03-27-2016, 09:44 AM | #1 |
39
Rep 127
After 4 months of ownership- M235
Purchased a lightly used 2015 M235 (8k mi) and recently took it for a long weekend drive that included freeway, mountain (Tail of the dragon) and city driving, so I'd like to share my impressions.
Before discussing the overall ownership there are a few thinks that annoy me about the car. 1) double pull on door latch to open door (yes I know you can get around this by not using self locking). 2) nanny oversight of iDrive system..."confirm", resetting drive mode every time I get in the car, etc. 3) inconvenient door pull locations. 4) lack of lsd as standard. 5) undersized tires (especially in front) limit cornering, especially with no front camber adjustment. 6) gauges - lack of temp and electrical gauges, speedo and tack are not illuminated when lights are not on, making them hard to read in the daylight especially if wearing sunglasses, 7) Nav system is not as informative as other car companies, 8) improved but imperfect iDrive system to name just a few. Overall performance: 1) very good mid-range power and responsiveness, 2) good handling to about 7-8/10ths, then the lack of camber, lack of lsd, and small front tires limits the grip and overall cornering capabilities, 3) responsive 8 speed auto in sport or manual mode, acceptable in standard mode for general driving, but always eager to meet the task, 4) PSS non run-flat are ideally matched to the intended use for this car - sporty/comfortable daily driver with higher than normal capabilities, 5) brakes have improved after "re-bedding" process and are strong but a little soft on initial bite, 6) adaptive suspension is a nice balance btwn comfort and improved handling over std BMW suspension or for those that don't want to live with a full M sport ride. Overall other: 1) great seating position and sport seats, easily adjustable, 2) overall size of the car makes it nimble yet flexible, 3) mixed on styling - overall like the design but some angles are unflattering (rear wheel well/fender), 4) wheels are so-so in design and are a pain to clean out recessed groves, 5) entertainment and HVAC controls are fine but radio/amp/speaker quality is lacking...expensive and challenging to upgrade, from what I've been told, 6) car feels/drives very well in daily use but as demands increase for handling/performance it can show the limitations of the car. Weekend drive: Car is an excellent open road (interstate/hwy) cruiser. ..very good cruise control, excellent seating and settable chassis control suits those that are very connected to their car. The adaptive suspension allows the car to be "tweaked" for road conditions and road types. Eco drive is basically "worthless" IMO on the hwy. The additional gas mileage derived from ECO over standard "auto" settings in comfort or sport mode was less than 3 miles per gallon on the hwy. May be more benefit in town but I'd personally never use it bc I hate the "stop start" mode and it is soooo sluggish. When driven in the city the car works fine, easy to modulate accelerator/transmission to city conditions and the overall size is welcomed for maneuverability and parking. If you leave it in comfort mode its great, but if you like a stiffer chassis or sharper shift pattern you'll need to reset mode every time you restart the car...annoying but not insurmountable. Where I think it shines the most is on small 2 lane roads with varying degrees of surface texture, cornering speeds, passing and a mixture of speeds. This is where the M235 really is in its glory! Passing power is a blast! The combination of the 8 speed auto in sport (or manual mode) and the mid-range power makes this car a quick and efficient tool for dealing with passing. In this type of driving the suspension, tires and stock setup is well suited to the task...it is smooth, responsive and provides confidence. In the mountains or extremely tight cornering on surface roads the tire size (not the PSS tires) and the lack of front camber (grip) combined with no LSD makes the car edgy and loose as the limits (8/10ths) are approached plus the PSS outer edges start to suffer. The power is very good and the transmission seems to always select the right gear (Sport mode)...but it can be a little late in executing the downshift. In those cases a simple pull ( or 2) on the paddles moves you into manual mode so that you can time the very fast downshift to just when you want it. Is it a GREAT mountain car or aggressive twisty backroad car...no,..... but it is a very capable car and a well rounded driver. I think of this car as being like the old "IS" bmw classification of yore. It is a very capable car with a very wide range of performance and practicality that is slightly set apart from the rest of the line-up without going the extra step for the more "hard core" and less flexible M series. I've owed three "M" cars and I liked them very much, and if I was going to be using the car for primarily very aggressive weekend driving/or tracking I'd choose a different weapon. The M235 is in a nice sweet spot for those people that want/must daily drive their car but want the satisfaction and enhanced performance without trading off much NVH. It is an ideal weekend "get away" car with handling and performance to match/exceed most rivals. What I'd change/or add to make it better: 1) Improved handling - M4 LCA, LSD, performance alignment and wider tires. I wouldn't do the springs or sway bars bc it starts to tradeoff the very virtues of flexibility that I like about the car. 2) Reprogramming to overcome some of the annoying factory settings. 3) Upgrade the wheels (wider, lower weight and better styling) and possibly the brakes for better initial bite and heat resistance...less dusting would be nice too. That's about it. Last edited by jaboyd; 03-28-2016 at 03:19 PM.. |
03-27-2016, 11:07 AM | #3 |
39
Rep 127
I agree. If I wanted a track toy or a weekend an M2 would be the better choice from BMW. I would be more inclined to look at other brands/options for an aggressive sports car/sedan which are more readily modded or setup from factory.
