2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Help needed: Bought Powered Sub for Trunk (kicker Substation)
      03-16-2016, 01:51 PM   #1
shadyru
Drives: M235i
I have the PP82dsp so will be hooking up the rca's to the subwoofer out on the PP82dsp
But so far I have purchased
http://www.kicker.com/substation
http://www.amazon.com/KnuKonceptz-Ko.../dp/B0058OENJ2
I have never installed an amp besides the PP82dsp.
Has anyone installed something similiar to what Im doing? Any instructions out there on how to run the cables? Im hoping this wouldnt be too difficult so any help would be awesome!
Thanks!
      03-16-2016, 02:20 PM   #2
Grave
Grave's Avatar
France
Drives: 220D M-Sport
you have a manual with all instructions
From your ppsp you need the two RCA and remote amp see your Audiotec notice
With your amazon purchase pick +12v from battery and dont forget the fuse. take a mass screw in the trunk (not direcly from battery)
Then you need to adapt your PPSP with a PC to get front signal to RCA output in IO section then apply a low pass filter to these output.
The good thing your sub has only two connectors so it's easy to put it out of the car.
The bad thing : trunk is well encapduled so a 10 sub will not provide many more bass than two good subs under the seats (not OEM) and it takes a lot of place in a small trunk.
      03-16-2016, 06:30 PM   #3
jetvet
jetvet's Avatar
34
Drives: 2015 M235i xDrive
I installed a 12" JL Audio powered sub and I'm pretty pleased with the sound and it didn't take up that much room. I had it facing the rear seats so I may spin it around facing rearward as I do get some very slight rattles on certain songs (I listen to hard rock/progressive rock).
Here's a couple pics of where to run the power and ground wires. I looked at the manual for your sub and you shouldn't need to run the "REM" or remote turn-on wire and rather just set the amp auto turn on to "audio".
Like Grave said, just run the power, ground and RCA outputs from the Bimmertech amp to the sub input harness and you should be good to go.
Current: 2015 M235i F22 BSM (FBO)
Current: 2015 X5 M Sport CBM (hers)
Previous: 2008 335i E90 Tiag (FBO)
2addicts
