03-21-2016, 06:35 PM | #1 |
Supreme Being
1804
Rep 5,425
Some opinions and advice needed:
Weekend trip to the North West so ~600 mile round trip. 50 miles from home I get a coolant low warning, followed 5 minutes later by engine high temp warning! Stopped at a services for a while to allow the engine to cool, topped up the coolant and off again. 20 minutes later, same error and engine temp shot up again! I crawled home at 40mph to manage the temperature and made it Ok (thank goodness this didn't happen near Manchester!). Anyway, coolant is again very low so a call the the experts tomorrow. No obvious leaks, no obvious rad/inter cooler damage but no heater and the above errors. The oil looks suspect - what do you think?
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
03-21-2016, 06:47 PM | #2 |
1155
Rep 2,727
Those pics look worrying to me. Any kind of emulsion in the coolant tank is not good news. Did you top up the coolant tank with water or proper coolant?
Hope it gets sorted with minimal fuss.
Curent: F31 335d xDrive MSport Individual TB / OW Merino
Gone: F31 320d MSport BS /CR, E61 520d MSport Bus Ed, E53 X5 V8 Sport |
03-21-2016, 06:52 PM | #3 |
6419
Rep 8,500
The symptoms and the state of the filler/cap suggest there's a problem. Get it in straight away and don't drive it far.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
03-21-2016, 06:53 PM | #4 | |
Supreme Being
1804
Rep 5,425
By the roadside so water - needs to go in anyway as a result! EDIT: or does it - BMW coolant is diluted anyway.
03-21-2016, 06:56 PM | #5 | |
Supreme Being
1804
Rep 5,425
Forgot to add - it started to misfire badly about 20 minutes before the warnings - I started slating the BP fuel I'd just filled up with!
03-21-2016, 06:59 PM | #6 | |
1155
Rep 2,727
When you say engine temp shot up, I assume that was the oil temp? If there are no external signs of water loss, then it points to the head gasket. But guess you already thought this.
03-21-2016, 07:06 PM | #7 |
512
Rep 1,404
Looks like water contamination in the oil? (or more worryingly, coolant), if you had a missfire maybe coolant has leaked into a cylinder?
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras Prev - E92 330D M Sport | Black | Highline Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White |
03-22-2016, 02:05 AM | #9 |
288
Rep 1,201
well that doesnt look good. you say you had to top up the coolant twice. thats ALOT of water. and if it isnt leaking from pipes and hoses, and all that water is mixing with the oil then it would be safe to assume you should absolutely not start this car up anymore. it could be something simple to fix. or it could be something capabke if nuking that engine. get her inti the garage asap
hope it goes well |
03-22-2016, 03:32 AM | #10 |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Oh dear, none of this sounds particularly good. The coolant is going somewhere, rather hope it's a leak to the open than the internals I guess.
If it is something serious then it'll be the first serious issue on one of these engines I can recall.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
03-22-2016, 03:48 AM | #11 | |
Live for today tomorrow never comes
1989
Rep 9,498
Good luck with it.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
03-22-2016, 04:32 AM | #12 |
3719
Rep 8,636
Yeah, not a good sign that emulsified oil. And as previously mentioned that's a lot of water its got through. No obvious sign of a leak on the ground when its been stood a few min?
03-22-2016, 04:38 AM | #13 |
1867
Rep 13,043
Drives: BMW M340I G20
Have you checked the oil level? If noticeably higher than it should be coolant has leaked into the oil and could have fooked the internals.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
03-22-2016, 05:09 AM | #14 |
Supreme Being
1804
Rep 5,425
Oil was ok - although it wouldn't let me check it yesterday due to the error.
No drips, hisses or moisture anywhere to be seen. I'll call the dealer shortly and have them collect from my drive - if they can't I'll be calling recovery tonight.
03-22-2016, 05:29 AM | #16 |
409
Rep 903
No idea if it affects warranty but if I were you I would top it up with official BMW coolant before you take it in. They may try to blame the failure on you using water if they're really being buggers about it
03-22-2016, 05:35 AM | #17 | |
Supreme Being
1804
Rep 5,425
I don't think it's like the Toyota non aqueous stuff...
03-22-2016, 05:41 AM | #18 | |
849
Rep 1,858
have you any mods to the engine? (chip / map etc?) |
03-22-2016, 05:53 AM | #20 | ||
Supreme Being
1804
Rep 5,425
No mods - tried a box for a couple of weeks but otherwise standard. Just called them: "Can't help you - we're fully booked until mid April" Great. Calling assistance tonight.
03-22-2016, 06:05 AM | #21 |
Barge driver
8656
Rep 12,425
No you didn't.....
730d/Z4C
03-22-2016, 06:20 AM | #22 |
Supreme Being
1804
Rep 5,425
What are you saying - of course I didn't!
