135i makes 279WHP and 295WTQ on a dynopack dyno
03-11-2008, 11:37 AM | #1 |
333
Rep 4,632
mwerks put there 135i spot on the dynopack dyno and got 279WHP and 295WTQ.. im not really good with dynos but doesnt this dyno make even more WHP then a dynojet? so what is the norm for this engine with wheels and tires on, 260WHP?
03-11-2008, 11:43 AM | #3 |
137
Rep 6,608
So is that more than the 335i has stock?
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
03-11-2008, 11:44 AM | #4 |
50
Rep 1,600
Drives: e90 335i
Any Dyno can read high and any Dyno can read low depending on how it is calibrated, what corrections are used, and by user error (entering the wrong gear ratio, etc). However, if all things are done correctly Dynapacks read higher since you remove the wheel and tire so you are measuring HP at the hub which generally is about half way between WHP and Crank HP.
03-11-2008, 12:20 PM | #5 |
40
Rep 660
You had your Evo dynod on all 3 wheels???? wtf?
jk I cant wait to see the 135i in person. Dosnt a 135i with a Steptronic sound very very fun! We are very lucky to have this car hit the US. It will be an instant classic. Huge HP and tight little package. |
03-11-2008, 12:27 PM | #6 |
PMOTH
Rep 38
From the results I have seen in person, same car, 4 different dynos, the dyno dynamics and mustangs read fairly similar and low. Those two are followed by the Dynapack and then the Dynojet. All things being equal and dynos being left in their factory calibrated spec, that is usually the trend. So, I essentially second what M3This said.
PS - Any dyno pull after a change made for more power is worthless without a baseline/benchmark. |
03-11-2008, 12:33 PM | #7 | |
Modder Raider
753
Rep 8,633
Drives: M3
Don't you take off the rear wheel to do a dynopack dyno? If so, I thought for sure they would read higher than the dynojets.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
03-11-2008, 12:33 PM | #8 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
03-11-2008, 12:36 PM | #9 |
103
Rep 2,626
03-11-2008, 12:38 PM | #10 | |
PMOTH
Rep 38
True. |
03-11-2008, 01:03 PM | #11 |
333
Rep 4,632
yea dynopack is with the wheels and all removed. right on the hubs.
i was always under the impression it reads higher of course since there is no wheels. just thought some of you guys would be interested. |
03-11-2008, 03:08 PM | #13 |
152
Rep 5,501
Sure it did.
2007 E92 Montego Blue 335i
03-11-2008, 03:27 PM | #14 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
I have only dyno'd my cars on a dynojet, but from what I have seen over the years you *usually* see higher #'s from a dynapack.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
03-11-2008, 03:34 PM | #15 |
Rep 280
also, the 1 series is about 200 lbs lighter (according to BMWUSA).. I don't know if that makes a difference though.. but it should only on the torque side at least.. not the horsepower side..
03-11-2008, 05:13 PM | #16 |
23
Rep 617
that's what it seems, 295wtq seems kinda high.
root@bash-it# shift -g 6 -c 335i | grep "155 MPH"
03-11-2008, 06:02 PM | #17 |
103
Rep 2,626
Makes no difference in dyno figures. Makes a noticeable difference in acceleration. It's like having a fat guy in your car, as opposed to no one in your car.
03-11-2008, 06:03 PM | #18 |
Rep 280
so the torque should increase.. not the horsepower?
03-11-2008, 06:50 PM | #20 |
313
Rep 2,576
In my experience, typically the dynapaks read the highest, then dynojet, then mustang and dyno dynamics with the last two reading very close.
Keep in mind any dyno can be calibrated to read differently from other dynos even if from the same mfr. Dyna paks typically read higher as it is not a load based dyno and the HP is measured at the hub and not the wheels. |
03-11-2008, 08:22 PM | #21 | |
296
Rep 1,515
Drives: Ever changing fleet
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
