Oil Cooler Fan
04-07-2016, 07:07 AM | #1 |
47
Rep 292
Oil Cooler Fan
Hi,
My car has the stock oil cooler, and it looks real small for our engine. I was thinking to install fan on it, to cool it, rather spending $$$ on upgrading the oil cooler. Like this one |
04-07-2016, 11:21 AM | #3 |
379
Rep 909
You're still trying to use a cooler that's too small. The fan might (also might not) help a little, but you still need to upgrade the size of the core if you want the effect of a cooler upgrade.
04-07-2016, 12:20 PM | #4 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Oil flow volume in an engine isn't that high, so you don't need a huge oil cooler. The lower the flow, the longer the fluid stays in the cooler which gives it more time to cool down. The factory one should be sufficient for most unless you are tracking the car. Have you seen any problems with oil temps?
04-07-2016, 02:56 PM | #6 |
245
Rep 1,595
You have an oil temp gauge on the dash. I would make sure you have a problem or else you may be trying to solve a problem you don't even have.
04-07-2016, 03:47 PM | #7 |
47
Rep 292
04-08-2016, 12:38 AM | #8 |
379
Rep 909
04-08-2016, 09:18 AM | #9 |
47
Rep 292
04-08-2016, 09:25 AM | #10 |
Clean is the new cool, keep it that way.
808
Rep 1,685
A fan will actually inhibit the coolers ability to function well at speed.
I also own a Mazda RX-8 Turbo that comes with two oil coolers about the size of the cooler my 335i has and I did a bit of testing on my RX-8 with fans a couple years back and I used a nice Spal fan and it just did nothing. At idle it will drop temps a small amount but at speed temps were higher. A better/larger cooler in the way to go. I now use a large BEHR oil cooler from an S class mercedes as a secondary oil cooler on my RX-8.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
04-08-2016, 12:01 PM | #11 |
379
Rep 909
Right, so it'll make a marginal difference in traffic and zero difference at the speeds you said you were concerned about. Again, you simply need a bigger/better cooler to do what you want.
04-08-2016, 12:21 PM | #12 | |
186
Rep 927
