F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Activating Connected Drive, Live & Internet on a retrofitted NBT EVO
Studio RSR
      04-06-2016, 04:20 AM   #1
Osmansky
15
Drives: BMW 316i
Hi Peeps,
Anybody has any luck activating Connected Drive, Live & Internet on a retrofitted NBT EVO. so far hardware activation is not working as per my understanding BMW changed the activation method.
Any help would be appreciated
      04-12-2016, 05:27 AM   #2
Osmansky
15
Drives: BMW 316i
really, no single reply?? nobody has faced this issue?
      04-12-2016, 10:13 AM   #3
sandwi54
sandwi54's Avatar
538
Drives: G07, F90
Don't you need the FSC code?
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD)
      04-12-2016, 03:10 PM   #4
TePee
67
Drives: F34 LCI MY2019
NBT Evo uses a different Telematic Communication Box (ATM/TCB2) with OABR communication to the HU.
I guess you don't have it as you retrofitted your NBT Evo. Thus the mentioned features can't work.
      04-12-2016, 03:16 PM   #5
Osmansky
15
Drives: BMW 316i
What i know is that hardware activation works no more, as bmw moved tge actuvation to its servers not on the unit itself. And i also heard some progress has been made on hacking this server. I was kind of hoping that someobody already had a sloution.
Not sure if FSC codes will work with a retrofitted KIT
      04-12-2016, 03:51 PM   #6
TePee
67
Yes there is probably the problem with BMW server, you have to be white listed there as I read.
But did you read my post above? I assume that you don´t even have the communication hardware which is essential...
      04-13-2016, 03:36 AM   #7
Osmansky
15
Drives: BMW 316i
Actually i am not sure, I have it but my supplier says it does and then only problem is the server issue
      04-13-2016, 04:37 AM   #8
TePee
67
If you don't have stock NBT Evo, you can't have it!
You may have the normal TCB1, but this is not compatible with NBT Evo. NBT Evo uses ATM/TCB2 which is wired completely different (OABR Ethernet instead of USB cable).
Even if you retrofitted TCB2, such a used module can't be activated for your car, you would need a new TCB2.
      01-22-2017, 12:52 PM   #9
MachOne
Drives: BMW 330xd 2009
Hi,
Not possible you say?
Why services are active here, moreover, in a E series
      01-23-2017, 08:28 AM   #10
steve@codemybimmer
BimmerPost Supporting Vendor
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Originally Posted by MachOne View Post
Hi,
They probably installed an ATM module from a donor vehicle.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      01-23-2017, 01:58 PM   #11
TePee
67
Exactly.
      08-06-2017, 05:23 PM   #12
Cedric02
Drives: BMW E64
Connected Services
Hi,
Any updates on a possible avenue to enable Connected Services?
      08-06-2017, 08:29 PM   #13
Mashman
118
Drives: E93
Originally Posted by Cedric02 View Post
Hi,
It's possible, but as mentioned, it requires an ATM module be retrofitted. Also, you can not change the VIN on the ATM, and the VIN on the ATM MUST match the VIN on the EVO. So you need to flash the EVO to use the same VIN as the ATM, and use FSCs for that VIN on the EVO. So, because the car VIN will not match the EVO/ATM VIN, you will also need a CAN adapter.
      03-03-2020, 08:14 AM   #14
Gremlin82
Sri Lanka
Drives: BMW G11, E46, F30
Is there anyway to change the on board sim in the atm?
      03-06-2020, 01:22 PM   #15
Mashman
118
Drives: E93
It's possible, but I've never done it. Here is a thread that talks about it.
https://cartechnology.co.uk/showthread.php?tid=37323
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves....
      03-13-2020, 12:43 PM   #16
Gremlin82
Sri Lanka
Thanks buddy
      03-21-2024, 12:40 AM   #17
dogballs
dogballs's Avatar
New Zealand
62
Drives: Bmw 435d Xdrive
2018 Honda CRF1000  [0.00]
  [0.00]
The sim swap can be done. - I just did it.!
Brief summary:
2014 F32, originally with “route” business nav and tcb.
Retrofitted nbtevo, then used adaptor loom to connect new ATM, used BimmerUtility to code vin etc.
Removed eSIM from old tcb then soldered it onto new atm.
FULL functionality restored with MyBMW app, remote services etc..
      03-21-2024, 02:48 PM   #18
dogballs
dogballs's Avatar
New Zealand
62
  [0.00]
eSIM swap pics:
rlesko232.50
f30post
