M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2 at Burger (BMS)...Existing JB4 Works...But Not Great News
      04-23-2016, 06:13 AM   #1
PrematureApex
840
Drives: N55 X1, N54 135, s54 m3
Just a maxed out N55...
From Terry...
The good:
1) Car looks super awesome in person and really attracts a lot of attention on the road. DCT drives and shifts great.
2) The tuning scheme is the same as the M235 EWG. Meaning our existing F Series N55 EWG JB4 is fully compatible from a hardware perspective. Some minor M2 specific software changes will be added, of course.
3) All of the cool in dash controls we've added to the F Series JB4 are compatible. CANflap works, in dash boost gauge works, map switching works, boost by gear works, 6cyl timing logging works, and it even logs the DCT trans oil temperature.
4) The platform appears to be E85 friendly. More on that later.
The bad:
1) This is simply based on my initial few hours with the car. But from a performance perspective, it appears to be basically an N55 with a tune from the factory. It's not in the same universe as the S55 M3/M4 motor and even appears to be a step down from the B58 found in the new 340i.
2) On normal pump 91 octane fuel running its factory 15-16psi boost profile it had fairly significant timing pull and only put down 330whp. Subsequent pulls did even worse as it heated up.
3) We added an E30 mix on the dyno and the factory power jumped up nicely to the 350whp range and it was also more consistent. Even at this power level though the car had a strange behavior where it would momentarily drop boost for no apparent reason, resulting in a noticeable "hiccup" in the dyno chart. Maybe something that will be fixed via a future software update or perhaps related to the E30 itself without tuning in place for it.
4) I raised boost around 3psi just to evaluate it on the E30 mix and the result was pretty respectable power. Around 390whp. Which, is what the normal 335 F30 EWG cars make on E30 at roughly the same boost level.
Potential Tuning Gains:
E85 Mix: I expect we'll be able to get power up to around 425whp.
91 Octane: There is no power to be picked up via tuning on 91. Just the extra features via the JB4.
93 Octane: I'm hopeful with good 93 octane we can pickup at least 15-20whp and similar torque.
Bottom Line:
It's a cool little platform. But basically appears to be a more aggressively tuned M235.
From a power potential perspective, we'd have been better off with a B58.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
Appreciate 2
      04-23-2016, 07:33 AM   #2
TunedM2C
TunedM2C's Avatar
No_Country
829
Drives: 2016 LBB M2
Well I'll be on 93 and an e85 mix so I'm excited.
      04-23-2016, 07:48 AM   #3
PrematureApex
840
Yup, and again, there are reasonable priced, reliable aftermarket solutions for the turbo size...so no real worries.
$900 gets you a very nice top end. $2500 gets you 500 bhp.
FSociety3812.50
      04-23-2016, 10:29 AM   #4
BruceM
985
Drives: '17 6MT MG M2,930,Jag XKR 5.0
What are the fueling solutions for these size solutions? For example, if you go with a Pure Stage 1 or Stage 2, who makes the piggyback or flash that goes with them?
      04-23-2016, 11:11 AM   #5
PrematureApex
840
You can run stock fueling on either stage 1 or stage 2.
You can run an off the shelf JB4 (you'd want to set higher boost targets via a custom map to get the most out of it), nothing more. Or you can do a backend flash (Burger has a free one you can use) with or without a JB4 over top.
It is literally a bolt-on solution.
Easy as pie.
      04-23-2016, 11:28 AM   #6
Twix
Twix's Avatar
657
Drives: 2011 e91
I'm really hoping somebody does a direct ECU tune for this thing. I'm sick of seeing these lame piggybacks that don't offer the user the ability to tweak their own parameters.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      04-23-2016, 11:31 AM   #7
kovsky
198
Drives: M2, finally
If you have e85 gas station nearby adding 65rwhp is pretty nice. Like he mentioned in the "post" 420rwhp will be pretty easy.
If that's not enough there is always Pure.
But yes, yesterday's results were quite disappointing until e85 was tried.
      04-23-2016, 11:32 AM   #8
PrematureApex
840
Was this a serious post?
There are backend flashes for this ECU already.
And do you not know that you can set your own targets/custom map with a JB4? If anything, you cold argue the JB4 offers MORE user tuneabilty. And they certainly make MORE power than tunes. Lame I guess?
This isn't 1995. Piggybacks have come a long way, actually offer many advantages over flashes on these platforms.
You're sick of piggybacks? Based on what exactly? Your JB4 experience with a 4-cyclinder X1 is hardly indicative of what the rest of the community has been enjoying for years with the N54/55.
Perhaps a bit of research on your end is in order?
Appreciate 6
Poochie9104.50
      04-23-2016, 12:06 PM   #9
BruceM
985
Y
Well, this is great news. I clearly have lost track of technology advances over the years. My last involvement with serious tuning was a Motec M48 black box on my 930, and that was not an easy tune, to say the least. Basically had to create a new ECU from scratch. Once dialed in, it was excellent, and still is, but this is something else altogether.
