Changed to 18' 162s (from 16' stock) - I think my front struts need changing
04-25-2016, 03:30 PM | #1 |
151
Rep 545
So I recently upgraded from stock 16' RFTs to 18' 162 style on Conti DWS all-season. Despite the lower profile tires ride quality increased, I guess RFTs were so stiff and bad in this regard.
However, I started to notice on some bad roads, from time to time, when I hit some pothole, my front struts would hit bump stops (sorry, not sure if they are called that) and my front takes the hit really hard. I checked front struts and couldn't find any leaks, they seem to work well otherwise. It's only at those deep potholes when they are not sufficient anymore. I guess 18' rims require a bit stronger shocks/struts. I was wondering if I can change just the front struts to some descent ones - BUT I want to keep same comfort as stock ones and I'm not willing to sacrifice ride comfort AND I'm not looking to lower/drop my ride. I just don't want to keep collecting hard shuttering hits with my front. What options do I have? Thank you Last edited by WhiteBeard; 04-25-2016 at 03:39 PM.. |
04-26-2016, 08:03 AM | #2 | |
287
Rep 595
But here is something I've found with the DWS on my 535i Sport... They are very soft, in regards to sidewall stiffness. That's where the smooth ride comes from. On smooth and mildly patchy roads, the DWS smother the bumps excellently. But big potholes or sharp edged cracks will compress the tire and smack the actual wheel with a nasty thump and bang, and possibly damage the wheel too, if severe enough. The stock inflation pressure on the front is not enough to prevent this occurrence. Try increasing the front tire pressure to 38psi. 32-35 is too low in front. It can feel like the suspension is bottoming out, when the tire compresses fully and is forced into the actual wheel/rim. What is your tire pressure set at? Make sure it is at a MINIMUM of 35 front, 38 rear. Free and easy to do. If you still have problems, then look at your shocks. Additionally, with higher psi, you will find that the DWS track srtraight and true through deep puddles of water in the rain. If too low, the DWS have a tendency to pull the steering wheel as the wheel rolls thru decent puddles of water and certain road contours. I hope this helps. Let me know. |
04-26-2016, 11:36 AM | #4 |
151
Rep 545
Thanks guys! The thing is car has only 38K miles, it was rarely used and I think struts are not worn out. I will check my tire pressure and will try to increase pressure to 38psi fronts. Who knows what pressure my local shop put when they changed rims/tires, I bet they put stock pressure.
If that won't help - I'll go with Koni FSD - as I've heard only good things about Koni in general. Thank you again! |
04-26-2016, 11:45 AM | #5 |
84
Rep 1,623
Drives: Alpine White 128i Cabrio
Go with FSD. They're adorable and a good replacement if you're looking to stay comfortable. Alternatively there are bilstein B4 replacement shocks available, as well as Bilstein B6(HD) shocks available to keep stock height.
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
04-26-2016, 11:56 AM | #6 |
4276
Rep 9,209
Regardless of miles I think they are due for replacement as everything has a shelf life. The struts/shock on newer BMW's are disappointingly short lived.
04-26-2016, 05:16 PM | #7 | |
151
Rep 545
Hope it will help, but if not - I'll go with Koni FSD |
04-26-2016, 07:58 PM | #8 |
4276
Rep 9,209
That logic would only work if applied when your tire pressure is too low let say 25psi when there won't be enough pressure and you will be hitting the rims aka bottoming out the tires. Running 35/38 on worn out suspension will make things worse compared to 32/35 as tires will bw more prone to bouncing as they will not absorb the bump as much.
04-26-2016, 09:21 PM | #9 | |
151
Rep 545
Any links for Koni FSD and roughly labor estimate? Thank you P.S. Just wanted to ask, is it a good time to drop the car a bit? Is coilovers what majority use for this? What $$$ I'm looking for 4 corners to drop a bit (nothing crazy, I still want to be able to ride comfortably). Do you guys think lowered pre-LCI 328xi looks better? Thank you |
04-26-2016, 11:50 PM | #10 |
287
Rep 595
04-27-2016, 08:51 AM | #11 | |
197
Rep 1,070
Working with tire pressures can make a HUGE difference. So thats worth investigating before you pull out the credit card and/or get dirty.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
04-27-2016, 06:56 PM | #12 |
151
Rep 545
04-27-2016, 08:19 PM | #13 | |
197
Rep 1,070
JWebb335xi
04-28-2016, 02:02 AM | #14 |
287
Rep 595
Ah! Great. Now that you know this works, you can play around with the pressures a bit to find the sweet spot for your car.
