
vtl's Avatar
Australia
1495
Why's that Vince??
Rear hand brake on a BMW is a drum brake that fits on the inside of the rear disc brake. If you are fitting a completely different disc then the diameter and offset will be different, requiring a new hand brake assembly.
      05-08-2016, 06:18 AM   #14
WatashiEd
WatashiEd's Avatar
Australia
29
I am doing it up with N55 kit on GTX35 single turbo, will likely hit 350hp at 11psi at safe tune, going the same path as Jayson from Jamsco Auto in Florida, but I am actually an auditor, so work is very demanding, that's why everything is happening slowly when I have time that do not need to work in night for work-related stuff....
http://www.e90post.com/forums/showthread.php?t=1223874
      05-08-2016, 06:19 AM   #15
WatashiEd
WatashiEd's Avatar
Australia
29
I thought about that!! But bugger my body is red....
      05-08-2016, 06:21 AM   #16
WatashiEd
WatashiEd's Avatar
Australia
29
OMG their price is very competitive Dane!! Seems like I can get both end adapters done up within $500!! What about re-drilling holes to 5x120 PCD, how much did it set you back?
      05-08-2016, 06:24 AM   #17
WatashiEd
WatashiEd's Avatar
Australia
29
Forgot to mention, I got it cheap, $2k for the whole set including calipers, rotors, braided lines, DS2500 pads, winning
      05-08-2016, 06:28 AM   #18
Trev88
Australia
182
Wow that's a steal!!
      05-08-2016, 06:30 AM   #19
WatashiEd
WatashiEd's Avatar
Australia
29
Ohhhh F.... thought it was a matter of fabricating the calipers adapters, correct PCD and center bore that's it... Cause I am running 19" 220m, should have enough clearance both both rotors...
So what handbrake will needed to be fitted in for the job Vince??
      05-08-2016, 06:30 AM   #20
Trev88
Australia
182
Thought it would make the look more sleek! Haha not too flashy! But if you're going flashy go Yellow or Gold!
      05-08-2016, 06:32 AM   #21
WatashiEd
WatashiEd's Avatar
Australia
29
Yea I know, in pretty good condition too, except the funny green color, can't complaint actually hehehehe
      05-08-2016, 06:33 AM   #22
Trev88
Australia
182
Hey ed! Did u just buy my cf spoiler?
