3.5 bar tmap sensor vs 4 bar?
04-10-2016, 01:24 AM | #1 |
163
Rep 466
Both the 3.5 and the 4bar map sensors are the same price. Is there any benefits from one or the other? Which one should I buy? I'll never boost over 30psi and I know the 3.5 bar is good to 36psi.
2007 e90 335i
pure stage 2 DD turbos, rb inlets |
04-10-2016, 07:26 AM | #3 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
I got the 4 bar as it was half the price of the 3.5.
04-10-2016, 05:27 PM | #6 |
163
Rep 466
I believe the stock tmap sensor is a 2.5 bar so it's good to about 21psi.
2007 e90 335i
pure stage 2 DD turbos, rb inlets Last edited by Riceball777; 04-11-2016 at 04:05 AM.. |
07-14-2016, 04:14 PM | #7 |
Bob Saget
355
Rep 2,229
3000GT MR What say you? I read somewhere the N20 3.5 sensors that people were using were having issues.
In memory of Robert E. Flynn (AR)
07-15-2016, 04:56 AM | #9 |
163
Rep 466
I bought the bms 4 bar map sensor and have been useing it with no issue for the past few months now.
2007 e90 335i
07-15-2016, 07:06 AM | #11 | |
Slow.
3782
Rep 7,151
4 bar is not that expensive I have one installed.
07-15-2016, 09:51 AM | #12 |
Bob Saget
355
Rep 2,229
Cory S & pits200 What all is needed beside the 3.5 TMAP? A new o ring? Extended bolts? A harness?
07-15-2016, 09:58 AM | #14 |
305
Rep 1,163
Not a thing. New sensor comes O-ring, and you can re-use the existing screws. I modified the harness and inside the connector with a Dremel.
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
07-15-2016, 10:12 AM | #15 |
Bob Saget
355
Rep 2,229
Well shit, I can't find any info except here. Thanks. I will get the 3.5bar instead of the 4 bar. I keep hearing the 4bar may or may not have bolt issues depending on chargepipe you have.
07-15-2016, 11:47 AM | #17 |
207
Rep 602
07-15-2016, 12:11 PM | #18 |
Bob Saget
355
Rep 2,229
No. Only the 4 bar is good for 40psi. But I don't know of ANYONE running 40psi on the N54
07-15-2016, 12:40 PM | #20 |
Slow.
3782
Rep 7,151
The 4 bar from BMS is cheaper than the 3.5 and comes with 2 o rings depending on your chargepipe. I have the cpe so the black o ring fit fine. Comes with the harness you need. But get whatever one you want.
07-15-2016, 01:11 PM | #21 |
Bob Saget
355
Rep 2,229
Thanks for the info Torgus
