Mmmm..turbo BBQ
03-08-2008, 02:01 PM | #1 |
54
Rep 1,677
Mmmm..turbo BBQ
So I brought the car in for the cylinder 3 misfire and they also pulled cylinder 1 misfire codes as well. They pulled out the sparkplugs and the bottom part looked like the car was running super rich and the top part looked like it was running super lean.
Guess what else my SA tells me? My front turbo is overheating to the extreme. He said when you open the hood you could almost get burned from just the fumes. The car isn't throwing any codes and runs just about normal when driven after the spark plugs had been replaced, but both my SA and the tech who drove the car @ different times after the spark plug replacement noticed the ar smells like it is burning. My SA wants to get me a new turbo but can't validate it with PUMA until a code is thrown and is trying to get the code to be thrown today and tomorrow so he can order a new turbo. Also, for an unknown reason, he tells me my car is dumping fuel onto cylinder 1 which is most likely the cause for the turbo overheating. He has no idea what is wrong as of this point and has no where to go without a code being thrown. He even said the car could work itself out and be running fine but recommended I leave the car for the weekend so that he can try and get the code to appear.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
03-08-2008, 02:17 PM | #3 | |
54
Rep 1,677
But my SA does believe my front turbo is on its way out the door .
03-08-2008, 02:39 PM | #5 |
54
Rep 1,677
Yea he's straight. Supercharged M3 with NOS, my car must be a civic to him lol.
03-08-2008, 03:50 PM | #6 | |
Moderator
133
Rep 6,775
Drives: TiAg E92 335
At least its good to hear that you have a cool SA to work with. That's a pretty rare thing to find.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
03-08-2008, 03:58 PM | #7 | |
54
Rep 1,677
03-08-2008, 03:59 PM | #8 |
54
Rep 1,677
Oh BTW, there is a TSB out on the turbos on the 335i, not by prod. date or anything, just a shitty part in general. So says my SA.
03-08-2008, 04:13 PM | #10 |
54
Rep 1,677
Yep. I guess these cars are designed for the old folks, and then they would die just past warranty, where BMW could reel the sucker back in. I guess it's all marketing, shaft the consumer after warranty and he is bound to buy from us again. I guess BMW just made the links too weak to last longer than 5000 miles .
03-08-2008, 04:49 PM | #12 |
54
Rep 1,677
It started around 4800 miles to be precise .
03-08-2008, 05:21 PM | #13 |
2753
Rep 4,445
Good luck OP. I'm at 16k now with no problems (knock on wood). These failures are getting a bit too common.
03-08-2008, 05:39 PM | #14 |
27
Rep 631
03-08-2008, 05:51 PM | #15 |
218
Rep 4,726
Great more doomsday threads.
Not sure about your SA though talking about how "he can feel it under the hood" in reference to your turbo "cooking".
03-08-2008, 06:01 PM | #16 |
54
Rep 1,677
Just stating what was said to me. I didn't take a doomsday approach, more of a 50 thou for what? attitude. He just says the car smells like it is burning when they drive it and noticed the car is dumping fuel into cylinder 1 and the turbo is overheating due to that. He says it is cooking though. Maybe he put the car on a lift after spirited driving? I don't know. I am just relaying what I am told.
03-08-2008, 06:07 PM | #17 | |
218
Rep 4,726
03-08-2008, 07:24 PM | #18 |
born to be turbocharged
24
Rep 1,347
the turbo overheats when the engine is running lean. the unburnt fuel is supposed to cool the turbo down, so I guess the overheated turbo is on the lean side of your engine, not on the rich side. I understand that turbo needs to be replaced, hopefully just the turbo, but I dont see the reason of the failure. why are some cylinders in your engine running lean? I dont see how could a faulty turbo cause that, if it would not supply enough air, the cylinders would run rich, than the ECU is supposed to intercept and cut the fuel down... I dont understand.
Wish U good luck.
Disclaimer: All this message was written with recycled electrons.
03-08-2008, 07:34 PM | #19 | |
13
Rep 143
03-08-2008, 10:05 PM | #20 | |
54
Rep 1,677
03-08-2008, 10:06 PM | #21 |
54
Rep 1,677
It is an 08 and supposedly has the HPFP. My SA said the HPFP wasn't throwing any codes.
03-08-2008, 11:44 PM | #22 |
اوليسيس
196
Rep 4,678
someone should compile a list of production dates, symptom, and tunes. We may be able to narrow down the problem.
