Connecting multiple devices to one remote TURN ON wire? WORK IN PROGRESS!
04-02-2016, 10:20 PM | #1 |
Rep 114
Hi all,
I'm planning to install the following devices: 1) 6 disc dvd changer (power cord consists of three wires, constant power 12v-3a inline fuse attached, ACC power-3a inline fuse attached, a ground wire. 2) one rear 9" monitor (Power cords consists of 2 wires, ACC Wire has a 7a inline fuse attached and there are 2 bullet connectors at the end of wire[one for ACC and one for constant power?] and a ground wire. 3) digital tv box Power cord consists of three wires, constant power has a 3a inline fuse attached, ACC wire no inline fuse, and a ground wire. I've been giving some thoughts on fitting a 20a SPDT relay as I want the above mentioned devices to be turned on/off when the HU(stereo) is on/off. fortunately, there is one remote turn on wire from the HU(dynavin d95) and that would allow me to fit a 20a relay to be used for my multiple add on devices as a turn on source. One of my main concerns is that when fitting a 20a SPDT relay, is it necessary to fit a power distribution bloc, ie.one input and 4-6 output and is there any other stuff that I should be awared of? 20A SPDT relay wiring diagram, not sure if this is the right way? #30 output turn on source for multiple devices #85 connect to factory ground location #86 constant 12v from fuse box by using add a circuit fuse tap #87 connect remote turn on wire from HU Run the power wire off #30 from the relay to the distribution block(1 input/4output, and correct fuse rate?) I'm really confused now and hope that someone would put me in the right direction! Any suggestion/input will be greatly appreciated!
2010 E91 320D LCI ALPINE WHITE, PERFORMANCE POWER KIT, PERFORMANCE BRAKE KITS, OEM M3 MIRROR WITH POWER FOLDING OPTION, M AERO PACKAGE, PERFORMANCE FRONT BUMPER CARBON FIBER LIPS N REAR CARBON FIBER DIFFUSER, FULL CARBON FIBER INTERIOR TRIM KIT, KONI 1130 W/ H&R SPORTS SPRING,
EISENMANN RACE EXHAUST, OEM 19" WHEEL STYLE 230 & M225 Last edited by bennyyko2013; 04-27-2016 at 02:44 PM.. |
04-02-2016, 10:23 PM | #2 |
Rep 114
A wiring diagram for 20A SPDT relay
EISENMANN RACE EXHAUST, OEM 19" WHEEL STYLE 230 & M225 |
04-02-2016, 10:57 PM | #3 |
Rep 114
Pic of power cord for the rear monitor
ACC wire(red) has two bullet style connectors at the end of cable Does one connector needs to be connected to a constant 12v source and the other connector to be connected to ignition on(ACC)source?
04-13-2016, 06:31 AM | #4 |
48
Rep 313
Hello mate.
I dont know if this helps but I have one amp running from the remote turn on and also have my reverse camera relay trigger running spliced into the amp turn on wire and have had no problems so far. I dont know what would happen if i was to connect 3 for our 5 devices to the same remote turn on signal but having spliced the remote camera relay trigger wire into it I have had no problems. |
04-15-2016, 04:31 PM | #6 |
2134
Rep 3,554
you can either use a distro block or just daisy chain everything. The actual current requirement for the remote turn on in pretty much everything is very low so you can run lots of stuff off one remote turn on source.
04-27-2016, 02:46 PM | #7 |
Rep 114
Work In Progress 1
OEM Amp Bracket Needs Some TLC in order to fit the Pioneer amp properly!
04-27-2016, 02:52 PM | #8 |
Rep 114
WORK IN PROGRESS 2
Plywood wrapped with black vinyl film!
04-27-2016, 02:53 PM | #9 |
Rep 114
WOK IN PROGRESS 3
Looks good so far!
04-27-2016, 02:59 PM | #10 |
Rep 114
Work in progress 4
The bracket and the plywood still needs some TLC, as the Pioneer amp a bit large to fit in the left side of the trunk!
04-27-2016, 03:03 PM | #11 |
Rep 114
Work in progress 5
Mounting aftermarket 6 DISC DVD changer using OEM CD changer bracket Once again, more TLC needs to done in order to fit the DVD changer nicely!
04-27-2016, 03:07 PM | #12 |
Rep 114
Work in progress 6
All the hard work has paid off and looking good so far! Stay tuned for more pics and thanks for reading all of my posts!
EISENMANN RACE EXHAUST, OEM 19" WHEEL STYLE 230 & M225 Last edited by bennyyko2013; 04-27-2016 at 03:18 PM.. |
