Procede vs Xede vs RD
03-11-2008, 12:31 PM | #2 |
Rep 82
Seriously? Of the hundreds of posts here, the stickeys...everything...you are going to pose this question? As you're new I'll not flame you for this - but you really just need to search or perhaps READ any one of the hundred or so posts and draw your own conclusion.
Your question is akin to asking somebody what is the best cologne to wear - it all comes down to personal preferences and what you want out of it. Peace, Dean |
03-11-2008, 12:39 PM | #3 |
Rep 280
I like Ralph Lauren.. but there are plenty of threads ..
http://www.e90post.com/forums/showth...t=Procede+Xede http://www.e90post.com/forums/showth...t=Procede+Xede
03-11-2008, 12:44 PM | #4 |
Moderator
270
Rep 4,481
03-11-2008, 04:43 PM | #6 | |
14
Rep 571
http://www.e90post.com/forums/showthread.php?t=121573 Welcome New Guy! You will get lost trying to read a million posts with a million different opinions. So here is the straight talk bro. I currently own a V2 Procede. The procede is a device that piggy backs onto the stock ECU and tricks the engine with a different signal. I bought my Procede back 10 months ago when there were not allot of options. I won't lie...the service has been a bit marginal for the guys that did all the R&D and Developed on the Maps for the Procede. Company name is Vishnu BTW...the Procede is manufactured by an Australian Company (I Think) and can be adapted to many type automobiles; it is a generic system. If you're interested in modifying your car with after market Down Pipes and Intake System then you may want to go with a Piggy Back System because a new map will eventually be developed to use with these type upgrades. However, the maps are slow coming from Vishnu and some folks are getting impatient with Vishnu because they have already upgraded there cars with all this stuff including Inner Coolers and their cars are going to Limp Mode. Limp Mode is when the N54 Engine see's a problem with fuel/air mixture or over boost or spark knock and literally detunes the motor instantly. This Limp Mode can be reset by simply turning the motor off and restarting it but you'll probably need to clear codes on the ECU with a device that plugs into the OBDII Port. This has been a pain in the butt for me and others using the Procede. Like I said, if you're looking to do a bunch of upgrades an aftermarket Piggy Back is probably the way to go. You'll also find some stuff on the JBS and SSTT units. The JBS uses an in line $10 setup of electronics that basically fools the turbos into providing more boost. It is the least expensive unit but seems to provide adequate performance for most using the device. Actually, Terry is the owner of this technology and I think he now holds the 1/4 mile record so you should take a serious look at this product. The SSTT is similar to the Procede but utilizes a different manufacturer for the Piggy Back. Like Dinan, the SSTT is conservative and provide very good performance that is safe for your car. Ok...If i had it to do over again I'd probably go with the Dinan Re-Flash. It costs more but it provides a few things. *Great Power - Less than V2 Procede and JBS *Maintains Factory Warranty *Cost $2000 plus installation costs. Maybe $2300 when done *No Limp Modes *You can install an Easy Flow Air Filter like K&N (More Power) *You can install Cat Back Exhaust (More Power) *You'll probably get your but Kicked by a Procede or JBS *No Brain Damage with Dinan (No Limp Modes) Do some more research and call the companies for more support and let them close you on the deal. The first time I got a Limp Mode it was one hour away from home and my wife and kids were with me and it happened on the expressway. You don't want to even know what my wife said and the look she gave me was scary. If you can handle this look you should go with a V2. If you don't want to take the chance go with Dinan. Dinan is safe. Do you live your life safe? |
03-11-2008, 04:46 PM | #7 |
14
Rep 571
BTW Vishnu is a good product and I don't seem to be having any problems but until they fix the overboost issue you may want to stay away or wait for a while.
Let us know who you go with and why. It would be nice to know what company is providing the best support. |
