04-19-2016, 12:24 PM | #1 |
TeQuiero
85
Rep 424
Pop goes the stock CP ... 2015 M235i N55
m235I with jb4, ~25% e85 on 91 octane.
Was on the freeway, 6th gear (6 speed manual), Throttle about 75% to pass a car when I heard a loud pop and car immediately signals drivetrain malfunction. My car didn’t go into limp mode at all, still has power. I’ll check my cp tonight but I thought my car was supposed to go into limp mode from cp blowing? |
04-19-2016, 12:36 PM | #3 |
2253
Rep 3,622
The charge pipe issue in conjunction with JB4 is not news, I'm sorry it happened though!
ER charge pipe is in your future. Don't replace it with another OEM!
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
04-19-2016, 01:41 PM | #6 | |
2077
Rep 2,641
Grab the ER Chargepipe from one of the sponsors here, they'll give ya a great deal. |
04-19-2016, 03:19 PM | #7 | |
24
Rep 167
04-19-2016, 04:02 PM | #8 |
TeQuiero
85
Rep 424
I’ll inspect further tonight but here is a pic of the cp to throttle body connection.
Doesn’t seem like there’s a crack though and everything is still> in tact ... Car runs fine, drivetrain malfunction went away a second after the popping sound, though I shift before 2k now to be safe. |
04-19-2016, 05:26 PM | #10 |
BimmerPost Supporting Vendor
24317
Rep 191,038
If everything looks good and no sign of Cp failure, check the codes on the Jb4
04-19-2016, 06:50 PM | #12 | ||
TeQuiero
85
Rep 424
Any recommendations on his to check the underside of the cp? Quote:
Did a Google of HPFP failure: long crank, engine dying at idle, CEL, all of which I don’t have |
04-19-2016, 10:44 PM | #13 | |
560
Rep 1,503
Your chargepipe looks fine in the picture and you will certainly notice a boost leak if it failed. Regardless though, I'd change it since you're running a jb4.
FBO M235i r
F80 M3 Last edited by ocN55; 04-19-2016 at 10:50 PM.. |
04-19-2016, 11:21 PM | #14 | |
TeQuiero
85
Rep 424
Did you also experience a loud but muffled "pop" sound coming from what sounded like the engine when that happened? My malfunction error came and went away immediately after the pop. Yes, no boost leak AFAIK and turbo still spools (from listening to it while driving). |
04-20-2016, 12:32 AM | #15 | ||
560
Rep 1,503
Try to scan your car for codes and see if anything comes up.
FBO M235i r
F80 M3 |
04-23-2016, 06:56 AM | #16 |
Moon Parasite
655
Rep 1,336
Since some CPs are breaking even on stock cars and you're running a tuned vehicle, I would be budgeting to get a ER CP because you're almost certainly on borrowed time with the stock one.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
04-23-2016, 10:42 AM | #18 | |
39
Rep 94
Mine popped yesterday, no limp mode, but acceleration was obviously lacking. Stock boost (only mod is a DP) and 25k miles. I could tell right away what happened. Mine came completely off of the throttle body:
'22 M240i Portimao/Cognac
(Sold) '14 335i Estoril/BK • M Sport • Prem/Tech Pkg • M Perf INTR • VMR V710FF • Shifteck DP (Sold) '95 M3 Avus/Dove • PSS9 • Vorschlag Camber Plates • 3.46 Torsen Diff • etc. Last edited by zerreissen; 04-23-2016 at 10:56 AM.. |
04-25-2016, 05:06 AM | #19 |
Moon Parasite
655
Rep 1,336
I ran my stock one on my X1 35i with a Dinan stage 2 tune for 2.5 years before it popped, but it did fail. 4 days before I had to travel for work (Murphy's law)
FSociety3812.50 |
04-25-2016, 04:53 PM | #20 | |
4921
Rep 115,999
Mike |