03-27-2016, 11:59 AM | #4 | |
871
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
03-28-2016, 10:19 AM | #5 |
37
Rep 95
Good review...The M235i isnt a track car that is for sure. The limitations of this car are so far beyond the legal limits of public roads it isnt funny, however.
The M235i is probably my favorite car that I've owned. I do miss feel the sensation of speed and driver input of a slower car at lower speeds... I would have to get into ludicrous ticket territory to feel like Im pushing the car so I end up yawning on curvy roads... This car has me wanting a slower car (Miata) for weekend canyon carving rather than a faster car.... |
03-28-2016, 11:09 AM | #6 | |
39
Rep 127
In my case, one of my other cars is a modified 2011 STI for the aggressive "hair on fire" weekend drives. It is raw, fast and an absolute blast...more grip than M235 and about the same zero - sixty times. And NO wife does not like to ride in this car...but now she has the M235 when she wants it....perfect! |
03-28-2016, 01:13 PM | #7 |
119
Rep 221
Nice write up jaboyd!
I agree with you guys on how difficult it is to feel like you're pushing the car on public roads and how great a car it is even on long trips and bumpy roads. In my experience it holds its own on the track too. I can't believe how nice it rides, yet how fast of laps it puts down. |
03-28-2016, 10:36 PM | #8 |
663
Rep 892
Can you explain your point here tbonez?
I drove a 2005 Mustang GT at HPDE events for 8 years, and it served me very well, teaching me the basics of performance driving. That car was stock other than Hawk HPS brake pads and ATE Super Blue fluid, and it never had a single issue ever, on the track or off. I had the thing up to 130 mph at Watkins Glen, so it was no slouch either. But the M235i is much more capable on the track than that Mustang from what I experienced last August at Palmer Motorsports Park in MA. My 2 Series is stock too, so not sure where you're coming from?
Vehicles: 2021 Alpine White M2C 6MT; 2011 Kawasaki Z1000 (1/4 mile 10.3 seconds @ 129 mph - stock)
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
03-29-2016, 03:55 PM | #9 | |
37
Rep 95
The M235i is a car I wouldnt pick as a track car. This is for numerous reasons from cost of operation, cost of upgrade, lack of aggressiveness in the area of suspension, brake challenges, Turbo engine, lack of feedback from the tires, etc.....The car can make a good track car but its not a track car I would pick or enjoy grinding out lap after lap especially in terms of the cost of the car. |
03-30-2016, 03:46 PM | #10 |
683
Rep 1,017
That was a really solid review. I've had my M235i for a little over a month and it's just right for me. My previous car was a 2014 Evo X and I never pushed the car that hard. On roads I've driven both cars, at the level at drive at; the M235i performed just as well as the Evo. Having said that, in curves the Evo felt like it could do more if it had to. That car clawed it's way out of corners.
What I like about the M235i is it's easy to just cruise along in traffic or get on it if you need to. It's a nice overall driving car. It also has a lot of little nice things about it, compared to my Evo. |
03-30-2016, 03:59 PM | #11 | |
37
Rep 95
Great follow up...Its the best and most fun DD I've ever owned. I wouldnt trade it for an M2 or a GT350 for daily driving. |
03-30-2016, 06:01 PM | #12 | |
39
Rep 127
The M235 is simply a few 10ths behind the EVO in pure performance but so much more sophisticated, flexible, and higher quality. I like EVOS but they are challenging to live with on a day to day basis. Track car ....give me the EVO. AUTOX car....give me the EVO. For everything else give me the BMW. |
03-30-2016, 07:42 PM | #13 | |
683
Rep 1,017
If I had to do it all over again, leaving out the fact that I would have got an M235i instead; I would have bought a loaded MR instead of a GSR. The M235i has all the stuff I wanted in the Evo X and then some. |
03-31-2016, 05:48 PM | #14 | |
127
Rep 765
"out of the box", I would say the M235 is pretty nice, but not quite the perfect BMW package. As you mentioned, a few small changes would have changed everything (and almost negated the eventual M2). I think BMW knew that as well, so we got the 'just enough' 2er, without damaging future M2 sales.... sadly. I plan on keeping my eye out for a totaled M2 to grab some easy swaps off of it - primarily the interior (love the blue stitching), and maybe some of the CF trim. The rest we can either buy already or just will not fit (rear valance/exhaust, which is oh so sexy).
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
