04-12-2016, 04:33 AM | #1 |
13
Rep 54
Coding out error messages lights
A friend of my recently installed aftermarket led lights in his F30. Now we found out that the wiring is not done properly. What I mean with that is when you put his light switch on. The lights come on in a different sequence than it should be. Because of that he gets every time errors that some lights are not working. But they are working. I already checked if I could change the wiring in the head light unit. But that's not possible because I can't reach the wiring due the small holes in the unit. Now I already coded for him the cold and warm check with from the lights and I coded that the lights are led. But still he gets the errors. Is their a way to code out completely the checks of the lights?
Thank you |
