03-22-2016, 11:09 PM | #1 |
169
Rep 548
Drives: 2011 E90 M3 ZCP
340i without Navigation?
Can anyone confirm what exactly is different between a non-navigation based and the navigation based iDrive system? I ordered my car without navigation and it's bundled with a bunch of stuff and I'm wondering what specifically I won't be able to do.
Thanks! |
03-22-2016, 11:34 PM | #2 |
2JZ-GTE
3045
Rep 3,997
In the United States you don't get the bigger navigation display, no navigation, BmW online connected stuff, heads up display, and the enhanced dash display.
03-23-2016, 07:04 AM | #3 |
169
Rep 548
03-23-2016, 08:41 AM | #4 | |
541
Rep 1,894
03-23-2016, 08:59 AM | #6 | ||
169
Rep 548
But other threads are suggesting that since MY2015, you can use BT audio with the base iDrive system. |
03-23-2016, 09:07 AM | #7 |
541
Rep 1,894
As you car is latest spec, sounds like you will have the HU_ENTRYNAV. I'm sure you can just code on EBT. It also means you should be able to whack on the 8.8" screen.
Pop up a new message in rgds to EBT coding, up on the coding forum. I have the NBT so can't tell you if it work 100%. |
03-23-2016, 09:43 AM | #8 | |
169
Rep 548
03-23-2016, 09:46 AM | #9 |
541
Rep 1,894
It's current version of iDrive without nav. In fact the business nav is the same unit, but has the correct FSC code to enable navigation. Chances are the rear external connectors like GPS are missing!
03-23-2016, 09:54 AM | #10 |
169
Rep 548
Awesome, thanks for the clarification. So the NBT was the previous gen of iDrive?
03-23-2016, 09:57 AM | #11 | |
541
Rep 1,894
The previous version of the pronav was HU_CIC. |
03-23-2016, 10:11 AM | #12 |
169
Rep 548
Got it, they sure know how to make it confusing! Mine is called ENTRYNAV even though it doesn't have nav! You guys are lucky in the UK. Nav is now standard on anything +MY2015!
03-24-2016, 09:49 AM | #14 |
169
Rep 548
Just following up on this again. Does anyone know if the BMW Apps can be enabled via coding with the HU_ENTRYNAV? I'm looking around and it's suggesting that you must have navigation already. I don't have navigation so I'm wondering if it's possible at all.
I really only care about the Spotify integration, which would be awesome. |
03-25-2016, 01:48 PM | #15 |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I use Pandora on my car (without Nav). Works just fine. Spotify too.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
03-25-2016, 04:11 PM | #16 |
169
Rep 548
03-25-2016, 04:23 PM | #17 |
1061
Rep 3,258
Just regular music streaming. With non-nav, it's pretty limited on the choices that will work.
25% 3M Tint| |
04-01-2016, 08:19 PM | #19 |
263
Rep 1,130
Drives: '16 340i AW MSport
I can confirm you can swap to the 8.8 display and what a worth while upgrade it is!
04-01-2016, 08:38 PM | #20 |
169
Rep 548
04-01-2016, 08:39 PM | #21 |
263
Rep 1,130
04-03-2016, 12:32 PM | #22 |
263
Rep 1,130
Snapped a pic earlier....
