04-20-2016, 01:26 PM | #1 |
15
Rep 127
Wheel size and spacer question..
Hi guys. Wheels and tires and not really my thing, so I'm not sure what the right answer is. I am currently looking at a set of wheels that would be 18x8 with a 40mm offset.. with 225 45 18 's all around for tires. Does this mean that they will sit in further in the wheel wells then my current stock luxury 18's? And if so what size spacer would I need to use if I want to get them to be flush?
Thanks.
2013 Bmw 335 xdrive: Imperial Blue/Saddle/Luxury/Tech/Prem/Cold/BMS Stage 1/RPI GT Exhaust
04-20-2016, 01:51 PM | #2 | |
3112
Rep 4,358
personally i'd just run the 18x8 +40, no spacers and 245/40/18 width tires to fill out the wheel wells Last edited by alohasurftoad; 04-21-2016 at 10:31 AM.. |
04-20-2016, 01:56 PM | #3 |
1863
Rep 5,140
Yes ET40 will sit in further in the wheel wells compared to OEM.
You can use 15mm front and 20mm rear spacers with 225/45-18. But I would instead (or also) use wider tires. 245/40-18 or 245/45-18 square. |
04-20-2016, 02:15 PM | #4 |
15
Rep 127
Gotcha!! Ok so the wider tire it is!! Makes sense didn't think to do that....so I think ill go with the 245 40 18's all around.. Really appreciate it guys
04-20-2016, 02:55 PM | #5 | |
15
Rep 127
And thanks !!
04-21-2016, 02:09 AM | #6 |
1863
Rep 5,140
04-21-2016, 02:04 PM | #7 |
A family of bimmers
2748
Rep 7,742
i would recommend a different offset and not need spacers. there are plenty of wheels out there that will fit better. if this is a used set and the "price is right" you'll end up spending more in spacers and lug bolts than if you just got a proper fitting wheel to start with. It i was stuck on getting an 18x8 square set, id look to make the offset in the range of 25-35.
Best option is to get an 18x8.5 et 30 or 35 and run 245s square
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
04-21-2016, 05:22 PM | #8 | |
1613
Rep 3,952
