03-28-2016, 10:12 AM | #1 |
Rep 11
Center Console USB Issue
Sorry if this has come up before, I have searched and searched and not found a thread associated with the issue I'm having.
I have a 2015 335i M Sport I recently purchased new as a left over 2015 Inventory. The issue I'm having is my USB port in my center console acts as if it has a short in it.... my phone will connect and disconnect.... sometimes it won't do it... other times it's non stop. I thought maybe it was my cable... but I recently had a loaner and the cable I have worked flawlessly. I decided to plug in my old ipod Nano... it does the same thing. The most annoying part of it all is that when it does drop connectivity, it even makes my bluetooth lose connectivity for audio... it will say that my phone is connected, both the phone and music logo are lit up in the bluetooth menu... phone says it's connected... but in the media menu under the bluetooth option it says no device connected... It's like it freezes the entire idrive temporarily. Anybody else experienced similar behavior out their USB connectivity? |
03-28-2016, 12:02 PM | #2 |
175
Rep 766
What phone and os?
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
03-28-2016, 01:47 PM | #5 |
304
Rep 1,739
It does this occasionally for me too. Something about the USB gets hosed and I've had to reset iDrive and devices. Device connects/disconnects/connects over and over. Be sure you are using a genuine apple cable too. I've seen non-oem cables behave funny. And yes, it seems when one device got whacky every device connection loses its mind too.
03-28-2016, 02:28 PM | #6 | |
Rep 11
I will try the hard reset and I also found there is an update for my car that I will try to do via USB flash drive. |
03-29-2016, 08:42 PM | #7 |
Rep 11
Okay... I've tried everything I can find on how to reset my idrive.... nothing seems to do anything. Also, the bmw.com/update site says that I am eligible for update UPD05073. I have a new flash drive in FAT32 format... I download the folder to my USB flash drive. When I follow the instructions to install it in my car, the idrive says software update found on USB... or something to that effect.... soooooo frustrating.
03-30-2016, 08:01 AM | #8 |
380
Rep 2,290
I would take it to the dealer to have them first update the software if you're unable to do so on your own. Then if the issue persists, bring it up with the dealer.
03-30-2016, 10:10 AM | #9 |
304
Rep 1,739
Wouldn't you know it...the day I posted my response above, I get in my car and my damn iPod (which I leave connected in the armrest) loses connection and I have to fight with it a bit.
To restart iDrive push and hold the power button until the screen goes blank and it resets. It takes several seconds. |
04-25-2016, 07:50 PM | #13 |
Burgh Bimmer
Rep 18
I posted a similar thread in this forum. Link here: http://f30.bimmerpost.com/forums/sho....php?t=1163296
I did a couple things last year. Install the software update from the BMW website that owners have access to. Had BMW dealer install their whole car program update (I forget the proper name). Bought a brand new cable that was certified Made for iPhone (MFi). I hear that the issue is related to the center console not allowing the power draw that the iphone wants. This will be particularly noticeable when the battery is low because the iphone wants to draw more power than the center console was initially spec'd to do. |
04-26-2016, 05:22 AM | #14 | |
433
Rep 778
Seems a low battery may be the cause and it is drawing too much current to charge. You'd think BMW would spec it to charge these types of devices though. It occasionally does it with my iPhone 6 too. |
04-26-2016, 08:30 AM | #15 | |
Burgh Bimmer
Rep 18
I've also read good things about these: http://www.amazon.com/iPhone-Chargin...=sr_1_1&sr=8-1 BMW's solution on this is pretty poor. We pretty much have to stream via Bluetooth and use the BMW adapter which restricts the current to what the console can handle or use use a cigarette lighter power plug. |
04-26-2016, 04:50 PM | #16 | |
304
Rep 1,739
04-26-2016, 07:15 PM | #17 |
92
Rep 267
Actually the USB port in the BMW delivers a full 500 mA as per standard USB 2.0 spec. Unfortunately with increasing battery capacities in newer smartphones, higher charging currents are required to charge those phones, and each manufacturer has their own unique chargers and ways to signal the charger to deliver the higher current required to charge the phones, because USB standards have not kept up, even USB 3.0! It's different from manufacturer to manufacturer. I bet when BMW designed this USB interface for the 3 series, no one was even anticipating the need for higher current charging capabilities, so you really can't blame them for not supporting it, even with current model cars. So for now either keep your phone with a healthy charge, or using a high current cigarette lighter charging adapter and output audio via 3.5 mm jack or bluetooth audio.
2017 430ix Gran Coupe
04-27-2016, 01:55 AM | #19 |
Rep 1
I had the same problem, so I even called the BMW concierge and they told me "it the phone". They have a list of phones that are "problematic" but it did my iPhone and Galaxy.
Take it to the dealership - have them look at it. |
04-27-2016, 05:04 AM | #20 | |
433
Rep 778
It's still doing it now, fully charged the a genuine iPod lead. Next plan, try a software update (Then dealer!). |
05-14-2018, 02:29 PM | #21 |
336
Rep 963
sorry to bump an old thread, but was there ever any solution to this? my wife's X3 does the exact same thing as the video that @Dyl posted but have not found a solution yet. Iphone cable works fine plugged into the cig adapter
05-14-2018, 07:06 PM | #22 |
¯\_(ツ)_/¯
537
Rep 1,000
The cables are sometimes only supported to charge the iphone and not sync data, trying a new cord is the best place to start. If that doesnt work changing the plug seems to work