Just so I understand, though, you are saying that the existing, stock ECU would provide adequate fueling under all load conditions to increase safe hp and torque with a Pure Turbo, but a JB4 or similar piggyback would allow relatively simple custom mapping to increase limits further?
And what is a "backend flash?" I certainly understand what a flash is--my Jag has a good one--but what does "backend" add?
Thank you for whatever guidance you can provide at your convenience. It helps mitigate this interminable waiting process...
      04-23-2016, 12:25 PM   #10
PrematureApex
840
I know what you mean, we ran Motecs (and much older systems) in our FSAE cars a decade or two ago.
Yup, with just the JB4, you can achieve good results with either setup.
A backend flash alters the stock ECU tune (either expands factory ranges of operation, and/or shifts control of certain parameters to the JB4 for more control). The JB4 itself is a piggy running over top of the factory tune. So a backend flash, like a traditional tune, is altering the factory tune, in one aspect of another.
More specifically, for the N55, the backend flash changes the base fuel and timing map to better match you'd want for larger turbos, so the JB4 has less work to do altering on the fuel and timing end.
Not sure where stand alone flash tunes with the N55 are.
You can read a bit here...(edit, that's for the N54...let me find it for the N55 big turbo swaps)
http://www.n54tech.com/forums/showthread.php?t=20563
But literally a google search for N55 backend flash, BMS, etc. will provide a lot of info. There's a few years of solid tuning/background out there...which is very good new.
      04-23-2016, 01:49 PM   #11
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
They already have and are working more & more.
EnzoPerformance
PrecisionTuning
MissionPerformance
Just to name a few
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      04-23-2016, 02:04 PM   #12
filet.M2c
filet.M2c's Avatar
784
Drives: M2c / mach e
M2 tuning potential
This was already posted in the turbo thread by I believe it deserves its own thread/ discussion. Credit to PrematureApex for linking it. From Terry@BMS
Hey guys,
A local customer was generous enough to come out for a few hours so we could poke around under the hood, take some logs, and do a little dyno testing with his new M2. He has around 1000 miles on the clock I believe.
Per usual I'll try to keep it brief and to the point:
The good:
The bad:
Bottom Line:
This is what I feared the most and considering we only have 91 octane fuel in AZ it is quite a let down. My n54 135i made more power than the M2 with a JB4. What are all your thoughts
      04-23-2016, 02:08 PM   #13
Adem1534
Adem1534's Avatar
2241
Drives: '16 M2
Always planned to and still will keep the engine 100% stock
Soon.
Appreciate 4
      04-23-2016, 02:28 PM   #14
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Drives: 2016 LBB M2 DCT
Do people really plan to mod their cars this quickly? I'm planning to keep the car stock, at least until until the factory warranty runs out, assuming I keep the car that long.
Appreciate 2
      04-23-2016, 02:41 PM   #15
Bluenose-2er
Bluenose-2er's Avatar
575
Drives: 2017 LBB 6MT M2
Seems to be a little self serving... he wants to sell tune kits! It is not exactly the same as the M235i N55 with a flash tune (as he claims)... so that casts some doubt on where he is getting his info.
Personally, I will keep mine stock. Not sure I need much more for a DD and don't plan to track it at this point. Others might have different plans of course... and maybe I will get jaded with the power level after a while
      04-23-2016, 02:43 PM   #16
kovsky
198
Drives: M2, finally
Originally Posted by Ex-MINI View Post
Do people really plan to mod their cars this quickly? ..
Yes, some people are not quite right in the head. Also, the JB4 setup is easy to remove and leaves no trace of any modifications.
      04-23-2016, 02:49 PM   #17
filet.M2c
filet.M2c's Avatar
784
How so? He says that there are no gains with 91 octane, which would probably hurt his sales a bit. He also says from a "performance perspective" it is the same, as in it makes the same power the the F30 335i and M235i.
Appreciate 2
      04-23-2016, 02:50 PM   #18
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Ha...yes I hear you. I've got a JB+ for my MINI...also easy to remove. But when people are talking about JB4 + an ECU tune then....
      04-23-2016, 03:49 PM   #19
Fab_R
Australia
192
Drives: BMW M2 / Audi S3 8V Sedan
Some really good positives there.
      04-23-2016, 03:53 PM   #20
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
It already has its own thread, in the correct forum?!
http://f87.bimmerpost.com/forums/sho....php?t=1253475
      04-23-2016, 04:18 PM   #21
filet.M2c
filet.M2c's Avatar
784
woops didn't see it.
      04-23-2016, 04:55 PM   #22
weyland
75
Drives: 2014 M235i
In the UK we get high quality 99 octane. I am presuming the ECU will auto adjust the timing - I wonder what this will make on 99?!
m2
