04-15-2016, 04:54 AM | #1 |
*_*
806
Rep 3,160
M4 GTS KWCS settings?
Being that the GTS uses a KWCS 3 way coilover set-up, is there any literature showing the exact specs of the suspension set-up for the track they've used to get those amazing times? (alignment, damper settings, etc.)
04-15-2016, 07:54 AM | #2 |
557
Rep 762
Yes, that wil come in a book with car. Stock setting is Nurburgring record lap setting in terms of suspension. That setting is max out on frontlip and rear wing. Nurburgring is a normal road that, hence that suspension setting will be ok for street as well( except frontlip due to diffrent regulations in law i guess. they got flat modern ractrack setting also in book for us to set up. Love it:-)
05-10-2016, 10:29 AM | #3 |
417
Rep 261
Drives: M4 GTS, M3 GT4, E30 M3...
Here is some additional info I found on the suspension.
06-10-2017, 03:58 PM | #9 |
1153
Rep 1,523
They are not the same. The GTS coilovers are valved differently, different springs, different top mounts and different springs seats. Pretty much the only thing in common is that they use the same strut body.
06-10-2017, 05:33 PM | #10 |
*_*
806
Rep 3,160
It's amazing how vendors on these forums have been marketing as such lol. lies...thanks for setting that straight...never bought them anyhow...
06-10-2017, 06:27 PM | #11 | |
1153
Rep 1,523
This pic shows it pretty well, just look at that solid ball bearing top mount in the rear, and the lower spring seats in the front. |
VCP1390.00 |
06-10-2017, 07:00 PM | #12 | ||
1390
Rep 2,336
06-11-2017, 08:01 AM | #13 |
*_*
806
Rep 3,160
agreed, although I have to admit, it would be interesting to see someone to take one of the named "GTS Plus" cars created on the forums or from scratch (to try and recreate it w mods), and take it head to head on a track somewhere. Honestly, not a half bad idea for an episode on any of these shows, DRIVETRIBE should pick up the idea!
VCP1390.00 |
06-11-2017, 12:00 PM | #14 | |
1153
Rep 1,523
06-11-2017, 02:26 PM | #16 |
1390
Rep 2,336
I would say lower springs to "track" height and leave dampers alone. If you do not have too many clearance issues. The car does not feel quite right in high setting. Anyone else feel this way?
06-11-2017, 03:11 PM | #17 | |
Bored at work....
887
Rep 5,378
Yup. After we lowered it to "track" setting, it felt more planted and the steering was just that much more fluid.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
06-24-2017, 06:39 AM | #18 |
52
Rep 138
Spring rate differences:
OEM M4 GTS Triple Adjustable ClubSport Front: 400 lbs/in Rear: 685 lbs/in M4 KW Triple Adjustable ClubSport Front: 575 lbs/in front Rear: 800 lbs/in rear http://f80.bimmerpost.com/forums/sho....php?t=1323417 |
06-24-2017, 07:41 AM | #19 | |
*_*
806
Rep 3,160
