03-19-2016, 09:51 AM | #1 |
57
Rep 124
Best overtake on the with Sports Auto - kickdown or point of resistance before ?
Getting close completing the work up/running in period and was wondering what members find best for fast acceleration and overtaking? Do you simply floor it to get kickdown or is it better to use a higher gear at the point of resistance before kickdown where the torque takes over.
Mine is the 30d engine. Just my last three cars, Golf GTD, 325d, Merc C220d kick down, got the lowest gear, but the revs were round to the 4000rpm point and all that happens is revs, noise and no action until the next gear change up and the torque kicks back in
M340i saloon, mineral grey, comfort plus pack, driver assistant pro pack, HK sound, mineral grey
Also drive BMW Z4 S Drive 23i Auto, Suzuki Jimny JLX+ |
03-19-2016, 10:06 AM | #3 |
741
Rep 2,511
Stick to left is my solution also. Quick and easy to do. A natural movement and then smooth acceleration. Selecting sport by the rocker switch is too fiddly. But, if you're already in sport you just accelerate. Mashing the accelerator and getting kick down can unsettle the car, especially out of a slow corner or when passing something very slow in comfort mode. Stick to the left also resets the driver adaptation.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
03-19-2016, 10:15 AM | #4 | |
178
Rep 1,470
03-19-2016, 10:42 AM | #5 |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
On a road I'm likely to be overtaking on I'm seldom not in sport mode so I tend to just pull out and accelerate. I never mash the throttle as I don't like kick down to the lowest gear.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
03-19-2016, 10:45 AM | #6 | ||
741
Rep 2,511
Acceleration may not be noticeably quicker, but all goes much smoother than when in comfort mode, with the stick in the normal right position. Running standard comfort I've had kick down engage the sideways gear and unexpectedly kick the rear out. Particularly with my narrow winter rears when passing a tractor or something else slow on greasy country roads. So, I find pre-changing down by selecting sport mode or putting the stick to the left makes for faster overtakes.
03-19-2016, 11:14 AM | #9 |
10995
Rep 32,881
03-19-2016, 12:45 PM | #10 |
99
Rep 464
I don't get the torque thing. Power is what gives you acceleration, which is revs x torque.
To make the quickest progress, gear down to put the car just below the power band in advance of the overtake. I find Sport tends to raise it about 2,200 which is sufficient in the lower gears but too far below the power band. If I'm on a short A-road pass I'll have it at about 3,000 and pull to 4,500 before shifting manually. That said, the benefit of a diesel and low-down torque is that you can still make a pretty quick overtake without gearing down because it can make a good % of peak power at low RPM. So it'll feel smoother to waft on by without any gear-down and high RPM shifting it's good for 'lazy fast driving'. |
03-19-2016, 03:23 PM | #11 |
451
Rep 1,201
I think it was Enzo Ferrari was once quoted as saying "Horsepower sells cars, torque wins races"
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
03-19-2016, 03:36 PM | #12 | |
Barge driver
8656
Rep 12,425
It's more about how long the torque can be sustained that gives you a truly powerful car like the M5 with over 500lb/ft from 1500-5750, having lots of torque for a very limited time isn't the goal most race engineers are aiming for. Look at the area underneath the torque curve, rather than the peak value.
730d/Z4C
03-19-2016, 03:51 PM | #13 | |
2070
Rep 2,639
03-19-2016, 04:07 PM | #14 | |
451
Rep 1,201
03-20-2016, 12:47 AM | #15 |
849
Rep 1,858
I find the kick down a complete pain.
Has any one fitted one of the Burger kickdown stops? http://www.burgertuning.com/downshift_blocker_BMW.html Any merit? |
03-20-2016, 03:57 AM | #16 | |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
03-20-2016, 07:44 AM | #17 | |
86
Rep 312
03-20-2016, 08:18 AM | #18 | ||
447
Rep 1,453
03-20-2016, 08:26 AM | #19 | |||
86
Rep 312
03-20-2016, 08:34 AM | #20 |
3719
Rep 8,636
Sport mode or stick to the left in comfort mode.
Just holds a gear lower so slightly higher revs putting it right in max shove torque zone for the overtake. |
03-20-2016, 08:34 AM | #21 |
3719
Rep 8,636
03-20-2016, 08:38 AM | #22 |
2856
Rep 5,608
