spec 2+ or spec 3+ for hexon 600rr
04-21-2016, 05:38 PM | #1 |
163
Rep 466
My hexon 600rr turbos are on the way and i will need to updrand my stock clutch. Should i go with the spec 2+ or 3+
2007 e90 335i
pure stage 2 DD turbos, rb inlets |
04-21-2016, 06:10 PM | #2 |
72
Rep 116
I have an acquaintance running the RR550's with the Stage 2+ Spec on the DMFW. Works well and feels stock. We just did a Stage 3+ and SMFW conversion. It's too aggressive and heavy for normal street use in my opinion. The friction material is very "on/off" in its feel so it can chatter a little if you're trying to be smooth footed.
04-22-2016, 02:28 PM | #3 |
252
Rep 1,869
I have Spec 3+ Mfactory Smfw. I disagree with above. I DD 50+ miles a day city/hwy, Pedal feel is firmer than stock but not heavy by any means. By aggressive, the clutch will give you instant feedback and is precise on engagement, but this makes driving that much more enjoyable. If you know how to properly rev match, you will be perfectly fine.
Torque capacity: 545 and 671 respectively. So if you exceed 545 with your goals, then go 3+. Drivability will be the same. Flywheel: I would imagine Hexon 600rr would be putting you over 500whp, so it is recommended to go with smfw. I remember your thread on noise of this setup. I can tell you that there will be clutch rattle, and there is clutch chatter in lower rpms. That is the normal and to be expected with a lighter flywheel. I am fully catless with idle raised to 850 and rattle noise is 4/10, some days it could be quieter/louder.
07 335xi (2007-2010)
08 Legacy Spec B (08-) 09 335i (2010-) 15 X5 xdrive 35i (2015-) 17 Forester XT (2016-) |
04-22-2016, 03:28 PM | #4 |
75
Rep 407
^ this guy knows what he's talking about. I got the same clutch set up as him after test driving his car. Spec 3+ feels great, it's just very grabby, once you get used to that it's only slightly stiffer than stock.
e90 jet black on terra//pure stage 2//fuel-it stage 3 lpfp & pi w. return//motiv tuned//vrsf dps//vtt inlets & outlets//helix fmic // er w. hks bov // bms dcis // spec stage 3+ w. mfactory smfw // cdv delete // clutch stopper // kw v1 // m3 control arms // whiteline fsb // cic|combox|backup camera retrofit // m3 headliner retrofit
04-22-2016, 10:29 PM | #5 |
76
Rep 1,071
Do the 3+, 2+ is only good for stock turbos. Once u go over 550wtq the stage 2+ pressure plate warps bcuz it's weak and a POS.
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
04-23-2016, 01:14 AM | #6 |
Rep 25
Seems like everybody is just assuming OP is going to tune the hell out of his car. Would probably help if specified what his goals are too. But I'm also running the 600RR and have a spec 2+ on new Lux DMFW too and it feels very much like stock which is what I was looking for (engagement point on the clutch is a bit shorter though). So if looking for OEM feel 2+ should do it for ya
04-23-2016, 11:50 PM | #7 |
192
Rep 1,173
I went with stg2 that mounts to oem flywheel. Supposedly thats a tad less harsh. Waiting for car from the shop now. Driven on stg 2+ and did not like it. Pedal felt 150% stiffer imo. Took away from the luxury aspect for me personally
04-24-2016, 11:02 AM | #8 |
3441
Rep 79,211
If you keep the torque conservative you can do 2+ if you plan on maxing out the tune and setup 3+.
I'd say go with the 3+ as everyone always wants to turn it up! |
11-01-2016, 10:45 AM | #9 |
255
Rep 554
Drives: 2013 335is E93 6MT
Just bumping this to add that the Spec 3+ can be necessary even with stock turbos. Adding inlets and outlets put me just at the 500whp/550wtq line, and that has proved too much even for my (now late) 335is clutch. I don't want to dial it down, so the Spec 3+ is on the way . . . .
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
11-01-2016, 10:58 AM | #10 |
3441
Rep 79,211
You can get away with 2+ at 500WHP.
Around 500-550WHP the stock DMFW can become imbalanced depending on the age and abuse. A fresh DMFW can probably handle 500WHP no issue. So at 500WHP, we recommend most folks to go with a single mass flywheel. |
11-01-2016, 11:51 AM | #11 | |
255
Rep 554
I should mention I had a new IS clutch and OEM DMFW put in last year, and didn't have much more than 11K miles on it... toast. Not sure why some people want to "upgrade" to an IS clutch.
Chris@VargasTurboTech1933.00 |
11-01-2016, 06:53 PM | #12 | |
3441
Rep 79,211
As far as 3+ vs 2+. You'll likely get more mileage out of the 2+. I know guys with over 40K on that clutch. 3+ won't last as long. It has more clamping force and bite but at the cost of wear. Consider the 2+ if you don't have the necessary power for the 3+. |
11-01-2016, 10:26 PM | #13 |
62
Rep 317
I have the 2+ with OEM dmfw. I'm running a single turbo with no fueling modifications. It's good for now. Let's see how it reacts with an upgraded fuel pump, then port injection. Currently have 60k miles on it.
11-01-2016, 10:52 PM | #14 | |
3441
Rep 79,211
The 2+ was put on the map on a Single Turbo kit making 600WHP. |
11-02-2016, 05:42 AM | #15 | |
255
Rep 554
The last thing I want is to have to replace my clutch every year, but that appears to be the road I'm on now. I had the original clutch on my 335is replaced with a new IS clutch just a year ago right after going FBO (and after about 2-3 months of running a Wedge custom MHD tune when I was otherwise stock). So this will be my third clutch. Ouch. If anything, this is a wake up call for me as an MT driver -- you always see people saying "I've been running 22 psi or 500+whp on this platform since the Paleozoic era without problems" and you realize they're AT drivers.
11-02-2016, 08:06 PM | #16 | |
3441
Rep 79,211
I wish I was wrong but I'm not basing this on opinion just experience of the 100's we've sold to people in this platform. We see the 3+ guys back a lot sooner, in fact I don't think we ever had a 2+ guy need a new clutch yet. I'm not sure where you purchased but I could have turned that package around for you and sent you a 2+. As far as how soon it will go will depend on your driving habits and abuse. At the end of the day summer tires wear out sooner then an average all season eco tire. Performance brake pads wear out sooner then stock OE or Eco pads. It's the nature of gaining performance out of materials that wear. One should choose the clutch kit that falls into the torque range of their power at the end of the day. Spec is also notorious for being conservative on their torque rating. Best of luck. |
11-02-2016, 08:28 PM | #17 |
59
Rep 143
One should choose a clutch based on power & intended use. I can burn through a stage 2+ in know time at 450wtq at the track & you can have a stage 3+ for 40k miles at 650wtq if you don't beat on the car. It's all relative
11-03-2016, 06:05 AM | #18 | |
255
Rep 554
Spec has listed the torque capacity for the 2+ at 545wtq. Perhaps that is conservative, but nevertheless it's just a hair below where I'm at. Maybe or probably I'd make out, but I'd be gambling, and in any event, if I were to go single turbo in a year or so, obviously it would not suffice. We'll see.
11-03-2016, 07:14 AM | #19 |
192
Rep 1,173
I have RR600 (soon to be removed) and im running regular stage 2 spec and no issues.
Jeff@TopGearSolutions3440.50 |
11-03-2016, 11:40 AM | #20 | |
3441
Rep 79,211
Well that's for sure but regardless of that. Some clutch materials simply wear faster then others so if you had = driving habits (although impossible) one would wear out sooner then the other, that's all I was saying. |
