Oil Catch Can
View Poll Results: Oil Catch Can | |||
My modified N55 has an oil catch can, yours should too | 10 | 29.41% | |
My modified N55 does not have an oil catch can, no need | 13 | 38.24% | |
My modified N55 does not have one but I plan to install | 11 | 32.35% | |
Voters: 34. You may not vote on this poll |
03-20-2016, 07:49 AM | #1 |
850
Rep 1,182
Drives: 2011 E92 M3 6MT ZCP
Oil Catch Can
Have seen two schools of thought on this. I purchased a JB4 over Cobb using a poll and I expect I know what this outcome will be too.
Thanks for the input. Last edited by timothy2001; 03-20-2016 at 07:52 AM.. Reason: Screwed it up the first time |
03-20-2016, 04:56 PM | #2 |
82
Rep 604
I don't have one, most people who have actually used them say there isn't a need, I guess you can't know until you try it. I've taken off my charge pipe a few times over the past 40k km, never more than a slight film of oil, if that.
However I do plan to install one if I do find it an issue, maybe I'll wait and see how my intake valves are for my first blast. |
03-20-2016, 06:22 PM | #4 | |
541
Rep 3,131
Drives: 2011 335i e92 DCT
Detach the old hoses, screw in place the OCC. Plug the hosees into the car and then lay the other ends over the OCC, make a mark, cut then push it on. Cutting the engine cover was a little more difficult.
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
03-21-2016, 12:31 AM | #8 |
324
Rep 2,014
I was told by a BMW tech that it is not necessary to buy the catch can for the n55.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
03-21-2016, 03:36 AM | #9 |
61
Rep 582
To all of you who doesn't need one.
Not the best picture of the intake manifold but.. It's not bad at all at 48k miles, boosted since between 25 to 30k miles. PS: photos failed uploading through the app... Will do it when I'm on computer Last edited by Joey911; 03-21-2016 at 03:41 AM.. |
03-21-2016, 07:45 AM | #10 |
Came to the N55 Darkside
1113
Rep 12,740
03-21-2016, 08:56 AM | #11 |
Is it the shoes!?
3884
Rep 5,112
I had the wrong cutting tool All I had was a pair of crappy sidecutters that didn't open wide enough. I don't recommend using those.
That engine cover took ages to cut. The instructions are fairly conservative on how much to grind away. |
03-21-2016, 09:16 AM | #12 |
93
Rep 213
Drives: 2011 335i xDrive
I don't feel comfortable telling someone whether or not to use one, but FWIW my experience in the N55 after over a year of running with one, FBO with a pro tune, not a single drop of oil.
Like everyone has said, BMW did a pretty good job of sorting out the oil issue by re-engineering the PCV system. I just put one on mine at nearly day one out of paranoia, figured it cant hurt. |
03-21-2016, 05:53 PM | #13 | |
541
Rep 3,131
I used some massive tin snips for the hose, went through like a hot knife cutting butter haha. The engine cover I hacked at it with a serrated knife then sanded down the edges to make it look a bit neater and so it doesn't cut the hoses. I did that around 6 months ago, i should really check the can to see whats inside.
03-21-2016, 07:16 PM | #15 |
e92 - 335i
179
Rep 743
03-22-2016, 02:44 PM | #16 |
BimmerPost Supporting Vendor
24290
Rep 190,975
You wont know whether you need one or not before installing it ... At the current price it is being offered for i would get one
03-22-2016, 08:18 PM | #17 |
850
Rep 1,182
03-25-2016, 11:44 AM | #20 |
320
Rep 1,023
I have both an N54 and N55, both roughly FBO and with BMS OCCs. Strangely, the N54 never has any oil in it, while the N55 has around 1/4" to 1/2" at oil change time (7500 miles). Meh, I guess every engine's different.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
03-25-2016, 06:06 PM | #21 |
218
Rep 245
Turbo engines use 2 separate crankcase ventilation paths: one when boost is positive (accelerating), and the other when boost is negative (cruising).
The attached photo (stolen from Weehe's N54tech post) shows the first inspection of his N55 at 80K miles without a catch can. This particular engine had a bad PCV regulator and was drawing excessive vapors for at least 5K miles so his carbon buildup should be worse than normal but what you can see here is:
