How solid are these N54 engines? Long term with mods?
05-05-2016, 09:01 PM | #1 |
g35x
105
Rep 630
Alright well I'm looking for people with high miles running good amounts of boost to the car. I am almost at 70k now I use about a quart of oil every 4000-5000 miles but I am not that easy on my car. I bought my car with 55k on it and did mods right off the bat. I am not scared of transmissions turbos differentials and other things. What I worry about is engine failure its the only thing I do not want to deal with... talking spinning rod bearings head gaskets and things of that nature is what fears me. Anything else I can tackle pretty much my warranty goes till I think 102k or something. I run a E85 backend flash with some mods FMIC Chargepipe DCI JB4 etc running E55 on Map 7 (almost 20 psi). I want to keep this car until 200k if possible but I am all modded up not sure longevity of these N54 motors. I know how much of a pain the car can be with fuel pumps going injectors coils all that and I keep up with all my fluid changes. Is it possible to hit 200k on these engines with power and a enthusiast driving nature?
05-06-2016, 12:22 AM | #2 |
312
Rep 766
I hope it's possible! I heard of some going up to 250-350k, but I am not sure if they were modded or not TBH. I am sure if you take really good care of preventative maintenance & have a list from A-Z of what needs to get done every year or 2, our N54s should last at least that long. Maybe even 400-500k!?:O Time will tell.
05-06-2016, 12:32 AM | #3 | |
2896
Rep 3,728
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
05-06-2016, 05:17 AM | #4 |
g35x
105
Rep 630
05-06-2016, 06:47 AM | #5 |
2341
Rep 3,544
Other than just the common regular every day stuff such ass...
injectors ignition coils valve cover gasket valve cover cracking pcv system clogging up fuel pump failure water pump failure oil filter housing gasket radiator cracking mechatronic sleeve leaking turbo waste gates rattling oil pan gasket leaking HVAC fan rusting and making noise radio display pixels fading ...car is pretty solid and should take you well into the 300,000km (may have missed a few items up top but you get the point. I did see two threads about spun rod bearings) |
05-06-2016, 09:43 AM | #6 |
228
Rep 1,046
Part of the question at hand is
05-06-2016, 09:47 AM | #7 |
2033
Rep 8,339
I've got 226k. Had it running 17psi it's whole life with no problems that weren't common or more frequent than bone stock cars. I use the power continuously and feel it should have come this way from the factory but BMW didn't want to kill their M3 sales so they put a granny tune on it to make it the mid power option.
I did just blow the motor but that was in testing running a new setup with upgraded everything, about 30 psi boost, and an improperly tuned fuel rail. It dumped gas into the cylinders at full bore and detonated it under pressure blowing the rings. I'm putting in a 52k block now with the correct tune and same setup and plan on going another 200k as a dd with 650-700 hp. Dyno is early next week. |
gster10962.50 |
05-06-2016, 09:49 AM | #8 |
Touring cars rock
351
Rep 907
Liqui-Moly & their Ceratec are both a major win in the bearing wear and engine life department.
We had used other oils in the race engines and shifted to this a while back and bearing wear was INCREDIBLY good with this combination on the endurance motors. Note that oil change frequency is also a factor as the filter can only do so much. |
05-06-2016, 10:26 AM | #9 |
352
Rep 2,050
It all comes down to preventative maintenance and pure luck. You don't care about transmission or turbos going out? Both of those cost as much as the motor lol
Not sure why you are loosing a quart of oil. Did you ever check for a valve cover gasket or oil filter housing gasket leak? Just cuz there is no leak on the floor doesn't mean shit
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
05-06-2016, 10:28 AM | #10 | |
352
Rep 2,050
'10 e92 N54
05-06-2016, 11:03 AM | #11 |
Maximus Decimus Meridius
1130
Rep 4,584
F30 335i Melbourne Red Metallic M-Sport Package |
05-06-2016, 11:30 AM | #12 | |
2033
Rep 8,339
05-06-2016, 02:45 PM | #13 |
BimmerPost Supporting Vendor
24322
Rep 191,063
120k miles here
Have been running 20 psi boost for 2 years ... Ran ~22 psi for a while as well
05-06-2016, 02:48 PM | #14 |
2033
Rep 8,339
05-06-2016, 02:50 PM | #15 |
24322
Rep 191,063
05-06-2016, 08:44 PM | #16 |
28
Rep 78
At 155,000 on my 335i. Did an oil analysis and the wear metals were low on a 10,000 miles interval. Like pretty much every BMW, the engines are pretty solid. The only thing that wears is the owner's patience as everything connected to the engine fails. But that's pretty much any car these days.
05-07-2016, 06:01 AM | #17 | |
g35x
105
Rep 630
Its easier and cheaper to replace a transmission and turbos vs these motors the price on the motor is like hella expensive on these cars used. I was told 1 qt is normal for oil in 4k-5k. Might have the OFGH leaking I think see minor seepage in that area nothing shows under the belly pan or on the ground and I just had it off to do my FMIC. |
05-07-2016, 06:18 PM | #19 |
g35x
105
Rep 630
05-07-2016, 06:26 PM | #20 |
428
Rep 2,136
150k miles on mine. I bought it with 65k miles and tuned it at 70k. Running FBO 17psi and 20psi sometimes on e70 mix.
No major problems, just the normal stuff for n54s (injectors, coils...) I replaced the water pump at 140k miles as a preventative maintenance, it had never been replaced... |
05-07-2016, 08:30 PM | #21 | |
19
Rep 128
05-08-2016, 12:13 PM | #22 |
Touring cars rock
351
Rep 907
My S4 had twin BW K04's pushing 23# tapering to 19 and I had 250,000 miles on it when I rebuilt the turbos with new CHRA's and only then due to a filter failure which allowed a small bit of grit to get into the intake and ruin a blade on one turbo. They were still tight in terms of oil, BUT I was maniacal about getting the oil temp up to operating before putting the car into boost, and I had an after run pump on the coolant to help with cool down.
That car probably had 40 track weekends on it as well. I hate to even think how many sets of Hoosiers I ate with that car. Again, I ran LiquiMoly the car's entire life, changed every 3500-5000 miles depending on abuse, and was using Ceratec every third change after it came on the market. What kills turbos is abuse, and the worst kind of abuse comes from hammering them cold. Impulse control is your turbos' best friend. |
